LTS Web SDK
If you need to collect and analyze user information on websites, such as browser, browsing behavior, device, device exception, and network usage records, you can use this SDK to report logs to LTS.
To use this SDK, enable the anonymous write function of log streams. After this function is enabled, the reported logs are not authenticated and may generate dirty data. For details, see Managing Log Streams.
The Web SDK supports cross-cloud and local log reporting for whitelisted users in CN North-Beijing4, CN East-Shanghai1, and CN South-Guangzhou. To use it, create a service ticket.
Transport Protocol
HTTPS
- You have obtained the name of the region where LTS is deployed.
- You have obtained a project ID of your Huawei Cloud account. For details, see API Credentials.
- You have obtained the IDs of the target log group and log stream in LTS.
Version Updates
| Version | Description |
| 1.0.25 | Added the reportCallback parameter to config. This supports user-defined callback functions that trigger upon the success or failure of log reporting. |
| 1.0.24 | Added support for regions CN East-Shanghai1 and CN South-Guangzhou. |
| 1.0.21 |
| 1.0.19 | Changed the time threshold range from 1–60 to 1–1800, and changed the default value from 30 to 3. |
| 1.0.18 |
| 1.0.15 | Added support for multiple instances. |
Installing the SDK Using NPM
- Run the npm i lts-web-sdk command in the root directory of the project to install the SDK. You can download the latest SDK from the open-source repository.
- Example code:
const LTS_WEB_SDK = require('lts-web-sdk').default; // import LTS_WEB_SDK from 'lts-web-sdk'; // Initialization const weblog = new LTS_WEB_SDK({ // Region for log reporting region: string, // Project ID projectId: string, // Log reporting address url: string, // LTS log group ID groupId: string, // LTS log stream ID streamId: string, // Debug log level debug: string, // Threshold for the number of reported log records cacheThreshold: number, // Threshold for the interval between log reports timeInterval: number, // Callback function reportCallback: () => (result: { success: boolean; // Whether the reporting is successful labels?: object; // Labels included in the report content?: string[]; // Log content included in the report reason?: string; // Failure cause (only provided if reporting fails) }) => void, }); // Immediately report a single record, with labels weblog.reportImmediately({ 'name': 'xiaoming', 'age': 18 }, { 'key': 'value' }); // Immediately report a single record, without labels weblog.reportImmediately([{ key: 'value', number: 1, array: [], json: { json: 'json' } }, { 'key': 'value' }]); // Cache and report multiple records, with labels weblog.report([{ 'name': 'xiaohong', 'age': 18 }, { 'name': 'xiaobai', 'age': 20 }], { 'key': 'value' }); // Cache and report multiple records, without labels weblog.report([{ 'name': 'xiaohong', 'age': 18 }, { key: 'value', number: 1, array: [], json: { json: 'json' } }]); // Cache and report multiple records, with multiple labels (max. 50) weblog.report([{ 'name': 'xiaohong', 'name': 'xiaolan' }], {'version': '1.0.0', 'render': 'web', 'link': '/', from: 'web'});
Installing the SDK Through CDN Synchronization
- How to install:
In your HTML file, reference the SDK as follows:
<script src="https://res.hc-cdn.com/web-sdk-cdn/Version number/websdk.min.js"></script>
- Example code:
// Import the SDK on the page. <script src="https://res.hc-cdn.com/web-sdk-cdn/1.0.15/websdk.min.js"></script> // Initialization const weblog = new LTS_WEB_SDK({ // Region for log reporting region: string, // Project ID projectId: string, // Log reporting address url: string, // LTS log group ID groupId: string, // LTS log stream ID streamId: string, //Debugging switch. If enabled, you can view the debug logs. debug: boolean, // Threshold for the number of reported log records cacheThreshold: number, // Number of logs reported in the period. timeInterval: number, // Callback function reportCallback: () => (result: { success: boolean; // Whether the reporting is successful labels?: object; // Labels included in the report content?: string[]; // Log content included in the report reason?: string; // Failure cause (only provided if reporting fails) }) => void, }); // Immediately report a single record, with labels weblog.reportImmediately({ 'name': 'xiaoming', 'age': 18 }, { 'key': 'value' }); // Immediately report a single record, without labels weblog.reportImmediately([{ key: 'value', number: 1, array: [], json: { json: 'json' } }, { 'key': 'value' }]); // Cache and report multiple records, with labels weblog.report([{ 'name': 'xiaohong', 'age': 18 }, { 'name': 'xiaobai', 'age': 20 }], { 'key': 'value' }); // Cache and report multiple records, without labels weblog.report([{ 'name': 'xiaohong', 'age': 18 }, { key: 'value', number: 1, array: [], json: { json: 'json' } }]); // Cache and report multiple records, with multiple labels (max. 50) weblog.report([{ 'name': 'xiaohong', 'name': 'xiaolan' }], {'version': '1.0.0', 'render': 'web', 'link': '/', from: 'web'});
Parameters
- See the following table.
