Configuring MFA Device Enforcement
You can determine whether IAM Identity Center users must have a registered MFA device when they log in to the user portal.
- Log in to the Huawei Cloud management console.
- Click
in the upper left corner of the page and choose Management & Governance > IAM Identity Center. - Choose Settings in the navigation pane.
- Click the Authentication tab.
- In MFA Device Enforcement, select one of the following options based on service requirements:
- Require them to bind an MFA device during login
Use this option when you want to require users who do not yet have a bound MFA device, to bind a device by themselves during login following a successful password authentication. For details, see Binding an MFA Device.
- Block their login
Use this option when you want to enforce MFA authentication for every login.
- Allow them to log in
Use this option when you do not require MFA authentication for user logins.
- Allow them to log in using the one-time password sent via email
Use this option when you want to send a verification code to a user by email.
Figure 1 Configuring MFA device enforcement
- Click Save.
