Updated on 2026-02-13 GMT+08:00
Extending Disk Partitions and File Systems (Linux)
After a disk is expanded on the console, the disk size is enlarged, but the disk partition and file system are not extended. You must log in to the server to extend the partition and file system before you can view and use the additional space. Specifically, you can add the additional space to an existing partition and file system or create a new partition and file system with the additional space.
This section describes how to extend partitions and file systems on a system or data disk in Linux. The extension operations may vary depending on the server OS.
Table 1 Operation instructions of extending partitions and file systems in Linux
Partition Style
Disk Function
OS Requirements
File System Format
Tool
Example Configuration
Extending an Existing Partition
GPT or MBR
System disk
Data disk
  • To extend partitions and file systems of a system disk, the kernel version must be later than 3.6.0.
  • To extend partitions and file systems of a data disk, there are no requirements on the OS version.
ext* (such as ext2, ext3, and ext4), xfs, and btrfs
growpart
  • Device name: /dev/vdb
  • Existing partition: /dev/vdb1
  • Space added: 50 GiB
Extending an Existing MBR Partition (for System Disks Whose Kernel Version Is Earlier Than 3.6.0)
MBR
System disk
The kernel version is earlier than 3.6.0.
dracut-modules-growroot
  • Device name: /dev/vda
  • File system format: ext4
  • Mount point: /mnt/sda
  • Partition name: /dev/vda1
  • Space added: 60 GiB
  • Partition style: MBR
Creating a New MBR Partition
MBR
System disk
Data disk
None
  • fdisk
  • parted
  • Mount points: /mnt/sdc and /mnt/sdd
  • Partition 1: /dev/vdb1
    • Size: 100 GiB
  • Partition 2: /dev/vdb2
    • Size: 50 GiB
Creating a New GPT Partition
GPT
Data disk
None
parted
    • Size: 2 TiB
    • Partition style: GPT
    • Size: 1 TiB
Extending a Logical Volume
If you use Logical Volume Manager (LVM) to manage EVS disks, you can extend logical volumes when the capacity fails to meet your requirements.
Extending the File System of an Unpartitioned Data Disk in Linux
If no partition but only a file system is created on a data disk, you can directly extend the file system.
Increasing the Size of the Root Partition of a BMS That Is Quickly Provisioned
If the root partition of a quickly provisioned BMS is too small, you can extend the size of the root partition.
You can run uname -a to check the Linux kernel version.
  • The additional space of a data disk cannot be added to the root partition. To extend the root partition, expand the system disk instead.
  • During an expansion, the additional space is added to the end of the disk. If the disk has multiple partitions, the additional space can only be allocated to the last partition of the disk.
  • If the target partition is an extended MBR partition (whose partition number is usually greater than or equal to 5), you need to first expand the extended partition and then the logical partition. Assume that you have three partitions, /dev/vdb1 (primary partition), /dev/vdb2 (extended partition), and /dev/vdb5 (logical partition), you need to run growpart /dev/vdb2 and then growpart /dev/vdb5 to extend the partitions.
  • The maximum disk capacity that MBR supports is 2 TiB, and the disk space in excess of 2 TiB cannot be used. If your disk already uses MBR for partitioning and you require more than 2 TiB after the capacity expansion, do as follows:
    • (Recommended) Create a new EVS disk and use GPT.
    • Back up the disk data, perform the expansion, and then change the partition style from MBR to GPT. During this change, services will be interrupted and data on the disk will be erased.
Extending the Disk Partition and File System
When extending a partition, you can choose to extend an existing partition or create a new partition. To check the current disk partition style, run the parted<disk-name> command.
Originally, data disk /dev/vdb has 100 GiB and one partition /dev/vdb1. Then, the data disk is expanded to 150 GiB. The following example shows how to allocate the additional 50 GiB to the existing /dev/vdb1 partition.
  1. Log in to the server as user root.
    For how to log in to an ECS, see How Do I Log In to My ECS?
