Updated on 2025-12-05 GMT+08:00
SQL JSON Functions
JSON functions are used to parse JSON objects or JSON arrays and extract values from them.
Syntax
SELECT json_extract(Results, '$[0].EndTime')
JSON Function Statements
Table 1 JSON function statements
Statement
Example
Returned Value Type
json_extract
Extracts a set of JSON values (object or array) from a JSON object or JSON array.
json_extract(x, json_path)
Data of string type in JSON format
json_extract_scalar
Extracts a set of scalar values (string, integer, or Boolean) from a JSON object or JSON array. If the specified JSON path is not a scalar, null is returned.
json_extract_scalar(x,json_path)
varchar type
Examples
  • json_extract function
    Obtain the value of the EndTime field in the Results field.
    1. Example field
      Results:[{"EndTime":1626314520},{"FireResult":2}]
    2. Query and analysis statement
    3. Query and analysis result
      Table 2 Query and analysis result
      EXPR$0
      1626314520
  • json_extract_scalar function
    Obtain the values of the RawResultCount field from the Results field, convert these values to bigint type, and sum them up.
    1. Example field
      Results:[{"EndTime":1626314520},{"RawResultCount":1}]
      SELECT sum(cast(json_extract_scalar(Results,'$[1].RawResultCount') AS bigint) )
      Table 3 Query and analysis result
      EXPR$0
      1546
