Configuring a Function Component
Function flows support the function component. You can associate a created function with the component to meet service requirements.
Notes and Constraints
- Function flows created in Data Workroom (DWR) can only be viewed on the FunctionGraph console; editing and deletion must be done within DWR.
- The data returned by the configured function must be in JSON format. Otherwise, it cannot be parsed.
- Synchronous invocation does not support long-term running functions and is max. 15 minutes.
- Asynchronous invocation supports long-term running functions. The max. duration of a function node is the same as that supported by FunctionGraph.
- A flow can have zero to 99 functions.
- A function connected to an error handling node can be connected to another node that is not start or error handling.
- A function that is not connected to an error handling node can be connected to only one non-start node.
- You have created a function on the FunctionGraph console. For details, see Creating a Function from Scratch.
- Before using flows, learn about Expression Description and Operators.
Configuration Description
Parameter |
Description |
App |
App to which the desired function belongs. You can create multiple functions under an app. |
Function |
Function you want to use. |
Version |
Function version you want to use. |
CallMode |
Required when creating a standard flow. By default, function nodes in a flow are invoked synchronously. |
Function Parameters |
Key-value pairs passed for executing a function. Set constants, or obtain values from the input defined during function flow startup or the output of the former node using a JSONPath expression. To include sensitive information such as passwords, encrypt them first to prevent leakage. Parameters that will be passed in JSON format in the body. Key: parameter name Value: parameter value DefaultValue: used if no value is specified for the parameter Operation: to edit or delete the parameter |
Input Filter Expression |
JSONPath expression used to filter the input information of the node. |
Output Filter Expression |
JSONPath expression used to filter the output information of the node. |
Turn on StandbyOperation |
When enabled, the current node name cannot be the same as other function node names. |
Example
This section uses Python 3.9 to demonstrate function implementation. The code and function are shown below. For detailed instructions on creating functions, see Creating a Function from Scratch.
import json def handler (event, context): input = event.get('input',0) return { "result": input }
