Updated on 2026-08-10 GMT+08:00
Overview
The Elastic IP (EIP) service provides public IP addresses and the capability to access the Internet. After you configure an EIP and bandwidth for an ECS, the ECS can directly access the Internet.
EIP provides two types of public IP resources:
  • EIPs: provide independent public IP resources, including public IP addresses and outbound public network bandwidth. EIPs can only be bound to resources in the same region. They cannot be used across regions.
  • Global elastic IPs (global EIPs) provide global Internet access for cloud instances. You can specify a global region and a global EIP pool to assign a global EIP, and bind the global EIP to a cloud instance (such as a load balancer or an ECS) from any region to enable communications between a cloud resource and the Internet.
EIP
EIPs can be bound to or unbound from ECSs, BMSs, virtual IP addresses, NAT gateways, and load balancers.
Each EIP can be bound to only one cloud resource at a time and both should be in the same region.
Note the following when binding an EIP to an instance (such as ECS):
  • Each EIP can be bound to only one ECS at a time. If an EIP is already bound to an ECS, it cannot be bound to another cloud resource. You can unbind the EIP from the ECS and then bind it to another cloud resource in the same region.
  • The EIP and the ECS must be in the same region.
Figure 1 Connecting to the Internet using EIPs
IP addresses include private IP addresses, EIPs, and virtual IP addresses. They are used in different scenarios. For details, see Table 1.
Figure 2 IP address architecture
Table 1 Functions of different IP address types
IP Address Type
Example Value
Private IP address
Private IP addresses come with your ECSs and belong to the VPC subnets of the ECSs. They are used for private communication on the cloud.
  • Private IP address of ECS-A-01: 172.16.0.84
  • Private IP address of ECS-B-01: 172.16.1.12
Virtual IP address
A virtual IP address is a private IP address independently assigned from a VPC subnet. It can be released when no longer needed. You can:
  • Bind one or more virtual IP addresses to a cloud server so that you can use either the virtual or private IP address to access the server. If you have multiple services running on a cloud server, you can use different virtual IP addresses to access them.
  • Bind a virtual IP address to multiple cloud servers. You can use a virtual IP address and an HA software (such as Keepalived) to set up a high-availability active/standby cluster. If you want to improve service availability and avoid single points of failure, you can deploy cloud servers in the active/standby mode or deploy one active cloud server and multiple standby cloud servers. In this arrangement, the cloud servers all use the same virtual IP address. If the active cloud server goes down, the standby cloud server becomes the active server and continues to provide services.
For more information about virtual IP addresses, see Virtual IP Address Overview. For details about how to set up a high availability cluster, see Using a Virtual IP Address and Keepalived to Set Up a High-Availability Web Cluster.
Bind virtual IP address (172.16.0.2) both ECS-A-01 and ECS-A-02. The active/standby switchover of ECS-A-01 and ECS-A-02 can be implemented by using Keepalived.
EIP
EIPs allow cloud resources to access the Internet. They can be flexibly bound to or unbound from instances.
  • You can bind an EIP to a virtual IP address to enable the ECSs with the virtual IP address bound to access the Internet.
  • You can also bind an EIP to the ECSs to enable them to access the Internet.
For more information, see EIP Overview.
  • Bind EIP (122.9.9.85) to virtual IP address (172.16.0.2) to enable ECS-A-01 and ECS-A-02 to access the Internet.
  • Bind EIP (122.9.9.87) to ECS-B-01 to enable ECS-B-01 to access the Internet.
Bandwidth refers to the maximum amount of data that can be transmitted in a given amount of time (generally one second). A larger bandwidth value indicates a stronger transmission capability. Bandwidth is classified into public bandwidth and private bandwidth.
Private bandwidth is the bandwidth consumed when data is transferred between ECSs in the same region and on the same private network. ECSs can also be connected to cloud databases, load balancers, and OBS through private bandwidth. The private bandwidth size depends on the instance specifications.
For details, see ECS Types.
Public bandwidth is the bandwidth consumed when data is transferred between Huawei Cloud and the Internet. You can configure the public bandwidth when creating an ECS or bind an EIP to an ECS after the EIP is created.
Figure 3 Public bandwidth and private bandwidth
Public bandwidth is classified into inbound bandwidth and outbound bandwidth. For details about the outbound bandwidth and inbound bandwidth, see Figure 4.
