Instance Management
Updated on 2024-11-06 GMT+08:00
Selecting an Instance
After an instance is created, select the instance before creating products and devices and setting other functions in the instance.
  1. Access the IoTDA service page and click Access Console.
  2. In the navigation pane, choose IoTDA Instances, and click the target instance card.
    Figure 1 Instance management - Changing instance
Viewing Instance Details
After purchasing an IoTDA instance, you can view the instance details in the instance details page, including the instance ID, name, and specifications.
  2. In the navigation pane, choose IoTDA Instances and click Details corresponding to an instance.
    Figure 2 Instance management - Instance details
Modifying Instance Specifications
You can upgrade the specifications of an IoTDA instance based on service requirements. Modifying instance specifications does not affect services.
  2. In the navigation pane, choose IoTDA Instances. Locate the target instance, click Modify, and select the new instance specifications.
  3. Set a delay for the change to take effect. After you set a maintenance window, the change will be performed in the scheduled time.
    Figure 3 Instance management - Modifying specifications
Unsubscribing from an Instance
If an instance is no longer required, you can choose More > Unsubscribe in the Operation column to release your cloud service resources. For details, see Unsubscriptions.
Figure 4 Instance management - Unsubscribing from an instance
