Updated on 2026-08-24 GMT+08:00
Disk Mounting
This section describes how to mount a disk to a function on the FunctionGraph console to expand the storage space of the function.
FunctionGraph supports persistent storage by mounting file systems. Advantages:
  • Multiple functions can mount and share the same file system.
  • Existing storage capabilities of ECSs can be used to dynamically expand compute resources.
  • Compared with the temporary storage space /tmp, the function storage space can be greatly expanded.
The /tmp directory can store temporary files. The default size is 512 MB and the maximum size is 10,240 MB.
FunctionGraph supports the following file systems:
Table 1 Disk mounting
File System Type
SFS Turbo
SFS Turbo provides a fully hosted shared file storage that can be expandable to petabytes of capacity and provide sub-millisecond latency, up to tens of millions of IOPS, and hundreds of GB/s of bandwidth. It can provide high availability and durability for workloads dealing with massive small files and applications that require low latency and high IOPS. For details about SFS Turbo file systems, see SFS Turbo Service Overview.
The advantages of using SFS Turbo for function mounting are as follows:
  • Ephemeral files can be stored in the SFS Turbo file system. Their size will not be limited by instance local disk space.
  • Multiple functions can share an SFS Turbo file system.
General Purpose File System
Expandable to petabytes of capacity and terabytes of bandwidth, an SFS general-purpose file system provides fully hosted shared file storage. It features high availability and durability, and provides support for data-intensive and bandwidth-intensive applications. It supports large-scale data throughput and high-bandwidth workloads such as video transcoding and batch log analytics. For details about SFS general-purpose file systems, see SFS General Purpose File System.
ECS
A directory on an ECS is specified as a shared file system by using the network file system (NFS) service. Functions can mount the directory for read and write operations and dynamic scaling of compute resources. You can configure user permissions to manage shared data resources. It suitable for use cases that rely on existing ECS resources to rapidly enable lightweight data processing and file-sharing, particularly when such workloads occur only occasionally.
SFS Capacity-Oriented File System (Only for Existing Users)
Expandable to petabytes, SFS capacity-oriented file systems provide fully hosted shared file storage. It features high availability and durability, and provides support for data-intensive and bandwidth-intensive applications.
Notes and Constraints
  • Only existing users can mount SFS capacity-oriented file systems. The regions where each file system can be mounted are subject to the console.
  • Do not read or write data on disks in the initializer. Otherwise, the function cannot read data on disks.
  • Before disk mounting, the following file system ports must be enabled: 111, 445, 2049, 2051, 2052, and 20048.
    Another three ports must be enabled for Ubuntu. To obtain the port numbers, run the following command:
    rpcinfo -p|grep mountd|grep tcp
    For details, see What Resources Does SFS Occupy?
Table 2 Prerequisites for mounting a disk
File System Source
Mounting an SFS Turbo file system
  • You have created an SFS Turbo file system to be mounted. For details, see Creating a File System.
    You have recorded the VPC and subnet information used by the SFS Turbo file system.
  • You have created the agency required for mounting an SFS Turbo file system. For details, see Configuring Agency Permissions.
Mounting a General-Purpose File System
  • You have created an SFS general-purpose system to be mounted. For details, see Creating a File System.
    You have recorded the VPC and subnet information used by the SFS general-purpose file system.
  • You have created the agency required for mounting an SFS general-purpose file system. For details, see Configuring Agency Permissions.
Mounting an ECS shared directory
Mounting an SFS Capacity-Oriented File System (Only for Existing Users)
  1. Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
  2. Click the name of a function.
  3. Choose Configuration > Permissions to configure an agency for the function to access the SFS Turbo file system.
    1. Select the agency created in Prerequisites.
    2. Click Save.
  4. Choose Configuration > Network to configure the VPC for the function to access the SFS Turbo file system.
    1. Enable VPC Access.
    2. Set VPC and Subnet to the VPC and subnet recorded in Prerequisites.
    3. Click Save.
  5. Choose Configuration > File Systems.
  6. Click Mount File System. In the displayed dialog box, configure the SFS Turbo file system.
    Table 3 Parameters for mounting an SFS Turbo file system
    Example Value
    User ID
    User ID to be used for the function to access the specified file system. The value can be –1 (default) or an integer ranging from 1 to 65534, excluding 1000 and 1002. –1 indicates that the system automatically allocates the user ID.