  • The metrics about outbound bandwidth on the Cloud Eye console are Outbound Bandwidth and Outbound Traffic.
  • The metrics about inbound bandwidth on the Cloud Eye console are Inbound Bandwidth and Inbound Traffic.
Figure 4 Inbound bandwidth and outbound bandwidth
Table 2 Inbound bandwidth and outbound bandwidth
Type
Outbound bandwidth
Bandwidth consumed when data is transferred from Huawei Cloud to the Internet. For example, the outbound bandwidth is consumed when ECSs provide services accessible from the Internet or when FTP clients download resources from the ECSs. The metrics about outbound bandwidth on the Cloud Eye console are Outbound Bandwidth and Outbound Traffic.
You are only billed for the outbound bandwidth you have used.
Inbound bandwidth
Bandwidth consumed when data is transferred from the Internet to Huawei Cloud. For example, the inbound bandwidth is consumed when downloading resources from the Internet to ECSs and when FTP clients upload resources to the ECSs. The metrics about inbound bandwidth on the Cloud Eye console are Inbound Bandwidth and Inbound Traffic.
The maximum inbound bandwidth depends on the size of the outbound bandwidth.
  • If your specified bandwidth is less than or equal to 10 Mbit/s, the inbound bandwidth will be 10 Mbit/s, and the outbound bandwidth will be the same as the specified bandwidth.
  • If your specified bandwidth is greater than 10 Mbit/s, the outbound and inbound bandwidth will be the same as the specified bandwidth.
The preceding bandwidth limit is not applicable in CN North-Beijing1 and CN East-Shanghai2.
Global EIP
Global EIPs provide global Internet access for cloud instances. You can specify a global region and a global EIP pool to assign a global EIP, and bind the global EIP to a cloud instance (such as a load balancer or an ECS) from any region to enable communications between a cloud resource and the Internet. A global EIP needs a global connection bandwidth for cloud backbone (intranet) communications and a global internet bandwidth for Internet access. To enable an ECS to communicate with the Internet through a global EIP, you also need to bind a global internet gateway to the global EIP. Figure 5 shows the global EIP architecture.
Figure 5 Global EIP architecture
Differences Between EIPs and Global EIPs
Table 3 Differences between EIPs and global EIPs
Item
Feature
How to Obtain
EIP
EIPs and cloud resources must be in the same region.
The EIP service provides independent public IP addresses and bandwidths for Internet access. EIPs can be bound to or unbound from ECSs, BMSs, virtual IP addresses, NAT gateways, and load balancers.
  • An EIP can be flexibly bound to or unbound from a cloud resource in the same region.
  • Low costs
  • Simple networking
Global EIP
A global EIP with a global connection bandwidth and a global internet bandwidth associated can be bound to a cloud instance in any region.
Global EIPs provide global Internet access for cloud instances. You can specify a global region and a global EIP pool to assign a global EIP, and bind the global EIP to a cloud instance (such as an ECS or a load balancer) from any region to enable communications between a cloud resource and the Internet.
  • Global EIPs can be bound to cloud resources across regions.
  • Global connection bandwidths and global internet bandwidths are required for network communications.
Before binding a global EIP to an ECS, you need to create a global internet gateway to connect the VPC of the ECS to the global EIP so that the ECS can access the Internet through the global EIP. Global internet gateways are free of charge.
When you bind a global EIP to an ECS, the system automatically lists the global internet gateway of the VPC that the ECS belongs to, if there is one.
For details, see Global Internet Gateway Overview.
A global connection bandwidth can be bound to a central network to allow the resources to communicate with each other over the backbone network.
There are different types of global connection bandwidths that are designed for different application scenarios, including multi-city, geographic-region, and cross-geographic-region bandwidths. Geographic-region and cross-geographic-region bandwidths are often bound to Cloud Connect central networks.
Geographic-region bandwidths are used for resources in a geographic region to communicate.
Cross-geographic-region bandwidths are used for resources across geographic regions to communicate.
For details, see Global Connection Bandwidth Overview.
A global internet bandwidth can be shared by one or more global EIPs at the same time, improving bandwidth utilization.
Global internet bandwidths work together with global EIPs for Internet access. You can add one or more global EIPs to the same global internet bandwidth. A global EIP and its global internet bandwidth must use the same access point.
Figure 6 Global EIP architecture
For details, see Global Internet Bandwidth Overview.