    For how to log in to a BMS, see Linux BMS Login Methods.
  2. Check the capacity expansion tool and current disk information.
    1. Check whether the growpart expansion tool is installed.
      growpart
      • If the tool instructions are returned, the tool has been installed, and you do not need to install it again.
        [root@ecs-centos76 ~]# growpart
        growpart disk partition
          rewrite partition table so that partition takes up all the space it can
          options:
          -h | --help	        print Usage and exit
               --fudge F        if part could be resized, but change would be
                                less than 'F' bytes, do not resize (default: 1048576)
          -N | --dry-run        only report what would be done, show new 'sfdisk -d'
          -v | --verbose	increase verbosity / debug
          -u | --update R	update the the kernel partition table info after growing
                                this requires kernel support and 'partx --update'
                                R is one of:
                                - 'auto': [default] update partition if possible
                                - 'force' : try despite- sanity checks (fail on failure)
                                - 'off' : do not attempt
                                - 'on'	: fail if sanity checks indicate no support
          Example:
          - growpart /dev/sda 1
            Resize partition 1 on /dev/sda
        must supply disk and part it ion-number
        [root@ecs-centos76 ~l#
        • If error message "Read-only file system" is returned, run mount -o remount,rw / to change the file system permissions to read/write.
        • If your OS does not allow using online resizing tools (such as growpart and resize2fs) to extend mounted partitions, you can unmount the partitions first and then extend them offline. For details, see Extending Partitions and File Systems Offline (Linux Data Disk).
      • If no tool instructions are returned, run the following command to install the tool:
        yum install cloud-utils-growpart
        Loaded plugins: fastestmirror
        Determining fastest mirrors
        epel/x86_64/metalink
        | 8.0 kB  00:00:00
        Package cloud-utils-growpart-0.29-2.el7.noarch already installed and latest version
        Nothing to do
        The installation is successful.
    2. Check the partitions of the /dev/vdb disk.
      lsblk
      [root@ecs-centos76 ~]# lsblk
      NAME   MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
      vda    253:0    0  40G  0 disk
      ├vda1 253:1    0  40G  0 part /
      vdb    253:16   0  150G 0 disk
      ├vdb1 253:17   0  100G 0 part /mnt/sdc
      We can see that /dev/vdb has 150 GiB, the /dev/vdb1 partition has 100 GiB, and the additional 50 GiB space is not allocated.
      If the disk is not partitioned, you need to directly extend the file system, go to 4.
  3. Add the additional space to the /dev/vdb1 partition that already exists.
    growpart /dev/vdb 1
    [root@ecs-test-0001 ~]# growpart /dev/vdb 1
    CHANGED: partition=1 start=2048 old: size=209713152 end=209715200 new: size=314570719,end=314572767
    • Command line structure: growpart<disk-partition> <partition-number>. Note that there is a space in front of the partition number.
    • If the following command output is displayed:
      no tools available to resize disk with 'gpt'
      FAILED: failed to get a resizer for id ''
      The disk uses the GPT partition style, and the gdisk tool is required when you use growpart to add the additional space. In this case, run yum install gdisk, enter y to install gdisk, and then run the preceding growpart command.
      growpart /dev/vda 1 unexpected output in sfdisk --version [sfdisk is from util-linux 2.23.2]
      Check whether the system character set (language environment) is en_US.UTF-8. If not, run export LC_ALL=en_US.UTF-8.
    • If error message "NOCHANGE:partition 1 is size xxxxxxx. it cannot be grown" or "No space left on the block device" is returned, the expansion may be failed because the server disk is full (at 100% usage). Back up the disk data and clear unnecessary files or programs.
  4. Extend the file system of the /dev/vdb1 partition.
    1. Check the file system format of the /dev/vdb1 partition.
      parted /dev/vdb
      P
      [root@ecs-centos74 ~]# parted /dev/vdb
      GNU Parted 3.1
      Using /dev/vdb
      Welcome to GNU Parted! Type 'help' to view a list of commands.
