Overview
IoTDA authenticates a device when the device attempts to access the platform. The authentication process depends on the access method.
| Access Type | Authentication Mode |
| Device using LwM2M over CoAP | You can call the API for creating a device or use the IoTDA console to register a device. Then, when connecting to the platform, a non-security device does not use DTLS/DTLS+, and carries the node ID to get authenticated. A security device uses DTLS/DTLS+, and carries both the secret and node ID to get authenticated. |
| Device using MQTT or MQTTS |
