- What's New
- Product Bulletin
- Billing
Getting Started
Quick Device Access - Property Reporting and Command Receiving
- Subscribing to IoTDA
- Connecting a Smart Smoke Detector to the Platform (Quick Usage)
- Registering a Simulated Smart Street Light Device
- Using MQTT.fx to Simulate Communication Between the Smart Street Light and the Platform
- Using a Virtual Smart Street Light to Communicate with the Platform (Java SDK)
- Using a Virtual Smart Street Light to Communicate with the Platform (C SDK)
- Quick Device Access - Message Sending and Receiving
- Quick Application Access
User Guide
- Overview
- IoTDA Instances
- Resource Spaces
- Device Access
- Message Communications
- Device Management
Rules
- Overview
- Data Forwarding Process
- SQL Statements
- Connectivity Tests
- Data Forwarding to Huawei Cloud Services
- Data Forwarding to Third-Party Applications
- Data Forwarding Channel Details
- Data Forwarding Stack Policies
- Data Forwarding Flow Control Policies
- Abnormal Data Target
- Device Linkage
- Monitoring and O&M
- Granting Permissions Using IAM
Best Practices
- Introduction
Device Access
- Developing an MQTT-based Simulated Smart Street Light Online
- Developing a Smart Street Light Using NB-IoT BearPi
- Developing a Smart Smoke Detector Using NB-IoT BearPi
- Connecting and Debugging an NB-IoT Smart Street Light Using a Simulator
- Developing a Protocol Conversion Gateway for Access of Generic-Protocol Devices
- Connecting a Device That Uses the X.509 Certificate Based on MQTT.fx
- Connecting to IoTDA Based on the BearPi-HM_Nano Development Board and OpenHarmony 3.0
- Testing MQTT Performance Using JMeter
- Device Management
- Data Forwarding
- Device Linkage
Developer Guide
- Before You Start
- Obtaining Resources
- Product Development
- Development on the Device Side
- Development on the Application Side
API Reference
API Reference on the Application Side
- Before You Start
- Calling APIs
- API Overview
API
- Product Management
- Device Management
- Device Message
- Device Command APIs
- Device Property
- AMQP Queue Management
- Access Credential Management
- Data Forwarding Rule Management
Transition Data
- Push a Device Status Change Notification
- Push a Device Property Reporting Notification
- Push a Device Message Status Change Notification
- Push a Batch Task Status Change Notification
- Push a Device Message Reporting Notification
- Push a Device Addition Notification
- Push a Device Update Notification
- Push a Device Deletion Notification
- Push a Product Addition Notification
- Push a Product Update Notification
- Push a Product Deletion Notification
- Push an Asynchronous Device Command Status Change Notification
- Rule Management
- Device Shadow
- Group Management
- Tag Management
- Instance Management
- Resource Space Management
- Batch Task
- Device CA Certificate Management
- OTA Upgrade Package Management
- Message Broadcasting
- Device Tunnel Management
- Stack policy management
- Flow control policy management
- Device Proxy
- Device Policy Management
- Bridge Management
- Pre-provisioning Template Management
- Custom Authentication
- Codec Function Management
- Examples
- Appendix
MQTT or MQTTS API Reference on the Device Side
- Before You Start
- Communication Modes
- Topics
- Device Connection Authentication
- Device Commands
- Device Messages
- Device Properties
Gateway and Child Device Management
- Platform Notifying a Gateway of New Child Device Connection
- Platform Notifying a Gateway of Child Device Deletion
- Gateway Synchronizing Child Device Information
- Gateway Updating Child Device Status
- Responding to a Request for Updating Child Device Statuses
- Gateway Requesting for Adding Child Devices
- Platform Responding to a Request for Adding Child Devices
- Gateway Requesting for Deleting Child Devices
- Platform Responding to a Request for Deleting Child Devices
- Software and Firmware Upgrade
- File Upload and Download
- Device Time Synchronization
- Device Reporting Information
- Device Log Collection
- Remote Configuration
- HTTPS API Reference on the Device Side
- LwM2M API Reference on the Device Side
- Security Tunnel WebSocket API Reference
- Module AT Command Reference
- Change History
- SDK Reference
- Top FAQs
Solution Consulting
- In What Scenarios Can the IoT Platform Be Applied?