      (parted) p
      Model: Virtio Block Device (virtblk)
      Disk /dev/vdb: 107GB
      Sector size (logical/physical): 512B/512B
      Partition Table: gpt
      Disk Flags:
      Number  Start   End    Size     File system    Name       Flags
       1      1049KB  107GB  107GB    ext4           /dev/vdb1
      (parted)
      Partition Table shows the partition style, which is GPT in this example. File system shows the file system format, which is ext4 in this example.
      Enter q and press Enter to exit parted.
      • If Partition Table: msdos is returned, the partition style is MBR.
      • If Partition Table: gpt is returned, the partition style is GPT.
      • If Partition Table: loop is returned, the disk is not partitioned (the entire disk is partitioned into one partition), and only a file system is created.
    1. As the file system format of /dev/vdb1 is ext4, run the following command to extend the file system:
      resize2fs /dev/vdb1
      [root@ecs-test-0001 ~]# resize2fs /dev/vdb1
      resize2fs 1.42.9 (28-Dec-2013)
      Filesystem at /dev/vdb1 is mounted on /mnt/sdc; on-line resizing required
      old_desc_blocks = 13, new_desc_blocks = 19
      The filesystem on /dev/vdb1 is now 39321339 blocks long.
      • Command line structure: resize2fs<disk-partition>
      • If the error message "open: No such file or directory while opening /dev/vdb1" is returned, an incorrect partition is specified. Run parted to view disk partitions.
      • If the file system format is xfs, run the following command (/mnt/sdc is the mount point of /dev/vdb1. Change it based on your actual conditions):
        sudoxfs_growfs /mnt/sdc
        [root@ecs-test-0001 ~]# sudo xfs_growfs /mnt/sdc
        meta-data=/dev/vdb1              isize=512    agcount=4, agsize=6553536 blks
                 =                       sectsz=512   attr=2, projid32bit=1
                 =                       crc=1        finobt=0 spinodes=0
        data     =                       bsize=4096   blocks=26214144, imaxpct=25
                 =                       sunit=0      swidth=0 blks
        naming   =version 2              bsize=4096   ascii-ci=0 ftype=1
        log      =internal               bsize=4096   blocks=12799, version=2
                 =                       sectsz=512   sunit=0 blks, lazy-count=1
        realtime =none                   extsz=4096   blocks=0, rtextents=0
        data blocks changed from 26214144 to 39321339
  5. Check the partition size after extension.
    lsblk
    ├vdb1 253:17   0  150G 0 part /mnt/sdc
    We can see that the /dev/vdb data disk now has 150 GiB and the /dev/vdb1 partition has 150 GiB, meaning that the extension operation is successful.
  6. (Optional) If you are expanding a data disk whose OS kernel version is earlier than 3.6.0, after the extension operation is complete, you need to run reboot to make the additional space available for use.
    Restarting the OS will interrupt services. To prevent any data loss after the restart, ensure that you have backed up the disk data before the restart. To back up data using CBR, see Backing Up EVS Disks. To back up data using snapshots, see Creating an EVS Snapshot.
Originally, system disk /dev/vda has 40 GiB and one partition /dev/vda1. Then, the disk is expanded to 100 GiB. The following example shows how to allocate the additional 60 GiB to the existing /dev/vda1 partition.
  • If the OS kernel version is earlier than 3.6.0, you need to reboot the system after extending an existing MBR partition to make the additional space available. During the reboot, services will be interrupted. After the reboot, the additional space is automatically added to the last partition of the system disk.
  • If your OS kernel version is earlier than 3.6.0 and you want to create a new partition with the additional space, see Creating a New MBR Partition.
