Updated on 2026-05-11 GMT+08:00
Overview
You can attach EVS disks to cloud servers to be used as system disks or data disks. For details, see Table 1.
Figure 1 shows the process of purchasing and using a data disk.
- Make preparations: Sign up for a HUAWEI ID, enable Huawei Cloud services, and top up your Huawei Cloud account.
- Buy an EVS disk: Configure the disk parameters, including the disk type, capacity, name, and other information by referring to Purchasing an EVS Disk.
- Attach the data disk: Attach the separately purchased disk to an ECS by referring to Attaching an EVS Disk.
- Initialize the data disk: After the data disk is attached, log in to the ECS and initialize the disk before using it. For details about how to initialize the disk, see the following sections:
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
