Configuring an Alarm Rule
After creating a function and trigger, you can monitor the invocation and running statuses of the function in real time.
Notes and Constraints
After a function is deleted, the alarm rules created for it will not be updated in real time on the Cloud Eye console and may continue to be displayed there for a maximum of seven days.
Viewing Function Metrics
FunctionGraph differentiates the metrics of a function by version, allowing you to query the metrics of a specific function version.
Create an alarm rule for a function to report metrics to Cloud Eye so that you can view monitoring graphs and alarm messages on the Cloud Eye console.
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the name of the desired function.
- On the displayed function details page, select a function version or alias, and choose Monitoring > Metrics.
- Click Create Alarm Rule.
- Set alarm parameters and click Next as shown in Figure 1.
- Enter a rule name and click OK.
