- Product Bulletin
User Guide
- Usage Overview
- Selecting HCE as the Public Image When Creating an ECS
- Changing an OS to HCE
- Migrating an OS
- Upgrading HCE and RPM Packages
- Security Updates for HCE
- Obtaining the openEuler Extended Software Packages
- Creating a Docker Image and Starting a Container
- Tools
- Kernel Functions and Interfaces
- xGPU
- Configuring the Repositories and Installing Software for HCE
- What Do I Do If CentOS Linux Is No Longer Maintained?
- Does Huawei Cloud Have a Migration Solution for CentOS?
- How Do I Install the MLNX Driver?
- How Do I Enable SELinux on an ECS Running HCE?
- How Do I Change the OS Name on the Console After the OS Is Migrated?
- How Are Huawei Cloud EulerOS, EulerOS, and openEuler Different from One Another?
- How Do I Enable WireGuard in Kernel and Install wireguard-tools?
- How Do I Save the User Credential Information for Logging In to Docker Like What Docker CE Does?
- What Is OOM? Why Does OOM Occur?
- How Do I Handle IPVS Errors?
- Why Can't HCE Obtain an IPv6 Address After IPv6 Is Enabled for an ECS?
- How Do I Set Auto Log Using TMOUT?
- Best Practices
On this page
Show all
Help Center/
Huawei Cloud EulerOS/
User Guide/
Migrating an OS/
Migrating an OS to HCE 1.1/
- Only a CentOS 7.9 OS without a GUI installed can be migrated to HCE 1.1.
- During the OS migration, RPM packages need to be uninstalled, installed, and updated. As a result, the OS may restart unexpectedly. Back up the system disk before the OS migration. For details, see Creating a Cloud Server Backup.
- There should be at least 128 MB of available space in the memory and 1 GB on the system disk.
Parent topic: Migrating an OS to HCE 1.1
