Updated on 2026-06-30 GMT+08:00
Resource Package Overview
Resource packages are prepaid resources that you can purchase to save money. A resource package takes effect immediately once it is purchased. It cannot be used upon expiration and is suspended when it is used up. To continue using a resource package, you need to purchase a new one.
For details about how to reduce costs, see Lower Network Costs.
Shared Data Package
Shared data package provides a quota for data usage. Such packages are cost-effective and easy to use. Shared data packages take effect immediately after your purchase. If you have subscribed to pay-per-use EIPs billed by traffic in a region and buy a shared data package in the same region, the EIPs will use the shared data package. After the package quota is used up or the package expires, the EIPs will continue to be billed on a pay-per-use basis. For billing details, see Product Pricing Details.
  • Two types of packages are available: dynamic BGP and static BGP. Dynamic BGP data packages will be used by pay-per-use EIPs (billed by traffic) of the dynamic BGP type, and static BGP data packages will be used by pay-per-use EIPs (billed by traffic) of the static BGP type.
  • Shared data packages can be purchased yearly or monthly. Yearly packages are more cost effective. If you have multiple shared data packages, the one that expires first will be used first.
  • If your usage exceeds your shared data package quota within its validity, you will be billed on a pay-per-use basis for the additional traffic usage.
  • If a shared data package expires, make sure your account balance is sufficient. Your EIP will be billed on a pay-per-use basis, and EIP usage will not be affected.
  • If you want to stop using a shared data package before it expires, you can unsubscribe from it. For details, see Cloud Service Unsubscriptions.
  • Shared data packages require a one-off payment and take effect immediately after purchase. You cannot specify an effective date.
  • Shared data packages are billed by month or year. Once expired, remaining package quota cannot be used anymore.
  • Shared data packages can only be used by pay-per-use dedicated bandwidth billed by traffic. Two types of shared data packages are available: dynamic BGP (for dynamic BGP bandwidth) and static BGP (for static BGP bandwidth).
  • A shared data package cannot take effect only for the bandwidth of a specific EIP.
  • A shared data package cannot be used by a shared bandwidth.
  • A shared data package cannot be used by EIPs of the premium BGP type.
Related Operations
Viewing the Usage Details and Configuring Remaining Usage Alerts: View the usage of a shared data package and configure remaining usage alerts.