Table 2 Parameters Field
Type
Mandatory
Default Value
region
String
Yes
Region where LTS is located.
projectId
String
Yes
Project ID of the account. The value contains a maximum of 128 characters.
groupId
String
Yes
Log group ID. The value contains a maximum of 128 characters.
streamId
String
Yes
Log stream ID. The value contains a maximum of 128 characters.
url
String
No
Public network address domain name used to report logs. The port number can be specified, for example, https://lts-access.cn-north-4.myhuaweicloud.com:443. If url is not set, a link is automatically generated based on the region. The format is as follows: https://lts-access.{region}.myhuaweicloud.com
- When the SDK is used to report logs across clouds or locally, port 443 is used.
- When Huawei Cloud hosts report logs via the Huawei Cloud intranet, port 8102 is used.
debug
String
No
OFF
- Output level of the console debugging information. The options are OFF, ERROR, WARN, INFO, and DEBUG.
- If an invalid value is entered, this parameter defaults to OFF. The highest level is DEBUG, and the level decreases in descending order.
- If this parameter is set to true, DEBUG logs are enabled. If this parameter is set to false, DEBUG logs are disabled.
cacheThreshold
int
No
30
By default, the cache threshold is 30 records. When the number of cached records reaches the threshold (range: 30 to 1,000), cached records are reported.
timeInterval
number
No
3
By default, records are reported every 3 seconds. When the threshold interval (range: 1 to 1,800) is reached, cached records are reported.
reportCallback
function
No
User-defined callback function that triggers upon the success or failure of log reporting.
- Parameters of the Report method for reporting logs
Table 3 Report parameters Field
Type
Mandatory
Default Value
content
Object | Array<Object>
Yes
Object or object array to be reported. The limits are as follows: Each object can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 × 30 characters. Excess characters will be truncated.
Each object in the array can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 × 30 bytes. Excess characters will be truncated.
The log field name cannot contain double underscores (__).
labels
Object
No
Null
Log labels. The outermost key-value pair can contain a maximum of 50 key-value pairs. The outermost key can contain a maximum of 64 characters including letters, digits, and underscores (_), and must start with a letter. The maximum length of the converted JSON string is 1024 × 30 characters. If the length exceeds the limit, the record will not be reported.
- Parameters of the reportImmediately method for reporting logs immediately
Table 4 reportImmediately parameters Field
Type
Mandatory
Default Value
content
No
Object or object array to be reported immediately. The limits are as follows: Each object can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 × 30 characters. Excess characters will be truncated.
Each object in the array can contain a maximum of 300 key-value pairs. The maximum length of the JSON string is 1024 × 30 bytes. Excess characters will be truncated. If this parameter is left empty, cached logs will be reported immediately.
labels
Object
No
Null
Obtaining Parameters
- Read the region table.
Table 5 Regions Name
Region
CN North-Beijing4
cn-north-4
CN East-Shanghai1
cn-east-3
CN South-Guangzhou
cn-south-1
- To obtain a log group's ID, choose Log Management in the navigation pane of the LTS console and hover over the target log group's name.
- To obtain a log stream's ID, click
next to the corresponding log group and hover over the target log stream's name.