  2. (Optional) Install the dracut-modules-growroot tool.
    yum install dracut-modules-growroot
    [root@ecs-test-0002 ~]# yum install dracut-modules-growroot
    Loaded plugins: fastestmirror, security
    Setting up Install Process
    Loading mirror speeds from cached hostfile
    epel/metalink        | 4.3 kB     00:00
     * epel: pubmirror1.math.uh.edu
    base        | 3.7 kB     00:00
    extras        | 3.4 kB     00:00
    updates        | 3.4 kB     00:00
    Package dracut-modules-growroot-0.20-2.el6.noarch already installed and latest version
    Nothing to do
    Skip this step if the tool is already installed.
  3. Regenerate the initramfs file.
    dracut -f
    The initramfs file helps the Linux kernel to access drivers on external storage devices.
  4. Check the information of the /dev/vda disk.
    lsblk
    [root@ecs-test-0002 ~]# lsblk
    vda    253:0    0 100G  0 disk
    vdb    253:16   0 100G  0 disk
    We can see that the /dev/vda system disk has the /dev/vda1 partition, then the disk is expanded to 100 GiB, and the additional space is not allocated. So, /dev/vda has 100 GiB, and /dev/vda1 has 40 GiB.
  5. Restart the server.
    reboot
    Reconnect to the server after it is restarted.
  6. Check the information of the /dev/vda disk.
    lsblk
    ├vda1 253:1    0 100G  0 part /
    We can now see that /dev/vda has 100 GiB and /dev/vda1 also has 100 GiB.
Originally, data disk /dev/vdb has 100 GiB and one partition /dev/vdb1, and then the disk is expanded to 150 GiB. The following example shows you how to use fdisk to allocate the additional 50 GiB to a new partition (/dev/vdb2).
  2. Check the information of the /dev/vdb disk.
    1. Check disk partition sizes.
      lsblk
      [root@ecs-test-0001 ~]# lsblk
      └vda1 253:1    0   40G  0 part /
      └vdb1 253:17   0  100G  0 part /mnt/sdc
      We can see that the /dev/vdb data disk has the /dev/vdb1 partition, then 50 GiB is added to the disk, and the additional 50 GiB is not allocated. So, /dev/vdb has 150 GiB, and /dev/vdb1 has 100 GiB.
    1. Check the disk partition style.
      parted /dev/vdb
      p
      [root@ecs-test-0001 ~]# parted /dev/vdb
      GNU Parted 3.1
      Using /dev/vdb
      (parted) p
      Disk /dev/vdb: 161GiB
      Disk Flags:
       1      1049kB  107GiB 107GiB ext4         /dev/vdb1
      (parted)
      In this example, the disk uses MBR.
  3. Use the additional space to create a second primary partition /dev/vdb2 on the /dev/vdb disk.
    1. Create the partition.
      fdisk /dev/vdb
      n
      p
      [root@ecs-test-0001 ~]# fdisk /dev/vdb
      Welcome to fdisk (util-linux 2.23.2).
      Changes will remain in memory only, until you decide to write them.
      Be careful before using the write command.
      Device does not contain a recognized partition table
      Building a new DOS disklabel with disk identifier 0x38717fc1.
      Command (m for help): n
      Partition type:
         p   primary (0 primary, 0 extended, 4 free)
         e   extended
      Select (default p): p
      Partition number (2-4, default 2):
    Partition type shows that there are two types of partitions. Choosing p creates a primary partition and choosing e creates an extended partition.
    Partition number indicates the serial number of the primary partition. Because partition number 1 has been used, the value ranges from 2 to 4.
    MBR partitions include primary partitions and extended partitions. A maximum of four primary partitions are supported. If you need more partitions, create one extended partition. The number of logical partitions allowed in the extended partition is not limited, so theoretically you can create as many logical partitions as you want. If you need five or more partitions, use the "primary partitions + one extended partition" model and then create logical partitions in the extended partition.
