Updated on 2025-08-26 GMT+08:00
Buying a Shared Data Package
This section describes how to buy a shared data package. Shared data packages take effect immediately after your purchase. If you have subscribed to pay-per-use EIPs billed by traffic in a region and buy a shared data package in the same region, the EIPs will use the shared data package. After the package quota is used up or the package expires, the EIPs will continue to be billed on a pay-per-use basis.
If you have an order that has not been paid within the payment period, you need to cancel or pay for the order first. Then, you can purchase a shared data package.
  1. Go to the Buy Shared Data Package page.
  2. Set the parameters as prompted.
    Table 1 Parameter descriptions
    Example Value
    Region
    A shared data package can only be used by resources in its same region. Select the region based on your requirements.
    CN-Hong Kong
    Type
    The shared data package type. Set this parameter based on the bandwidth type of the EIP. The following two types of packages are available:
    • Dynamic BGP: A dynamic BGP data package can only be used by dynamic BGP EIPs billed by traffic on a pay-per-use basis.
    • Static BGP: A static BGP data package can only be used by static BGP EIPs billed by traffic on a pay-per-use basis.
    Static BGP
    Package Validity
    The validity period of the shared data package. Select a validity period based on service requirements. A shared data package cannot be unsubscribed and takes effect immediately after you purchase it. Expired shared data packages will longer be available for use.
    1 month
    Specification
    The size of the shared data package in GB.
    10 GB
    Usage Duration
    Default
  3. Click Next.
  4. Confirm the configurations and click Submit.
  5. On the payment page, confirm the order information and click Confirm.
Related Operations
Viewing the Usage Details and Configuring Remaining Usage Alerts: Viewing the usage of a shared data package and configuring remaining usage alerts are supported.
