Updated on 2025-12-05 GMT+08:00
SQL IP Functions
The relationships between IP addresses and regions provided by LTS are from third-party libraries. The data is updated periodically (about half a year) and may not reflect the correct relationships. LTS will be optimized to update the libraries more frequently to provide better experience.
A maximum of 5 million data records can be queried using the aggregate query of an IP function. Exceeding this limit will cause the query to time out.
IP functions identify the country, state/province, city, and network carrier to which a target IP address belongs.
Syntax
SELECT count(*) AS PV, ip_to_province(client_ip) AS province GROUP BY province
IP Function Statements
Table 1 IP function statements
Statement
Example
ip_to_province
Identifies the state/province where an IP address is located.
ip_to_province(x)
ip_to_country
Identifies the country/region where an IP address is located.
ip_to_country(x)
ip_to_city
Identifies the city where an IP address is located.
ip_to_city(x)
ip_to_provider
Identifies the network carrier of an IP address.
ip_to_provider(x)
ip_to_geo
Returns the longitude and latitude of an IP address.
ip_to_geo(x)
Examples
  • ip_to_province
    Obtains the top 3 states/provinces with the most requests.
    1. Query and analysis statement
      SELECT count(*) AS PV, ip_to_province(client_ip) AS province GROUP BY province ORDER BY PV desc LIMIT 3
    2. Query and analysis result
      Table 2 Query and analysis result
      PV
      province
      101
      Guangdong
      83
      Shanghai
      78
      Shandong
  • ip_to_country
    Obtains the top 3 countries/regions with the most requests.
      SELECT count(*) AS PV, ip_to_country(client_ip) AS country GROUP BY country ORDER BY PV desc LIMIT 3
      Table 3 Query and analysis result
      PV
      country
      100
      China
      76
      United States
      55
      Canada
  • ip_to_city
    Obtains the top 3 cities with the most requests.
      SELECT count(*) AS PV, ip_to_city(client_ip) AS city GROUP BY city ORDER BY PV desc LIMIT 3
      Table 4 Query and analysis result
      PV
      city
      109
      Guangzhou
      89
      Shanghai
      23
      Xi'an
  • ip_to_provider
    Obtains the top 3 carriers with the most requests.
      SELECT count(*) AS PV, ip_to_provider(client_ip) AS provider GROUP BY provider ORDER BY PV desc LIMIT 3
      Table 5 Query and analysis result
      PV
      provider
      115
      Telecom
      65
      att.com
      44
      Unicom
  • ip_to_geo
      SELECT count(*) AS PV, ip_to_geo (client_ip) AS geo GROUP BY geo ORDER BY PV desc LIMIT 3
      Table 6 Query and analysis result
      PV
      geo
      101
      83
      47.369013, -68.326674
      78
      32.715891, -117.161588
