Help Center/ IoT Device Access/ User Guide/ IoTDA Instances/ Tag Management/ Searching for Resources by Tag
Updated on 2025-03-26 GMT+08:00
After adding tags to cloud resources, you can use the methods described in this section to search for resources by tag.
Filtering Resources by Tag
- Access the IoTDA service page and click Access Console.
- In the upper right corner of the page, click the username and select Tag Management from the drop-down list. Figure 1 Tag management
- On the Resource Tags page, set the search criteria, including Region, Resource Type, and Resource Tag.
- Click Search. All the resources that meet the search criteria will be displayed. Figure 2 Instance tag - Searching for resources by tag
Parent topic: Tag Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
