Audit Logs
Updated on 2024-04-29 GMT+08:00
After you enable CTS and the management tracker is created, CTS starts recording operations on cloud resources. After a data tracker is created, the system starts to record user operations on data in OBS buckets. CTS retains operation records of the latest seven days.
This section describes how to query and export operation records of the last seven days on the CTS console.
  • Traces of a single account can be viewed on the CTS console. Multi-account traces can be viewed only on the Trace List page of each account, or in the OBS bucket or the CTS/system log stream configured for the management tracker with the organization function enabled.
  • You can only query operation records of the last seven days on the CTS console. To store operation records for more than seven days, you must configure an OBS bucket to transfer records to it. Otherwise, you cannot query the operation records generated seven days ago.
  • After performing operations on the cloud, you can query management traces on the CTS console 1 minute later and query data traces on the CTS console 5 minutes later.
Viewing Real-Time Traces in the Trace List of the New Edition
  1. Log in to the console.
  2. Click in the upper left corner and choose Management & Governance > Cloud Trace Service.
  3. Choose Trace List in the navigation pane.
  4. On the Trace List page, use advanced search to query traces. You can combine one or more filters.
    • Trace Name: Enter a trace name.
    • Trace ID: Enter a trace ID.
    • Resource Name: Enter a resource name. If the cloud resource involved in the trace does not have a resource name or the corresponding API operation does not involve the resource name parameter, leave this field empty.
    • Resource ID: Enter a resource ID. Leave this field empty if the resource has no resource ID or if resource creation failed.
    • Trace Source: Select a cloud service name from the drop-down list.
    • Resource Type: Select a resource type from the drop-down list.
    • Operator: Select one or more operators from the drop-down list.
    • Trace Status: Select normal, warning, or incident.
      • normal: The operation succeeded.
      • warning: The operation failed.
      • incident: The operation caused a fault that is more serious than the operation failure, for example, causing other faults.
    • Time range: Select Last 1 hour, Last 1 day, or Last 1 week, or specify a custom time range.
  5. On the Trace List page, you can also export and refresh the trace list, and customize the list display settings.
    1. Enter any keyword in the search box and click to filter desired traces.
    2. Click Export to export all traces in the query result as an .xlsx file. The file can contain up to 5,000 records.
    3. Click to view the latest information about traces.
    4. Click to customize the information to be displayed in the trace list. If Auto wrapping is enabled (), excess text will move down to the next line; otherwise, the text will be truncated. By default, this function is disabled.
  6. For details about key fields in the trace structure, see Trace Structure and Example Traces.
  7. (Optional) On the Trace List page of the new edition, click Go to Old Edition in the upper right corner to switch to the Trace List page of the old edition.
Viewing Real-Time Traces in the Trace List of the Old Edition
  4. Each time you log in to the CTS console, the new edition is displayed by default. Click Go to Old Edition in the upper right corner to switch to the trace list of the old edition.
  5. Specify the filters used for querying traces. The following filters are available:
    • Trace Type, Trace Source, Resource Type, and Search By: Select a filter from the drop-down list.
      • If you select Resource ID for Search By, specify a resource ID.
      • If you select Trace name for Search By, specify a trace name.
      • If you select Resource name for Search By, specify a resource name.
    • Operator: Select a specific operator (a user other than an account).
    • Trace Status: Select All trace statuses, Normal, Warning, or Incident.
    • Time Range: You can query traces generated during any time range of the last seven days.
    • Click Export to export all traces in the query result as a CSV file. The file can contain up to 5,000 records.
  6. Click Query.
  7. On the Trace List page, you can also export and refresh the trace list.
    • Click to view the latest information about traces.
  8. Click on the left of a trace to expand its details.
  9. Click View Trace in the Operation column. The trace details are displayed.
  10. For details about key fields in the trace structure, see Trace Structure and Example Traces.
  11. (Optional) On the Trace List page of the old edition, click New Edition in the upper right corner to switch to the Trace List page of the new edition.
