Updated on 2026-01-13 GMT+08:00
Extending Disk Partitions and File Systems (Windows)
After a disk is expanded on the console, the disk size is enlarged, but the disk partition and file system are not extended. You must log in to the server to extend the partition and file system before you can view and use the additional space. Specifically, you can add the additional space to an existing partition and file system or create a new partition and file system with the additional space.
This section describes how to extend partitions and file systems on a system or data disk in Windows. The extension operations may vary depending on the server OS.
  • Extending an Existing Partition
  • Creating a New Partition
  • The additional space of a data disk cannot be added to the root partition. To extend the root partition, expand the system disk instead.
  • During an expansion, the additional space is added to the end of the disk. If the disk has multiple partitions, the additional space can only be allocated to the last partition of the disk.
  • If the target partition is an extended MBR partition (whose partition number is usually greater than or equal to 5), you need to first expand the extended partition and then the logical partition. Assume that you have three partitions, /dev/vdb1 (primary partition), /dev/vdb2 (extended partition), and /dev/vdb5 (logical partition), you need to run growpart /dev/vdb2 and then growpart /dev/vdb5 to extend the partitions.
  • The maximum disk capacity that MBR supports is 2 TiB, and the disk space in excess of 2 TiB cannot be used. If your disk already uses MBR for partitioning and you require more than 2 TiB after the capacity expansion, do as follows:
    • (Recommended) Create a new EVS disk and use GPT.
    • Back up the disk data, perform the expansion, and then change the partition style from MBR to GPT. During this change, services will be interrupted and data on the disk will be erased.
Extending the Disk Partition and File System
When extending a partition, you can choose to extend an existing partition or create a new partition.
Originally, the D drive in the Windows Server 2019 has 60 GiB, and then 30 GiB is added to the disk. The following example shows how to allocate the additional 30 GiB to the D drive.
  1. Log in to the server.
    For how to log in to an ECS, see How Do I Log In to My ECS?
    For how to log in to a BMS, see Windows BMS Login Methods.
  2. Log in to the server. On the server desktop, right-click and choose Disk Management.
    The disk list is displayed. The Unallocated area shows the newly added disk space, which is not added to any partition or file system. Now we will perform the following steps to add the additional space to an existing partition and a file system.
    Figure 1 Disk expanded but additional space not allocated
    If you cannot see the additional space, right-click Disk Management and choose Refresh from the shortcut menu.
  3. On the Disk Management page, find the disk and volume that you want to extend. Check the size and unallocated space.
  4. Right-click the volume and choose Extend Volume from the shortcut menu. In this example, right-click New Volume (D:).
    Figure 2 Choosing Extend Volume
    On the displayed Extend Volume Wizard windows, click Next.
    Figure 3 Extend Volume Wizard
  5. In the text box to the right of Select the amount of space in MB, enter the amount of space you want to add and click Next. The default setting is used in this example.
    Figure 4 Selecting the amount of space you want to add
  6. Click Finish.
    After the extension succeeds, the volume size is greater than the original size.
    Figure 5 Extension succeeded
The following example shows you how to create a GPT partition with an NTFS file system on a server running Windows Server 2019.
  1. Log in to the server. On the server desktop, right-click and choose Disk Management. The disk list is displayed.
    • Disks are displayed in the right pane. If there is a disk that is not initialized, the system will prompt you with the Initialize Disk dialog box.
      Figure 6 Disk list
    • If the Initialize Disk dialog box is not prompted up and the disk has no partitions (entire disk shown as Unallocated), right-click the area where the to-be-initialized disk is and choose Initialize Disk from the shortcut menu.
      Figure 7 Initialize Disk
    • If the Initialize Disk dialog box is not prompted up but the disk has a partition (primary partition) and unallocated space, the disk has been expanded. Now you need to extend the partition and file system by either creating a new partition and file system with the additional space or adding the additional space to an existing partition and file system.
      • To create a new partition and file system, go to 2 and subsequent steps.
      • To allocate the additional space to an existing partition and file system, go to Extending an Existing Partition.
      Figure 8 Disk expanded but additional space not allocated
      If the disk is offline, you need to bring it online before initializing it.
  2. On the Initialize Disk dialog box, select GPT (GUID Partition Table) and click OK to go back to Computer Management.
    If your disk size is greater than 2 TiB or you plan to expand it to more than 2 TiB, select GPT (GUID Partition Table).
    Figure 9 Selecting GPT
  3. In the Unallocated area of Disk 1, right-click and choose New Simple Volume from the shortcut menu and initialize the disk as prompted.
    Figure 10 New Simple Volume
    1. On the Specify Volume Size page, retain the default settings and click Next.
      The system uses the maximum disk space as the default volume size. You can specify a volume size as needed.
      Figure 11 Specify Volume Size
    2. On the Assign Drive Letter or Path page, retain the default settings and click Next.
      Figure 12 Assign Drive Letter or Path
    3. On the Format Partition page, retain the default settings and click Next.
      The default file system format is NTFS. You can set other parameters based on your need.
      Figure 13 Format Partition
      The partition sizes supported by file systems vary. Choose an appropriate file system format based on your service requirements.
    4. On the Completing the New Simple Volume Wizard page, click Finish.
      Wait for the initialization to complete. When the volume status changes to Healthy, the initialization has succeeded.
      Figure 14 Completing the New Simple Volume Wizard
      Figure 15 Viewing the initialization results
  4. (Optional) Alternatively, choose Server Manager > File and Storage Services > Volumes > Disks to view the disk status, capacity, and partition style.
  5. After the volume is created, click on the task bar and check whether a new volume appears in the File Explorer. In this example, New Volume (D:) is the new volume.
    If New Volume (D:) appears, the disk is successfully initialized and no further action is required.
    Figure 16 File Explorer
Related Operations
  1. In the Disk 1 area, right-click and choose Online from the shortcut menu.
    Figure 17 Online
    When the status of Disk 1 changes from Offline to Not Initialized, the disk has been brought online.
    Figure 18 Disk brought online
Related Links
