Wireless Network Configuration (SSH)
A HiLens Kit device can be connected to a router in wireless or wired mode. This section describes the wireless network configuration mode.
A router cannot be connected to a wired network and a wireless network at the same time. If you connect the router to a wireless network, the default gateway will be automatically deleted. If you connect the router to a wired network again, you need to configure the default gateway. You are advised to connect the router to a wireless network, in case you forget the device IP address after updating it.
If you select the wired network configuration mode, see Wired Network Configuration (SSH).
Configuration Requirements
To connect to a router through a wireless network, enter the network's password first.
Currently, HiLens Kit devices support only 2.4 GHz wireless networks with general encryption types. The name of a wireless network consists of 8 to 63 characters but cannot contain single or double English quotation marks.
- The 2.4 GHz wireless networks comply with IEEE802.11n, IEEE802.11g, and IEEE802.11b protocols.
- The supported wireless network encryption types include WEP, WPA-PSK/WPA2-PSK, and AES.
- Wireless networks that need to be verified are not supported.
- TKIP encryption is not supported.
- The IP address of the router gateway cannot be set to xxx.xxx.0.xxx, for example, 192.168.0.1. In addition, the router gateway and the HiLens Kit device cannot be in the same network segment. For example, if the device IP address is 192.168.2.111, the IP address of the router gateway cannot be set to 192.168.2.xxx.
- Use a network cable to connect the PC and the device. For details, see Connecting a HiLens Kit Device to a PC.
- Upgrade the HiLens Kit system firmware version. For details, see Upgrading the HiLens Kit System Firmware Version.
- Log in to the Huawei HiLens intelligent edge system using a browser on the local PC. Enter the address of the Huawei HiLens IES in the address box. The address format is "https://Huawei HiLens IES IP address". The default IP address is 192.168.2.111. Press Enter.
If "There is a problem with this website's security certificate" is displayed, click Continue to this website (not recommended).
- On the login page, enter login information.
Enter the username and password.
For details about the username and password, see .
- Choose Management > Network > Wired Network.
The Wired Network page is displayed.
- Under the Configure IP Address area, check whether the IP Address has a Default Gateway. See Figure 1.
- Choose Management > Network > Wireless Network.
The Wireless Network tab page is displayed.
- Click
to enable the Wi-Fi.
The system searches for the nearby Wi-Fi hotspots.
- Click
to refresh the hotspot information. - Click
The WIFI Connection dialog box is displayed.
- Enter the Wi-Fi password in the Password text box, as shown in Figure 2. Click OK.
Checking the IP Address of a Wireless Network
After a wireless network is configured, you can obtain its IP address from the Huawei HiLens intelligent edge system.
- In the upper right corner of the card of the wireless network you are connected to, click WIFI Detail.
The WIFI detail dialog box is displayed.
IP is the IP address of the wireless network.
Figure 3 Checking the IP address of a wireless network
Follow-up Operations
Register the HiLens Kit device. For details, see Registering a HiLens Kit Device via SSH.
