Updated on 2026-04-01 GMT+08:00
Installing x2hce-ca
  1. Confirm that the repository is configured correctly.
    Check whether the parameters in the /etc/yum.repos.d/hce.repo file are configured correctly. The correct configuration for HCE 2.0 is as follows:
    [base]
    name=HCE $releasever base
    baseurl=https://repo.huaweicloud.com/hce/$releasever/os/$basearch/
    enabled=1
    gpgcheck=1
    gpgkey=https://repo.huaweicloud.com/hce/$releasever/os/RPM-GPG-KEY-HCE-2
    [updates]
    name=HCE $releasever updates
    baseurl=https://repo.huaweicloud.com/hce/$releasever/updates/$basearch/
    enabled=1
    gpgcheck=1
    gpgkey=https://repo.huaweicloud.com/hce/$releasever/updates/RPM-GPG-KEY-HCE-2
    [debuginfo]
    name=HCE $releasever debuginfo
    baseurl=https://repo.huaweicloud.com/hce/$releasever/debuginfo/$basearch/
    enabled=0
    gpgcheck=1
    gpgkey=https://repo.huaweicloud.com/hce/$releasever/debuginfo/RPM-GPG-KEY-HCE-2
To install x2hce-ca on CentOS, you do not need to configure the repository. Download the latest x2hce-ca-hce from https://repo.huaweicloud.com/hce/2.0/updates/.
  1. Install x2hce-ca.
    Run yum install -y x2hce-ca-hce to install x2hce-ca. After the installation is complete, the directories listed in Table 1 will be generated.
    Table 1 Directories generated after x2hce-ca is installed
    Directory
    /var/log/x2hce-ca
    Stores log files of the x2hce-ca tool.
    /var/log/aparser
    Stores log files of the parser.
    /opt/x2hce-ca/output
    Stores the reports generated by the x2hce-ca tool.
    /opt/x2hce-ca/scan
    Stores the application software packages to be scanned.
    /etc/x2hce-ca/config
    Stores static configuration files.
    /etc/x2hce-ca/database_2.0.0.630
    Stores database files.
    /usr/local/x2hce-ca
    Stores program files.
    /usr/local/x2hce-python-3
    Python installation directory of the tool
    To install x2hce-ca on CentOS, run yum install -y x2hce-ca-hce-1.0.0-53.hce2.x86_64.rpm. Use the version of your downloaded x2hce-ca-hce.
  2. To make x2hce-ca take effect, perform operations as prompted after the installation is complete. Figure 1 is an example of the prompt, prompting you to run alias x2hce-ca="x2hce_python39 /usr/local/x2hce-ca/x2hce-ca.pyc" or restart the OS.
    Figure 1 Example prompt after the installation of x2hce-ca-hce