    1. Enter 2 as the primary partition number and view the first sector range.
      Partition number (2-4, default 2): 2
      First sector (83886080-209715199, default 83886080):
      First sector shows the first sector range. The value ranges from 83886080 to 209715199, and the default value is 83886080.
    2. Press Enter to use the default first sector and then press Enter to use the default last sector.
      using default value 83886080
      Last sector, +sectors or +size{K,M,G} (83886080-209715199, default 209715199):
      using default value 209715199
      Partition 2 of type Linux and of size 40 GB is set
      Last sector shows the last sector range. The value ranges from 83886080 to 209715199, and the default value is 209715199.
      If you want to create two or more partitions, calculate the first and last sectors of the partitions as follows:
      Assume that the /dev/vdb data disk has 100 GiB, and you are going to partition it into two primary partitions, first primary partition /dev/vdb1 (40 GiB) and second primary partition /dev/vdb2 (60 GiB). For how to calculate the sector values, see Table 2.
      Table 2 First and last sectors in this example are calculated as follows
      Sector
      /dev/vdb1 (40 GiB)
      /dev/vdb2 (60 GiB)
      Formula for Calculating the Value of sectors
      First sector
      2048 (The first sector of the /dev/vdb data disk is used.)
      Last sector of /dev/vdb1 + 1
      =83886079 + 1
      =83886080
      Value of sectors
      =Capacity × 1073741824/512
      Last sector
      Value of sectors – 1
      =(40 × 1073741824/512) – 1
      =83886079
      First sector + Value of sectors – 1
      =83886080 + (60 × 1073741824/512) – 1
      =209715199
  4. Check the size and partition style of the new partition.
    1. Enter p and press Enter to print details of the /dev/vdb2 partition.
      Command (m for help): p
      Disk /dev/vdb: 107.4 GB, 107374182400 bytes, 209715200 sectors
      Units = sectors of 1 * 512 = 512 bytes
      Sector size (logical/physical): 512 bytes / 512 bytes
      I/O size (minimum/optimal): 512 bytes / 512 bytes
      Disk label type: dos
      Disk identifier: 0x994727e5
         Device Boot       Start         End      Blocks   Id  System
      /dev/vdb1             2048    83886079    41942016   83  Linux
      /dev/vdb2         83886080   209715199    62914560   83  Linux
    2. Enter w and press Enter to write the changes to the partition table.
      In case that you want to discard the changes made before, you can exit fdisk by entering q and press Enter. Then, re-create the partition.
    3. Synchronize the new partition table to the OS.
      partprobe
  1. Create an ext4 file system on the /dev/vdb2 partition.
    mkfs -t ext4 /dev/vdb2
    • mkfs-t<file-system-format><disk-partition-name>: To create an xfs file system, the command is mkfs -t xfs<disk-partition-name>. To create a btrfs file system, the command is mkfs -t btrfs<disk-partition-name>.
    • It takes some time to create file systems. Do not exit before the system returns the following information:
    [root@ecs-test-0001 ~]# mkfs -t ext4 /dev/vdb2
    mke2fs 1.42.9 (28-Dec-2013)
    Filesystem label=
    OS type: Linux
    Block size=4096 (log=2)
    Fragment size=4096 (log=2)
    Stride=0 blocks, Stripe width=0 blocks
    2621440 inodes, 10485504 blocks
    524275 blocks (5.00%) reserved for the super user
    First data block=0
    Maximum filesystem blocks=2157969408
    320 block groups
    32768 blocks per group, 32768 fragments per group
    8192 inodes per group
    Superblock backups stored on blocks:
            32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
            4096000, 7962624
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (32768 blocks): done
    Writing superblocks and filesystem accounting information: done
    Run parted /dev/vdb and enter p to check the file system format.
    GNU Parted 3.1
    Using /dev/vdb
    (parted) p
    Disk /dev/vdb: 107GiB
    Disk Flags:
    Number  Start   End      Size     Type     File system  Flags
     1      1049kB  42.9GB   42.9GB   primary  ext4
     2      42.9GB  107GB    64.4GB   primary  ext4
    (parted) q
    An ext4 file system is created for the /dev/vdb2 partition.
