SQL JSON Functions
JSON functions are used to parse JSON objects or JSON arrays and extract values from them.
Syntax
SELECT json_extract(Results, '$[0].EndTime')
JSON Function Statements
Statement |
Description |
Example |
Returned Value Type |
json_extract |
Extracts a set of JSON values (object or array) from a JSON object or JSON array. |
json_extract(x, json_path) |
Data of string type in JSON format |
json_extract_scalar |
Extracts a set of scalar values (string, integer, or Boolean) from a JSON object or JSON array. If the specified JSON path is not a scalar, null is returned. |
json_extract_scalar(x,json_path) |
varchar type |
Examples
- json_extract function
Obtain the value of the EndTime field in the Results field.
- Example field
Results:[{"EndTime":1626314520},{"FireResult":2}]
- Query and analysis statement
- Query and analysis result
Table 2 Query and analysis result EXPR$0
1626314520
- Example field
- json_extract_scalar function
Obtain the values of the RawResultCount field from the Results field, convert these values to bigint type, and sum them up.
- Example field
Results:[{"EndTime":1626314520},{"RawResultCount":1}]
SELECT sum(cast(json_extract_scalar(Results,'$[1].RawResultCount') AS bigint) )
Table 3 Query and analysis result EXPR$0
1546
- Example field