IoTDA Operations That Can Be Recorded by CTS
Using Cloud Trace Service (CTS), you can view user and platform operations and results. If an exception occurs, you can locate and rectify the fault based on the logs. The table below lists IoTDA operations that are logged.
Table 1 IoTDA operations that can be recorded by CTS
Category
Operation
Resource Type
Trace Name
Linkage rule management
Creating a rule
rules
createRules
Deleting a rule
rules
deleteRules
Updating a rule
rules
updateRules
Modifying the rule status
rules
changeRuleStatus
JavaScript script management
Uploading JavaScript plug-in scripts
scripts
createScript
Deleting JavaScript plug-in scripts
scripts
deleteScript
Debugging JavaScript plug-in scripts
scripts
runScript
Function plug-in management
Uploading a Function plug-in
functions
createProductFunctions
Deleting a Function plug-in
functions
deleteProductFunctions
Downloading a Function plug-in
functions
getProductFunctions
Batch task management
Creating a batch task
batchtasks
createBatchtasks
Retrying a batch task
batchtasks
retryBatchtasks
Stopping a batch task
batchtasks
stopBatchtasks
Deleting a batch task
batchtasks
deleteBatchtasks
Batch task file management
Uploading a batch task file
batchtask-files
uploadBatchTaskFile
Deleting a batch task file
batchtask-files
deleteBatchTaskFile
Export tasks
Creating an export task
export-tasks
createExportTasks
Deleting an export task
export-tasks
deleteExportTask
Downloading an export file
export-tasks
createTaskreport
Application certificate management
Uploading a push CA certificate
Certificate
createCertificate
Updating a push CA certificate
Certificate
updateCertificate
Deleting a push CA certificate
Certificate
deleteCertificate
Certificate management
Uploading a device CA certificate
certificate
addCertificate
Deleting a device CA certificate
certificate
deleteCertificate
Commissioning the device CA certificate
certificate
debugCertificate
Verifying a device CA certificate
certificate
verifyCertificate
Downloading a device CA certificate
certificate
downloadCertificate
Server certificate management
Creating a certificate for the enterprise edition
ServerCertificate
addServerCertificate
Replacing the certificate of the enterprise edition
ServerCertificate
updateServerCertificate
Deleting a certificate of the enterprise edition
ServerCertificate
deleteServerCertificate
Resource space management
Creating a resource space
application
addApplication
Deleting a resource space
application
deleteApplication
Modifying a resource space
application
updateApplication
Access code management
Creating an access code
accessCode
createAccessCode
Verifying an access code
accessCode
verifyAccessCode
Software/Firmware upgrade package management
Creating an OTA upgrade package
upgradeTask
uploadOtaPackages
Deleting an OTA upgrade package
upgradeTask
deleteOtaPackages
File storage and management
Configuring an OBS bucket for file upload.