- What Are the Changes Brought by the Integration of IoT Device Management and IoTDA?
- Can I Enable IoTDA for IAM Users or Sub-Projects?
- Which Regions of Huawei Cloud Are Supported by the IoT Platform?
- Does Huawei Provide Modules, Hardware Devices, and Application Software?
- What Should I Do If I Want to Call an API But Have No Permissions to Do So as an IAM User? (Is It Edition-specific?)
- Why Was I Prompted to Grant Security Administrator Permissions When I Create a Rule or Set Resource File Storage?
- Which Resource Space Will Be Set As Default on the IoT Platform?
- How Does IoTDA Obtain Device Data?
- Is There Any Limitation on the Number of Resource Spaces and Devices I Can Add on the IoT Platform?
- Does the IoTDA Support Device Registration in Batches?
- Are There Any Limitations on the Use of the IoT Platform?
- What DTLS Encryption Algorithms Are Supported by the IoT Platform?
- Does the IoT Platform Support Conversion Between Big-Endian and Little-Endian for Binary Data?
- What Is NB-IoT?
- What Are the Components of the IoT Platform and What Hardware Architectures Does It Support?
- How Do I Obtain the Platform Access Address?
- Device Integration
- IoT Device SDKs
- LwM2M/CoAP Device Access
- MQTT-based Device Access
- Products Models
- Subscription and Push
- Codecs
- OTA Upgrades
- Application Integration
Show all
AMQP Server Configuration
This topic describes how to set and manage AMQP server subscription on the IoT platform.
- Access the IoTDA service page and click Access Console. Click the target instance card.
- In the navigation pane, choose Rules > Data Forwarding, and click Create Rule in the upper left corner.
- Set the parameters based on the table below and click Create Rule.
Table 1 Parameters for creating a rule Parameter
Rule Name
Name of the rule to be created.
Description of the rule.
Data Source
- Device: Device information, such as device addition, deletion, and update, will be forwarded. When Data Source is set to Device, quick configuration is not supported.
- Device property: A property value reported by a device in a resource space will be forwarded. Click Quick Configuration on the right and select the product, property, and service data to forward.
- Device message: A message reported by a device in a resource space will be forwarded. Click Quick Configuration on the right and select data of a specified topic to forward. Select the product to which the topic belongs and enter the topic name. You can use a custom topic on the product details page or a preset topic.
- Device message status: The status of device messages exchanged between the device and platform will be forwarded. For details on the device message status, see Message Delivery Status. When Data Source is set to Device message status, quick configuration is not supported.
- Device status: The status change of a directly or an indirectly connected device in a resource space will be forwarded. Click Quick Configuration on the right to forward information about devices whose status is Online, Offline, or Abnormal to other services. For details on the status of devices directly connected to the platform, see Device Management.
- Batch task: The batch task status will be forwarded. When Data Source is set to Batch Task, quick configuration is not supported.
- Product: Product information, such as product addition, deletion, and update, will be forwarded. When Data Source is set to Product, quick configuration is not supported.
- Asynchronous command status of the device: Status changes of asynchronous commands to devices using LwM2M over CoAP will be forwarded. For details on the asynchronous command status of devices, see Asynchronous Command Delivery. When Data Source is set to Asynchronous command status of the device, quick configuration is not supported.
- Run log: Service run logs of MQTT devices will be forwarded. When Data Source is set to Run log, quick configuration is not supported.
Trigger
After you select a data source, the platform automatically matches trigger events.
Resource Space
You can select a single resource space or all resource spaces. If All resource spaces is selected, quick configuration is not supported.
- Under Set Forwarding Target, click Add. On the displayed page, set the parameters based on the table below and click OK.
Forwarding Target
Select AMQP message queue.
Message Queue
Click Select to select a message queue.
- If no message queue is available, create one. The queue name must be unique under a tenant and can contain 8–128 characters, including letters, numbers, underscores (_), hyphens (-), periods (.), and colons (:).
- To delete a message queue, click Delete on the right of the message queue.
A subscribed queue cannot be deleted.
- After the rule is defined, click Enable Rule to start forwarding data to the AMQP message queue.
