Monitoring EIPs
Cloud Eye is a multi-dimensional resource monitoring service that you can use to monitor EIP and bandwidths in real time, set alarm rules, identify resource exceptions, and quickly respond to resource changes.
Cloud Eye is enabled automatically after an EIP is assigned. For more information about Cloud Eye, see What Is Cloud Eye?
Setting an Alarm Rule
You can configure alarm rules on the Cloud Eye console to send you notifications in case of exceptions.
For details about how to create alarm rules, see Creating an Alarm Rule.
Viewing Metrics
- Log in to the Cloud Eye console.
- In the navigation pane, choose Cloud Service Monitoring.
     On the Cloud Service Monitoring page, click Virtual Private Cloud VPC in the Dashboard column and go to the Details page.
- Select Elastic IPs or Bandwidths as required to view detailed data.
       If you select Elastic IPs, you can search for an EIP by IPv4 or IPv6 address to quickly locate and view the monitoring details of the EIP.
- On the Overview tab, perform the following operations:
     - View information under Resource Overview, Alarm Statistics, and Key Metrics. For details, see Table 1.
       Table 1 Three modules on the Overview tab Module Description Resource Overview You can view the resource data of the current cloud service in the current dimension, including Total Resources, Resources in Alarm, and Resources in Alarm in the Last 7 Days. Alarm Statistics You can view the total number of alarms in the last seven days, alarms of different severities (critical, major, minor, and informational), top 5 instances by total alarms, and top 5 resource groups by total alarms. Key Metrics You can view monitoring details of key metrics recommended by the cloud service.
- In the upper left corner of the Details page, select Resources to view corresponding monitoring details or select another cloud service to switch to its dashboard.
- On the Resources tab, perform the following operations:
     - Click Export Data to export cloud service monitoring data. For details, see How Can I Export Monitoring Data?
- Locate an instance and click View Metric to view the instance metrics and HTTP status codes.
- Locate an instance and choose More > Create Alarm Rule to create an alarm rule for the instance. For details about the parameters, see Setting an Alarm Rule.
- Locate an instance and choose More > View Alarm Rule to view the alarm rules created for the instance.
Related Operations
You can enable batch notification policy setting as required and select existing notification policies. For details about how to create a notification policy, see Creating a Notification Policy.