upgradeTask
createBucket
Forwarding rule management
Creating a rule triggering condition
routing-rule
addRule
Modifying a rule triggering condition
routing-rule
modifyRule
Deleting a rule triggering condition
routing-rule
deleteRule
Testing the SQL connectivity
rule-sql
checkSql
Forwarding rule action management
Creating a rule action
rule-action
addAction
Modifying a rule action
rule-action
modifyAction
Deleting a rule action
rule-action
deleteAction
Testing the connectivity interface
rule-action
sendMessage
Outbound flow control policy management
Creating an outbound flow control policy
create-flow-control-policy
createRoutingFlowControlPolicy
Updating an outbound flow control policy
update-flow-control-policy
updateRoutingFlowControlPolicy
Deleting an outbound flow control policy
delete-flow-control-policy
deleteRoutingFlowControlPolicy
Outbound push stacking policy management
Creating an outbound push stacking policy
create-routing-backlog-policy
createRoutingBacklogPolicy
Modifying an outbound push stacking policy
update-routing-backlog-policy
updateRoutingBacklogPolicy
Deleting an outbound push stacking policy
delete-routing-backlog-policy
deleteRoutingBacklogPolicy
Device shadow
Configuring desired data in the device shadow
deviceShadow
updateDeviceShadow
Plug-in mapping management
Modifying the mapping
plugin
addMapping
Plug-in message management
Modifying message information
plugin
addMessage
Plug-in management
Deploying an online plug-in
plugin
deployPlugin
Saving plug-in information
plugin
savePluginMessage
Updating plug-in information
plugin
modifyPluginMessage
Deploying an offline plug-in
plugin
bundlePackages
Simulator management
Registering and debugging a device simulator
plugin
registerEmulatedDevice
Device debugging messages
Sending upstream code stream
plugin
simulateReport
Tunnel management
Creating a tunnel
tunnels
createTunnel
Deleting a tunnel
tunnels
deleteTunnel
Modifying a tunnel
tunnels
updateTunnel
Product management
Creating a product
product
addProduct
Modifying product information
product
updateProduct
Deleting a product
product
deleteProduct
Custom topic management
Modifying a custom topic
topic
updateTopic
Deleting a custom topic
topic
deleteTopic
Creating a custom topic
topic
addTopic
Exception detection configuration
Configuring the exception detection
productConfig
addProductConfig
AMQP queue management
Creating an AMQP queue
amqp
addQueue
Deleting an AMQP queue
amqp
deleteQueue
Terminating the receive-link consumption capability
amqp
hangUpConnection
Cloud interconnection configuration management
Creating cloud interconnection configurations
service-integration
addServiceIntegrationConfig
Deleting cloud interconnection configurations
service-integration
deleteServiceIntegrationConfig
Modifying cloud interconnection configurations
service-integration
modifyServiceIntegrationConfig
Group management
Adding a group
device-group
addDeviceGroup
Modifying a group
device-group
updateDeviceGroup
Deleting a group
device-group
deleteDeviceGroup
Managing devices in a group
device-group
manageDevicesInGroup
Device tag management
Binding a tag
tag
bindTagsToResource
Unbinding a tag
tag
unbindTagsToResource
Device management
Creating a device
device
addDevice
Modifying device information
device
updateDevice
Deleting a device
device
deleteDevice
Resetting a device secret
device
resetDeviceSecret
Freezing a device
device
freeze-device
Unfreezing a device
device
unfreeze-device
HarmonyOS soft bus
Creating a HarmonyOS soft bus
harmony-soft-bus
create-harmony-soft-bus
Deleting a HarmonyOS soft bus
harmony-soft-bus
delete-harmony-soft-bus
Resetting a HarmonyOS soft bus key
harmony-soft-bus
reset-harmony-soft-bus-key
Synchronizing a HarmonyOS soft bus
harmony-soft-bus
sync-harmony-soft-bus
Device proxy management
Deleting a device proxy
device-proxy
deleteDeviceProxy
Creating a device proxy
device-proxy
addDeviceProxy
Modifying a device proxy
device-proxy
updateDeviceProxy
Device policy management
Creating a device policy
device-policy
addDevicePolicy
Deleting a device policy
device-policy
deleteDevicePolicy
Updating a device policy
device-policy
updateDevicePolicy
Binding a device policy
device-policy
bindDevicePolicy
Unbinding a device policy
device-policy
unbindDevicePolicy
Message tracing management
Modifying message tracing configurations
message-trace
updateMessageTraceConfig
Deleting message tracing configurations
message-trace
deleteMessageTraceConfig
Deleting message tracing data
message-trace
deleteMessageTraceData
O&M configuration management
Modifying O&M configurations
device-config
updateDeviceConfig
Command management
Delivering a command
command
sendCommand
Delivering an asynchronous command
asyncCommand
sendAsyncCommand
Remote login
Creating an SSH channel
SshConnect
SshConnect
Delivering an SSH command
SshComand
SshComand
Disabling an SSH channel
SshDisconnect
SshDisconnect
