Evaluating Software Compatibility
Scanning Methods
The x2hce-ca tool can:
- Scan a single application package or multiple application packages on the source OS.
- Scan all application packages in a given directory or multiple directories on the source OS.
- Log in and switch to user root.
- Scan the application packages to check for compatibility.
x2hce-ca scan <option> [-os_name Source OS name] [-target_os_name Target OS name]
Run the following command to verify the default Java version:
java -version
- If Java 1.8.0 has been installed on the target host, subsequent scanning is automatically performed.
- If Java 1.8.0 is not installed on the target host, perform the following operations (which vary depending on the OS):
- If the OS is HCE 2.0, the missing Java dependencies java-1.8.0-openjdk-devel, java-1.8.0-openjdk, and java-1.8.0-openjdk-headless will be installed automatically.
- If the OS is not HCE 2.0, an error message will be displayed to remind you to install the missing Java dependencies. Run the following command to install the Java dependencies:
- If the Java version on the target server is earlier than 1.8.0, run the following command and set the Java version to 1.8.0:
<option> has the following settings:
- Dir_Name/App_Name: scans a single application software package.
The following uses the x86 and Arm OS architectures as examples:
For example, if you want to scan application package NetworkManager-1.18.8-1.el7.x86_64.rpm (x86) in the /mnt/ directory, run the following command:
x2hce-ca scan /mnt/NetworkManager-1.18.8-1.el7.x86_64.rpm -os_name centos7.9 -target_os_name hce2.0
For example, if you want to scan application package NetworkManager-1.18.8-1.el7.aarch64.rpm (Arm) in the /mnt/ directory, run the following command:
x2hce-ca scan /mnt/NetworkManager-1.18.8-1.el7.aarch64.rpm -os_name EulerOSV2.0SP8arm -target_os_name hce2.0arm -arch aarch64
The default value of -arch is x86_64.
- Dir_Name1/App_Name1 Dir_Name2/App_Name2: scans multiple application software packages.
The following uses the x86 architecture as an example:
For example, if you want to scan the application software package grep-3.4-0.h3.r3.eulerosv2r9.x86_64.rpm in /opt/x2hce-ca/scan/ and the application software package groff-1.22.4-5.h1.eulerosv2r9.x86_64.rpm (x86) in /opt/x2hce-ca/scan/rpm/, run the following command:
x2hce-ca scan /opt/x2hce-ca/scan/grep-3.4-0.h3.r3.eulerosv2r9.x86_64.rpm /opt/x2hce-ca/scan/rpm/groff-1.22.4-5.h1.eulerosv2r9.x86_64.rpm -os_name centos7.9 -target_os_name hce2.0
- -b Dir_Name: scans all application packages in a single directory.
For example, if you want to scan all application packages in directory1, run the following command:
x2hce-ca scan -b directory1 -os_name centos7.9 -target_os_name hce2.0
- -b Dir_Name1 Dir_Name2: scans all application packages in multiple directories.
For example, if you want to scan all application packages in directory1 and directory2, run the following command:
x2hce-ca scan -b directory1 directory2 -os_name centos7.9 -target_os_name hce2.0
A single directory can contain a maximum of 750 files of up to 900 MB. Excessive software packages may cause tool failures.
- -l rpm_Name: scans a piece of locally installed software.
For example, to scan OpenSSL, run the following command:
x2hce-ca scan -l openssl -os_name centos7.9 -target_os_name hce2.0
- -l rpm_Name1,rpm_Name2...: scans more than one piece of locally installed software.
For example, to scan OpenSSH and OpenSSL, run the following command:
x2hce-ca scan -l openssl,openssh -os_name centos7.9 -target_os_name hce2.0
The -l parameter supports only CentOS.
Table 1 Type Parameter
Type
-os_name
String
Source OS.
This parameter is optional. The default value is centos7.9.
For example, if this parameter is set to centos8.2, CentOS 8.2 is selected as the source OS.
-target_os_name
String
Target OS.
This parameter is optional. The default value is hce2.0.
For example, if this parameter is set to -target_os_name hce1.1, the target OS is Huawei Cloud EulerOS 1.1.
- Analyze the evaluation results.
For example, after the x2hce-ca tool scans three RPM packages in the /tmp/x2hce-ca_test directory, it displays the following outputs.
Figure 1 Scan result- Download the compatibility evaluation reports from the /opt/x2hce-ca/output/software/ directory.
- If the software package is compatible with the target OS, the following message is displayed.
Figure 2 Evaluation result for software package compatibility
If the software package is not compatible with the target OS, the following message is displayed.
Figure 3 Evaluation result for software package incompatibility - For details about the compatible dependency packages and APIs, see the Excel file with the same name as the software package.
Figure 4 Dependency package compatibility and API compatibility
- If application packages fail the check, view the Excel report in the /opt/x2hce-ca/output/software/ directory.
