Updated on 2026-09-18 GMT+08:00
Monitoring Metrics
Overview
This section describes the namespace, list, and measurement dimensions of metrics of EIPs and bandwidths that you can check on Cloud Eye. You can use APIs or the Cloud Eye console to query the monitored metrics and generated alarms.
  • Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is resourceA_id,resourceB_id, resourceA_id indicates level 0 and resourceB_id indicates level 1.
  • If a bandwidth is increased or decreased, there is a delay of 5 to 10 minutes for the monitoring metrics to update for the new bandwidth.
Namespace
Namespace of EIPs and bandwidths: SYS.VPC
Monitoring Metrics
Table 1 EIP and bandwidth metrics
ID
Name
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Interval (Raw Data)
upstream_bandwidth
Outbound Bandwidth
Network rate of outbound traffic (Previously called "Upstream Bandwidth")
≥ 0
bit/s
1000 (SI)
bandwidth_id
publicip_id
1 minute
downstream_bandwidth
Inbound Bandwidth
Network rate of inbound traffic (Previously called "Downstream Bandwidth")
≥ 0
bit/s
1000 (SI)
bandwidth_id
publicip_id
1 minute
upstream_bandwidth_usage
Outbound Bandwidth Usage
Usage of outbound bandwidth in the unit of percent.
Outbound bandwidth usage = Outbound bandwidth/Purchased bandwidth
0-100
N/A
bandwidth_id
publicip_id
1 minute
downstream_bandwidth_usage
Inbound Bandwidth Usage
Usage of inbound bandwidth in the unit of percent.
Inbound bandwidth usage = Inbound bandwidth/Purchased bandwidth
0-100
N/A
bandwidth_id
publicip_id
1 minute
up_stream
Outbound Traffic
Network traffic going out of the cloud platform (Previously called "Upstream Traffic")
≥ 0
Byte
1000 (SI)
bandwidth_id
publicip_id
1 minute
down_stream
Inbound Traffic
Network traffic going into the cloud platform (Previously called "Downstream Traffic")
≥ 0
Byte
1000 (SI)
bandwidth_id
publicip_id
1 minute
Dimensions
Key
Value
publicip_id
EIP ID
You can call the API Querying an EIP to obtain the value from the response parameters.
bandwidth_id
Bandwidth ID
You can call the API Querying a Bandwidth to obtain the value from the response parameters.
