Help Center/ Elastic IP/ User Guide/ Elastic IP User Guide/ Elastic IP/ Releasing or Unsubscribing From an EIP
Updated on 2026-06-30 GMT+08:00
If an EIP is no longer required, you can unbind it from your instance and release it if it is a pay-per-use EIP or unsubscribe from it if it is a yearly/monthly EIP. If you do not release a pay-per-use EIP in a timely manner after unbinding it, the EIP continues to be billed for the reservation price. This section describes how to release or unsubscribe from an EIP.
  • An EIP that has been bound to an instance cannot be released or unsubscribed from.
  • Yearly/Monthly EIPs can only be unsubscribed from.
    If you no longer need a yearly/monthly resource, but the subscription has not yet expired, you can unsubscribe from it. Depending on what coupons were used for the purchase, Huawei Cloud may issue you a refund. For details about unsubscription rules, see Unsubscriptions.
  • An EIP cannot be released or unsubscribed if its server is suspected of violations and the EIP is frozen by the national supervision department.
  • The system preferentially assigns EIPs to you from the ones you released or unsubscribed from, if any. However, if any of these EIPs is already assigned to another user, it cannot be re-assigned to you.
    For details, see Assigning a Specific EIP.
Releasing a Pay-per-Use EIP
You can release a pay-per-use EIP on the console or by calling an API.
  1. Go to the EIP list page.
  2. In the EIP list, locate the row that contains the EIP and choose More > Release in the Operation column.
    A confirmation dialog box is displayed.
  3. Confirm the information and click OK.
    You can find that the EIP is not in the EIP list.
You can also select multiple EIPs and choose More > Release above the list to release EIPs. Only pay-per-use EIPs can be released in batches.
You can release a pay-per-use EIP by calling the API. For details, see Releasing an EIP.
Unsubscribing From a Yearly/Monthly EIP
You can unsubscribe from a yearly/monthly EIP on the console or by calling an API.
  2. In the EIP list, locate the target EIP, and choose More > Unsubscribe in the Operation column. The page for unsubscribing from resources is displayed.
  3. Confirm the information and click Confirm. A confirmation dialog box is displayed.
  4. Confirm the information and click OK.
You can also select multiple EIPs and choose More > Unsubscribe above the list to release EIPs. Only yearly/monthly EIPs can be unsubscribed from in batches.
To unsubscribe from a yearly/monthly EIP, refer to Unsubscribing from Yearly/Monthly Resources.
Scenarios Where EIPs Cannot Be Released or Unsubscribed from
  • An EIP has been bound to an instance.
    Only EIPs that have no instances bound can be released or unsubscribed from. To release or unsubscribe from an EIP that has been bound to an instance, unbind it first. For details, see Binding or Unbinding an EIP.
    Yearly/Monthly EIPs cannot be released. If you no longer need them, you can unsubscribe them.
  • Frozen EIPs
    An EIP cannot be released or unsubscribed if its server is suspected of violations and the EIP is frozen by the national supervision department. For details, see Why My EIPs Are Frozen? How Do I Unfreeze My EIPs?