    For SFS Turbo file systems, retain the default value –1.
    -1
    Group ID
    Group ID to be used for the function to access the specified file system. The value can be –1 (default) or an integer ranging from 1 to 65534, excluding 1000 and 1002. –1 indicates that the system automatically allocates the group ID.
    -1
    File System Type
    Select the type of the file system to be mounted. In this example, select SFS Turbo.
    SFS Turbo
    File System
    Select the SFS Turbo file system to be mounted.
    sfs-turbo-fg
    Shared Directory
    Specify the shared directory of the file system. The path must start with a slash (/), for example, /a.
    If this parameter is not set, the function can access all directories of the file system. If a specific directory path is configured, the function can access only the directory path.
    /a
    Access Path
    Specify the directory path used by the function to access files in the file system. The path must start with a slash (/) and contain a maximum of two levels. You are advised to set this parameter to a level-2 directory starting with /mnt or /home.
    The directory that already exists in the system cannot be used. Otherwise, the error message failed to mount exist system path is displayed.
    For example, the shared directory path is /a, with files /a/b and /a/c/d under it. If the function access path is /mnt/test, then the paths for the function to access file b and file d are /mnt/test/b and /mnt/test/c/d respectively.
    /mnt/test
  7. Click OK.
Currently, only the CN North-Ulanqab1 region supports mounting a general-purpose file system.
  3. Choose Configuration > Permissions to configure an agency for the function to access the SFS general-purpose file system.
    2. Click Save.
  4. Choose Configuration > Network to configure the VPC for the function to access the SFS general-purpose file system.
    3. Click Save.
  6. Click Mount File System. In the displayed dialog box, configure the SFS general-purpose file system.
    Table 4 Parameters for mounting an SFS general-purpose file system
    Example Value
    User ID
    -1
    Group ID
    -1
    File System Type
    Select the type of the file system to be mounted. In this example, select General purpose.
    General purpose
    File System
    Select the SFS general-purpose file system to be mounted.
    sfs-fg
    Access Path
    /mnt/test
  7. Click OK.
  3. Choose Configuration > Permissions to configure the agency for the function to access the ECS shared directory.
    2. Click Save.
  4. Choose Configuration > Network to configure the VPC for the function to access the ECS shared directory.
    3. Click Save.
  6. Click Mount File System. In the displayed dialog box, configure the ECS shared directory.
    Table 5 Parameters for mounting an ECS shared directory
    Example Value
    User ID
    • For ECSs on Windows, retain the default value –1.
    • For ECSs on Linux, use the system uid. For example, if the Linux username is test-user, you can run the id test-user command to query the uid and gid.
    -1
    Group ID
    • For ECSs on Linux, use the system gid. For example, if the Linux username is test-user, you can run the id test-user command to query the gid.
    -1
    File System Type
    Select the type of the file system to be mounted. In this example, select ECS, which indicates the ECS shared directory.
    ECS
    ECS
    Select the ECS to be mounted.
    ecs-fg
    Shared Directory
    Enter an existing directory path starting with a slash (/), for example, /a.
    If this parameter is not set, the function can access all directories in the file system.
    /a
    Access Path
    /mnt/test
  7. Click OK.
  3. Choose Configuration > Permissions to configure an agency for the function to access the SFS capacity-oriented file system.
    2. Click Save.
  4. Choose Configuration > File Systems.
  5. Click Mount File System. In the displayed dialog box, configure the SFS capacity-oriented file system.
    Table 6 Parameters for mounting an SFS capacity-oriented file system
    Example Value
    User ID
    For SFS capacity-oriented file systems, retain the default value –1.
    -1
    Group ID
    -1
    File System Type
    Select the type of the file system to be mounted. In this example, select SFS.
    SFS
    File System
    Select the name of the SFS capacity-oriented file system to be mounted.
    SFS-fg
    Shared Directory
    /a
    Access Path
    /mnt/test
  6. Click OK.
Creating an NFS Shared Directory on the ECS
Helpful Links
For details about the storage types supported by FunctionGraph, see Function Storage Selection.
