LTS Alipay Applet SDK
If you need to collect and analyze user information on your Alipay applet, such as browser, browsing behavior, device, device exception, and network usage records, you can use this SDK to report logs to LTS.
To use this SDK, enable the anonymous write function of log streams. After this function is enabled, the reported logs are not authenticated and may generate dirty data. For details, see Managing Log Streams.
The Alipay applet SDK supports cross-cloud and local log reporting for whitelisted users in regions CN North-Beijing4, CN East-Shanghai1, and CN South-Guangzhou. To use it, create a service ticket.
Transport Protocol
HTTPS
- You have obtained the name of the region where LTS is deployed.
- You have obtained a project ID of your Huawei Cloud account. For details, see API Credentials.
- You have obtained the IDs of the target log group and log stream in LTS.
Version Updates
| Version | Description |
| 1.0.24 | Added support for regions CN East-Shanghai1 and CN South-Guangzhou. |
| 1.0.23 | Supported quick app reporting. |
| 1.0.21 |
| 1.0.19 | Changed the time threshold range from 1–60 to 1–1800, and changed the default value from 30 to 3. |
| 1.0.18 |
| 1.0.15 | Supported reporting logs to LTS through multiple log streams. |
Instructions
To ensure that Alipay applet logs can be reported, add the reporting address to the domain name list of the Alipay developer platform. For details about the reporting address, see Table 2.
Installing the SDK
Run npm i lts-mini-sdk in the root directory of the applet to install the SDK.
You can download the latest SDK from the open-source repository.
Sample Code
const miniSDK = require('lts-mini-sdk').default;
// import miniSDK from 'lts-mini-sdk';
App({
onLaunch(options) {
// Initialization
const mymini = new miniSDK({
// Reporting region
region: string,
// Huawei Cloud project ID
projectId: string,
// Log reporting address
url: string,
// LTS log group ID
groupId: string,
// LTS log stream ID
streamId: string,
// Debug log level
debug: string,
// Platform of the current applet
platform: 'my',
// Records threshold
cacheThreshold: number,
// Time interval threshold
timeInterval: number,
// Immediately report a single record, with labels
mymini.reportImmediately({ 'name': 'xiaoming', 'age': 18 }, { 'key': 'value' });
// Immediately report a single record, without labels
mymini.reportImmediately([{ key: 'value', number: 1, array: [], json: { json: 'json' } }, { 'key': 'value' }]);
// Cache and report multiple records, with labels
mymini.report([{ 'name': 'xiaohong', 'age': 18 }, { 'name': 'xiaobai', 'age': 20 }], { 'key': 'value' });
// Cache and report multiple records, without labels
mymini.report([{ 'name': 'xiaohong', 'age': 18 }, { key: 'value', number: 1, array: [], json: { json: 'json' } }]);
// Cache and report multiple records, with multiple labels (max. 50)
mymini.report([{ 'name': 'xiaohong', 'name': 'xiaolan' }], {'version': '1.0.0', 'render': 'mini', 'link': '/', from: 'zhifubao'});
}); Parameters
- Parameters
Table 2 Parameters Field
Type
Mandatory
Default Value
region
String
Yes
Region where LTS is located.
projectId
String
Yes
Project ID of the account. The value contains a maximum of 128 characters.
groupId
String
Yes
Log group ID. The value contains a maximum of 128 characters.
streamId
String
Yes
Log stream ID. The value contains a maximum of 128 characters.
url
String
No
Public network domain name for reporting. The value can contain a port number, for example, https://lts-access.cn-north-4.myhuaweicloud.com:443. If no URL is set, a link is automatically generated based on the region. The format is as follows: https://lts-access.{region}.myhuaweicloud.com. The domain name must be registered as a valid domain name on the server domain name setting page in the Alipay applet background (for details, see the applet official website). The value contains a maximum of 128 characters.
- When the SDK is used to report logs across clouds or locally, port 443 is used.
- When Huawei Cloud hosts report logs via the Huawei Cloud intranet, port 8102 is used.
debug
Boolean
No
OFF
Output level of the console debugging information. The options are OFF, ERROR, WARN, INFO, and DEBUG, in ascending order. The highest level is DEBUG. If an invalid value is entered, the default value OFF is used. If this parameter is set to true, DEBUG logs are enabled. If this parameter is set to false, DEBUG logs are disabled.
cacheThreshold
int
No
30
By default, the cache threshold is 30 records. When the number of cached records reaches the threshold (range: 30 to 1,000), cached records are reported.
timeInterval
number
No
3
By default, records are reported every 3 seconds. When the threshold interval (range: 1 to 1800) is reached, cached records are reported.
platform
String
No
baidu
Platform that supports data reporting. Currently, the following platforms are supported: baidu (Baidu applet), wx (WeChat applet), dd (DingTalk applet), my (Alipay applet), and quick (quick app).
- Parameters of the report method for reporting logs
Table 3 report Parameters Field
Type
Mandatory
Default Value
content
Object | Array<Object>
Yes
Object or object array to be reported. Each object can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 x 30 characters. Excess characters will be truncated.
Each object in the array can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 x 30 bytes. Excess characters will be truncated.
The log field name cannot contain double underscores (__).
labels
Object
No
Null
Log labels. The outermost key-value pair can contain a maximum of 50 key-value pairs. The outermost key can contain a maximum of 64 characters including letters, digits, and underscores (_), and must start with a letter. The maximum length of the converted JSON string is 1024 × 30 characters. If the length exceeds the limit, the record will not be reported.
- Parameters of the reportImmediately method for reporting logs immediately
Table 4 reportImmediately Parameters Field
Type
Mandatory
Default Value
content
No
Object or object array to be reported immediately. Each object can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 x 30 characters. Excess characters will be truncated.
Each object in the array can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 x 30 bytes. Excess characters will be truncated. If this parameter is left empty, logs in the cache will be reported immediately.
labels
Object
No
Null
Obtaining Parameters
- Regions
Table 5 Regions Name
Region
CN North-Beijing4
cn-north-4
CN East-Shanghai1
cn-east-3
CN South-Guangzhou
cn-south-1
- To obtain a log group's ID, choose Log Management in the navigation pane of the LTS console and hover over the target log group's name.
- To obtain a log stream's ID, click the down arrow on the left of the corresponding log group name to expand the log stream list, then hover over the target log stream's name.
