Updated on 2026-08-24 GMT+08:00
Enabling or Disabling Functions
FunctionGraph supports enabling and disabling functions. Disabled functions cannot be invoked.
Notes and Constraints
- Only functions of the latest version can be disabled.
- Versions published based on the disabled latest version of a function are also disabled and can never be enabled.
- After disabling a function, you can modify its code but cannot execute the function.
Disabling a Function
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the name of the desired function.
- In the upper right corner of the function details page, click Disable Function. In the displayed dialog box, click Yes.
Enabling a Function
- Click the name of the disabled function.
- In the upper right corner of the function details page, click Enable Function.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
