Help Center/ Distributed Message Service for RocketMQ/ User Guide/ Testing Instance Performance/ Testing Performance of RocketMQ 4.8.0 Instances (Basic Scenario)
Updated on 2026-09-10 GMT+08:00
This section describes the production and consumption performance test of different flavors of RocketMQ 4.8.0 instances. The test is performed when 1 KB messages are sent, synchronously produced and consumed, and many messages are stacked.
Test Environment
Do as follows to set up the test environment:
  1. Buy instances as shown in Table 1. For details about how to buy an instance, see Buying a RocketMQ Instance.
    Table 1 Instance parameters
    Name
    Flavor
    Brokers
    Storage Space
    ACL
    Public Access
    SSL
    rocketmq-01
    rocketmq.4u8g.cluster.small
    Ultra-high I/O 1,500 GB
    Enabled
    Disabled
    Disabled
    rocketmq-02
    Enabled
    Disabled
    Disabled
    rocketmq-03
    rocketmq.8u16g.cluster
    Enabled
    Disabled
    Disabled
    rocketmq-04
    rocketmq.12u24g.cluster
    Enabled
    Disabled
    Disabled
    rocketmq-05
    rocketmq.16u32g.cluster
    Enabled
    Disabled
    Disabled
  2. Create topics as shown in Table 2. For details about how to create topics, see Creating a RocketMQ Topic.
    Table 2 Topic parameters
    Name
    Permission
    Broker
    Queue
    topic-01
    Pub/Sub
    broker-0
    8
  3. Create a consumer group as shown in Table 3. For details about how to create a consumer group, see Creating a RocketMQ Consumer Group.
    Table 3 Consumer group parameters
    Name
    Broker
    Max. Retries
    Broadcast
    group-01
    broker-0
    16
    Disabled
  4. Create a user as shown in Table 4. For details, see Configuring RocketMQ ACL Users.
    Table 4 User parameters
    Name
    Administrator
    Default Topic Permissions
    Default Consumer Group Permissions
    Secret Key
    test
    Disabled
    Publish/Subscribe
    Subscribe
    Custom
  5. Buy a Linux ECS (with the same region, AZ, VPC, subnet, and security group as the RocketMQ instance). For details about how to purchase an ECS, see Purchasing a Custom ECS.
  6. Install Java JDK on the ECS and configure the environment variables JAVA_HOME and PATH.
    export JAVA_HOME=/root/jdk1.8.0_231
    export PATH=$JAVA_HOME/bin:$PATH
  7. Download the benchmark suite.
    wget https://dist.apache.org/repos/dist/release/rocketmq/5.1.4/rocketmq-all-5.1.4-bin-release.zip
  8. Decompress the benchmark suite.
    unzip rocketmq-all-5.1.4-bin-release.zip
Test Commands
Production command:
Run the following command in the benchmark folder:
sh producer.sh -n "${Connection address}" -t ${Topic name} -s ${Message size} -w ${Number of producer threads} -a true -ak ${ACL username} -sk ${ACL key}
In the preceding command, -a true indicates that ACL is enabled.
Table 5 Message production parameters
Example Value
Connection address
Connection address of a RocketMQ instance. Obtain the address from the Connection area on the Overview page of the instance.
192.168.111.182:8100;192.168.111.14:8100
Topic name
Name of a topic created in the RocketMQ instance, which is obtained from Table 2.
topic-01
Message size
The message size is custom.
The maximum message size supported by RocketMQ is 4 MB.
1024 (1 KB)
Number of producer threads.
128
ACL username
Name of the user. It can be obtained from Table 4.
test
ACL key
Key of the user. It can be obtained from Table 4.
XXXXXXXX
Run the following command with the values obtained in Table 5 to produce a message:
sh producer.sh -n "192.168.111.182:8100;192.168.111.14:8100" -t topic-01 -s 1024 -w 128 -a true -ak test -sk XXXXXXXX
Consumption command:
sh consumer.sh -n "${Connection address}" -t ${Topic name} -g ${Consumer group name} -a true -ak ${ACL username} -sk ${ACL key}
Table 6 Message consumption parameters
Example Value
Connection address
Topic name
topic-01
Consumer group name
Name of a consumer group created in the RocketMQ instance, which is obtained from Table 3.
group-01
ACL username
test
ACL key
XXXXXXXX
Run the following command with the values obtained in Table 6 to consume messages:
sh consumer.sh -n "192.168.111.182:8100;192.168.111.14:8100" -t topic-01 -g group-01 -a true -ak test -sk XXXXXXXX
  1. Start the production and consumption commands at the same time.
  2. Stop the consumption command 1 minute later and wait for at least 100 GB messages to be produced.
  3. Start the consumption command again to test the production and consumption performance in a cold read scenario.
Test Result Reference
The following performance data is of RocketMQ clusters tested based on the benchmark conditions (disk type: ultra-high I/O; message size: 1 KB; cold read scenario). The actual performance is affected by multiple factors including but not limited to the disk type, cold read, cold read concurrency, SSL encryption, ACL, message trace, cross-AZ, production concurrency, and queue traffic distribution. Therefore, you are advised to monitor instances by referring to Configuring RocketMQ Alarms and expand the capacity before the instance performance is insufficient due to service growth.
Table 7 Test result reference (basic scenario)
Metric
Message production rate
28,566 per second
31,644 per second
43,272 per second
44,934 per second
42,380 per second
Message consumption rate
99,826 per second
104,949 per second
210,195 per second
219,311 per second
197,813 per second
Inbound traffic
68 MB/s
75 MB/s
115 MB/s
109 MB/s
96 MB/s
Outbound traffic
240 MB/s
251 MB/s
460 MB/s
400 MB/s
371 MB/s
CPU usage
98%
97%
89%
89%
90%
Average load per CPU core
4.07
3.61
2.25
2.32
2.83
Memory usage
46%
44%
49%
49%
48%
