Python SDK Access Example
This section describes how to use a Python 3 SDK to connect to the platform and receive subscribed messages from the platform based on AMQP.
Development Environment
Python 3.0 or later is required. In this example, Python 3.9 is used.
SDK Download
In this example, AMQP SDK python-qpid-proton (version 0.37.0) is used. You can run the following command to install the SDK of the latest version:
pip install python-qpid-proton
You can also manually install it by referring to Installing Qpid Proton.
Sample Code
import threading
import time
from proton import SSLDomain
from proton.handlers import MessagingHandler
from proton.reactor import Container
# Reconnection times
reconnectTimes = 0
def current_time_millis():
return str(int(round(time.time() * 1000)))
class AmqpClient(MessagingHandler):
def __init__(self, host, port, accessKey, accessCode, queueName, instanceId):
super(AmqpClient, self).__init__()
self.host = host
self.port = port
self.accessKey = accessKey
self.accessCode = accessCode
self.queueName = queueName
self.instanceId = instanceId
self.reconnectFlag = threading.local().flag = False
def on_start(self, event):
# Access domain name. For details, see "AMQP Client Access".
url = "amqps://%s:%s" % (self.host, self.port)
timestamp = current_time_millis()
userName = "accessKey=" + self.accessKey + "|timestamp=" + timestamp + "|instanceId=" + self.instanceId
passWord = self.accessCode
# By default, the server certificate is not verified.
sslDomain = SSLDomain(SSLDomain.MODE_CLIENT)
sslDomain.set_peer_authentication(SSLDomain.ANONYMOUS_PEER)
# Note: The reconnection mechanism has been implemented. The built-in reconnection of the client must be disabled (reconnect=False).
self.conn = event.container.connect(url, user=userName, password=passWord, heartbeat=60, ssl_domain=sslDomain,
reconnect=False)
event.container.create_receiver(self.conn, source=self.queueName)
# Called when the connection is established.
def on_connection_opened(self, event):
global reconnectTimes
reconnectTimes = 0
print("Connection established, remoteUrl: %s", event.connection.hostname)
# Called when the connection is cut off.
def on_connection_closed(self, event):
print("Connection closed: %s", self)
self.reconnect()
# Called when the remote end is disconnected due to an error.
def on_connection_error(self, event):
print("Connection error:%s", self)
self.reconnect()
# Called when the connection establishment handshake fails.
def on_transport_error(self, event):
print("Transport error:%s", self)
self.reconnect()
# Called when the socket is disconnected to cope with the scenario where the remote end cannot send error_condition when the network is abnormal.
def on_disconnected(self, event):
if self.reconnectFlag:
return
print("On disconnected")
if event.transport.condition:
if event.transport.condition.info:
print("Disconnected transport error:%s: %s: %s" % (
event.transport.condition.name, event.transport.condition.description,
event.transport.condition.info))
else:
print("Disconnected transport error:%s: %s" % (
event.transport.condition.name, event.transport.condition.description))
if event.connection.condition:
if event.connection.condition.info:
print("Disconnected connection error:%s: %s: %s" % (
event.connection.condition.name, event.connection.condition.description,
event.connection.condition.info))
else:
print("Disconnected connection error:%s: %s" % (
event.connection.condition.name, event.connection.condition.description))
self.reconnect()
def reconnect(self):
if not self.reconnectFlag:
self.reconnectFlag = True
ReconnectThread("reconnectThread").start()
# Called when a message is received.
def on_message(self, event):
message = event.message
content = message.body
print("receive message: content=%s" % content)
class ReconnectThread(threading.Thread):
def __init__(self, name):
threading.Thread.__init__(self)
self.name = name
def run(self):
global connecting
connecting = True
reconnectTimes = reconnectTimes + 1
time.sleep(15 if reconnectTimes > 15 else reconnectTimes)
Container(AmqpClient(amqpHost, amqpPort, amqpAccessKey, amqpAccessCode, amqpQueueName, instanceId)).run()
# For details about how to set the following parameters, see Connection Configuration.
# AMQP access domain name
amqpHost = "127.0.0.1"
# AMQP access port
amqpPort = 5671
# Access key
amqpAccessKey = 'your AccessKey'
# Access code
amqpAccessCode = 'your AccessCode'
# Name of the subscription queue
amqpQueueName = 'DefaultQueue'
# Instance ID. This parameter is mandatory when multiple instances of the standard edition are purchased in the same region.
instanceId = ''
Container(AmqpClient(amqpHost, amqpPort, amqpAccessKey, amqpAccessCode, amqpQueueName, instanceId)).run() What is your overall rating for this page?
