Assigning a Shared Bandwidth
When you host a large number of applications on the cloud, if each EIP uses a dedicated bandwidth, a lot of bandwidths are required, which incurs high costs. If all EIPs share the same bandwidth, your network operation costs will be lowered and your system O&M as well as resource statistics will be simplified.
Assign a shared bandwidth for use with EIPs.
- Go to the Buy Shared Bandwidth page.
- Set the parameters as prompted.
Table 1 Description Module
Example Value
Basic Configuration
Region
Regions are geographic areas that are physically isolated from each other. The networks inside different regions are not connected to each other, so resources cannot be shared across different regions. For lower network latency and faster access to your resources, select the region nearest to you.
CN-Hong Kong
Basic Configuration
Billing Mode
A shared bandwidth can be billed on a yearly/monthly or pay-per-use basis.
- Yearly/Monthly: You pay for the bandwidth by year or month before using it. No other charges apply during the validity period of the bandwidth.
- Pay-per-use: You pay for the bandwidth based on the amount of time you use the bandwidth.
Yearly/Monthly
Basic Configuration
Name
The name of the shared bandwidth.
Bandwidth-001
Basic Configuration
Enterprise Project
The enterprise project that the shared bandwidth belongs to.
An enterprise project facilitates project-level management and grouping of cloud resources and users. The name of the default project is default.
default
Bandwidth Details
Bandwidth Type
Select a type of the shared bandwidth based on your EIP type.
Standard: Dynamic BGP and static BGP EIPs can be added to a shared bandwidth of this type.
NOTE:In the CN-Hong Kong region, only dynamic BGP EIPs can be added to standard shared bandwidths.
Standard
Bandwidth Details
Billed By
The billing method for the shared bandwidth.
You can specify a shared bandwidth to be billed by bandwidth, 95th percentile bandwidth (enhanced).
NOTE:- 95th percentile bandwidth (enhanced) can be selected only when Billing Mode is set to Pay-per-use.
- Only customers with a level of V4 or higher can use the enhanced 95th percentile bandwidth billing. Enhanced 95th percentile bandwidth billing is based on average monthly bandwidth usage excluding peak traffic values. The charges will be deducted from your account balance on a monthly basis. You can specify the guaranteed minimum bandwidth by setting the bandwidth size and the minimum bandwidth percentage. If the monthly peak bandwidth is less than or equal to the guaranteed minimum bandwidth, you will be billed based on the guaranteed minimum bandwidth. If the monthly peak bandwidth is greater than the guaranteed minimum bandwidth, you will be billed based on the monthly peak bandwidth.
- If the enhanced 95th percentile bandwidth billing is used, the minimum shared bandwidth is 300 Mbit/s.
For more information, see 95th Percentile Bandwidth Billing (Enhanced).
Bandwidth
Bandwidth Details
Bandwidth (Mbit/s)
The bandwidth size in Mbit/s. The minimum value is 5 Mbit/s.
10
Bandwidth Details
QoS
After QoS is enabled, you can configure the bandwidth limits for each EIP that uses the shared bandwidth. This makes sure each EIP gets enough bandwidth and uses it better. Configuring bandwidth limits for EIPs is free of charge. For details, see QoS.
N/A
Required Duration
Required Duration
The duration for which the purchased shared bandwidth will be used. The duration must be specified if the Billing Mode is set to Yearly/Monthly.
2 months
Required Duration
Auto-renew
Whether to select Auto-renew. You can select it if the Billing Mode is set to Yearly/Monthly. The auto-renewal period is determined by the required duration.
- Monthly subscription: The subscription is renewed every month.
- Yearly subscription: The subscription is renewed each year.
N/A
- Click Next.
- Confirm the configurations.
- If you set Billing Mode to Pay-per-Use, click Submit.
- If you set Billing Mode to Yearly/Monthly, click Pay Now.
On the payment page, confirm the order information and click Confirm.
Related Operations
- Adding EIPs to or Removing EIPs from a Shared Bandwidth: After a shared bandwidth is assigned, you can add multiple pay-per-use EIPs to it so that all EIPs share the same bandwidth.
- Modifying a Shared Bandwidth: You can change the size of the shared bandwidth you have assigned.