  2. Create a directory (mount point) and mount the new partition on the created mount point.
    mkdir -p /mnt/sdd
    mount /dev/vdb2 /mnt/sdd
    lsblk
    View the mount results.
    ├vdb2 253:18   0  50G  0 part /mnt/sdd
    You should now see that partition /dev/vdb2 is mounted on /mnt/sdd.
  3. Use the partition UUID to configure auto mount at startup.
    • If device names are used to identify disks in the /etc/fstab file, your server may fail to run after reboot. This is because device names are assigned dynamically and may change (for example, from /dev/vdb1 to /dev/vdb2) after a server stop or start.
    • UUIDs are the unique character strings for identifying partitions in Linux.
    1. Query the UUID of the /dev/vdb2 partition.
      blkid /dev/vdb2
      [root@ecs-test-0001 ~]# blkid /dev/vdb2
      /dev/vdb2: UUID="0b3040e2-1367-4abb-841d-ddb0b92693df" TYPE="ext4"
      Take note of the partition UUID, which will be used in the next step. In this example, the UUID of the /dev/vdb2 partition is 0b3040e2-1367-4abb-841d-ddb0b92693df.
    2. Configure auto mount at startup.
      vi /etc/fstab
      Press i to enter editing mode, move the cursor to the end of the file, press Enter, and add the partition information.
      UUID=0b3040e2-1367-4abb-841d-ddb0b92693df    /mnt/sdd     ext4    defaults     0    2
      Press Esc, enter :wq, and press Enter to save the settings and exit the vi editor.
      Table 3 Content description
      Example Value
      The UUID of the partition.
      /mnt/sdc
      The mount point of the partition.
      ext4
      The file system format of the partition.
      defaults
      The partition mount option. Normally, this parameter is set to defaults.
      0
      • The Linux dump backup option.
        • 0: Linux dump backup is not used. Usually, dump backup is not used, and you can set this parameter to 0.
        • 1: Linux dump backup is used.
      2
      • The fsck option, which means whether to use fsck to check the disk during startup.
        • 2: The check starts from the partitions whose mount points are non-root directories. / is the root directory.
        • 1: The check starts from the partitions whose mount points are root directories.
        • 0: The fsck option is not used.
  4. Verify that auto mount takes effect.
    You can restart the server to check whether auto mount takes effect. Alternatively, you can perform the following steps to simulate auto mount.
    1. To verify auto mount, unmount the partition first.
    umount /dev/vdb2
    1. Reload all the content in the /etc/fstab file. /etc/fstab is a static file system table that contains the list of file systems that need to be automatically mounted during system startup.
    mount -a
    The system reloads all the content in the /etc/fstab file.
    1. Query the file system mount information.
    mount|grep/mnt/sdd
    If information similar to the following is displayed, auto mount has taken effect:
    root@ecs-test-0001 ~]# mount | grep /mnt/sdd
    /dev/vdb2 on /mnt/sdd type ext4 (rw,relatime,data=ordered)
Originally, data disk /dev/vdb has 2 TiB and one partition /dev/vdb1, and then the disk is expanded to 3 TiB. The following example shows you how to use parted to allocate the additional 1 TiB to a new GPT partition (/dev/vdb2).
      lsblk
      vdb    253:16   0  3T  0 disk
      └vdb1 253:17   0  2T  0 part /mnt/sdc
      We can see that the /dev/vdb data disk has the /dev/vdb1 partition, then 1 TiB is added to the disk, and the additional space is not allocated. So, /dev/vdb has 3 TiB, and /dev/vdb1 has 2 TiB.
      parted /dev/vdb
      p
      GNU Parted 3.1
      Using /dev/vdb
      (parted) p
      Disk /dev/vdb: 3299GB
      Disk Flags:
       1      1049kB  2199GB 2199GB ext4         /dev/vdb1
      (parted)
      In this example, the disk uses GPT.
