- Product Bulletin
User Guide
- Usage Overview
- Selecting HCE as the Public Image When Creating an ECS
- Changing an OS to HCE
- Migrating an OS
- Upgrading HCE and RPM Packages
- Security Updates for HCE
- Obtaining the openEuler Extended Software Packages
- Creating a Docker Image and Starting a Container
- Tools
- Kernel Functions and Interfaces
- xGPU
- Configuring the Repositories and Installing Software for HCE
- What Do I Do If CentOS Linux Is No Longer Maintained?
- Does Huawei Cloud Have a Migration Solution for CentOS?
- How Do I Install the MLNX Driver?
- How Do I Enable SELinux on an ECS Running HCE?
- How Do I Change the OS Name on the Console After the OS Is Migrated?
- How Are Huawei Cloud EulerOS, EulerOS, and openEuler Different from One Another?
- How Do I Enable WireGuard in Kernel and Install wireguard-tools?
- How Do I Save the User Credential Information for Logging In to Docker Like What Docker CE Does?
- What Is OOM? Why Does OOM Occur?
- How Do I Handle IPVS Errors?
- Why Can't HCE Obtain an IPv6 Address After IPv6 Is Enabled for an ECS?
- How Do I Set Auto Log Using TMOUT?
- Best Practices
Show all
Overview
OSMT is a tool provided by Huawei Cloud to upgrade or roll back HCE and RPM packages. It also allows you to customize the upgrade scope, configure scheduled checks, perform a single upgrade at the specified time period, and schedule restarts for RPM packages.
- To upgrade or roll back HCE, see Version Upgrade and Rollback.
- To update or roll back only RPM packages, see Updating RPM Packages.
OSMT can only upgrade or roll back HCE 2.0 or later. This tool periodically accesses the repository to obtain software update information, which will generate network traffic. You can run the systemctl stop osmt-agent command to stop this tool and run the systemctl disable osmt-agent command to disable automatic startup of this tool.