  3. Create a new partition /dev/vdb2 on the /dev/vdb disk.
    1. Create the /dev/vdb2 partition.
      parted /dev/vdb
      unit s
      p
      GNU Parted 3.1
      Using /dev/vdb
      (parted) unit s
      (parted) p
      Disk /dev/vdb: 6442450944s
      Disk Flags:
       1      2048s     4294965247s   4294963200s   ext4           /dev/vdb1
      (parted)
      Take note of the last sector, which will be used in the next step. In this example, the last sector of the /dev/vdb1 partition is 4294965247s.
      unit s means that the display and operation unit is sectors.
      p prints the partition table information.
      • If error message -bash: parted: command not found is returned, the system cannot identify the command. In this case, run yum install -y parted to install the command. Then, run the command again.
      • If the following error information is displayed, enter Fix.
        Error: The backup GPT table is not at the end of the disk, as it should be.  This might mean that another operating system believes the disk is smaller.  Fix, by moving the backup to the end (and removing the old backup)?
        Fix/Ignore/Cancel?
        The GPT partition table information is stored at the start of the disk. To reduce the risk of damage, a backup of the information is saved at the end of the disk. When you extend the disk, the end of the disk changes accordingly. In this case, enter Fix to move the backup file of the information to the end of the new disk.
      • If the following warning information is displayed, enter Fix.
        Warning: Not all of the space available to /dev/vdb appears to be used, you can fix the GPT to use all of the space (an extra 104857600 blocks) or continue with the current setting?
        Fix/Ignore?
        After you enter Fix, the system automatically sets the GPT partition style for the additional space.
    1. Set the partition name and size.
      mkpart /dev/vdb2 4294965248s100%
      p
      • mkpart<partition-name> <first-sector-value><last-sector-value>: In the example command, the first sector is 4294965248s, which is the last sector of /dev/vdb1 plus one. 100% indicates to allocate 100% of the disk space to the /dev/vdb2 partition.
      • If you want to allocate the additional space to two or more partitions, calculate the first and last sectors of the partitions based on the method provided in Table 2.
    1. Check the /dev/vdb2 partition.
      lsblk
      [root@ecs-centos74 ~]# lsblk
      ├─vda1 253:1    0    40G  0 part /
      ├─vdb1 253:17   0    2T  0 part /mnt/sdc
      ├─vdb2 253:18   0    1T  0 part
  4. Create an ext4 file system on the /dev/vdb2 partition.
    Filesystem label=
    OS type: Linux
    67108864 inodes, 268435456 blocks
    13421772 blocks (5.00%) reserved for the super user
    First data block=0
    Maximum filesystem blocks=2415919104
    8192 block groups
            4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
            102400000, 214990848
    GNU Parted 3.1
    Using /dev/vdb
    (parted) p
    Disk Flags:
     2      2199GB  3299GB   1100GB   ext4         /dev/vdb2
    (parted) q
  5. Create a directory (mount point) and mount the new partition on the created mount point.
    mkdir -p /mnt/sdc
    mount /dev/vdb1 /mnt/sdc
    lsblk
    ├vdb1 253:17   0   2T  0 part /mnt/sdc
    ├vdb2 253:18   0   1T  0 part /mnt/sdd
  6. Use the partition UUID to configure auto mount at startup.
      blkid /dev/vdb2
      vi /etc/fstab
      Table 4 Content description
      Example Value
      /mnt/sdc
      ext4
      defaults
      0
      2
  1. Verify that auto mount takes effect.
    You can restart the server to check whether auto mount takes effect. Alternatively, you can perform the following steps to simulate a system restart and auto mount.
    umount /dev/vdb2
    mount -a
    mount|grep/mnt/sdd
Related Links
