Updated on 2026-09-18 GMT+08:00
EIP Events That Can Be Monitored
Function Description
On Cloud Eye, you can use event monitoring for data collection, query, and alarm reporting. You can create alarm rules for both system events and custom events. When there are specified events, you will receive alarm notifications.
Namespace
SYS.EIP
Table 1 EIP events
Event Source
Namespace
Event Name
Event ID
Event Severity
Solution
Impact
EIP
SYS.EIP
EIP bandwidth overflow
EIPBandwidthOverflow
Major
The used bandwidth exceeded the purchased one, so the network may become slow or packets may be lost. The event value reflects the peak in a monitoring period, and the value of the EIP inbound and outbound bandwidth is taken from a specific point within that period.
  • egressDropBandwidth: dropped outbound packets (bytes)
  • egressAcceptBandwidth: accepted outbound packets (bytes)
  • egressMaxBandwidthPerSec: peak outbound bandwidth (Mbit/s)
  • ingressAcceptBandwidth: accepted inbound packets (bytes)
  • ingressMaxBandwidthPerSec: peak inbound bandwidth (Mbit/s)
  • ingressDropBandwidth: dropped inbound packets (bytes)
The EIP bandwidth overflow event is available only in certain regions. You can check the regions on the console.
Check whether the used EIP bandwidth keeps increasing and whether services are normal. Increase the bandwidth if necessary.
The network becomes slow or packets are lost.
Delete EIP
deleteEip
Minor
The EIP was released.
Check whether the EIP was released by mistake.
The resource cannot access the Internet.
EIP blocked
blockEIP
Critical
The used bandwidth of an EIP exceeded the threshold, so the EIP was blocked and packets were discarded. Such an event may be caused by DDoS attacks.
For details about the threshold, see CNAD Basic.
Replace the EIP to prevent services from being affected.
Locate and deal with the fault.
Services are impacted.
EIP unblocked
unblockEIP
Critical
The EIP was unblocked.
Use the previous EIP to save resources.
None
Start DDoS traffic scrubbing
ddosCleanEIP
Major
Traffic scrubbing on the EIP was started to prevent DDoS attacks.
Check whether the EIP was attacked.
Services may be interrupted.
Stop DDoS traffic scrubbing
ddosEndCleanEip
Major
Traffic scrubbing on the EIP to prevent DDoS attacks was ended.
Enterprise-class QoS bandwidth limit exceeded
EIPBandwidthRuleOverflow
Major
The allocated QoS bandwidth was exceeded, which may slow down the network or cause packet loss. The event value reflects the peak in a monitoring period, and the value of the EIP inbound and outbound bandwidth is taken from a specific point within that period.
Unbound EIP
EipNotBoundStatus
Warning
The EIP is not bound to any resource.
N/A
When an EIP is unbound, you will be billed for IP reservation fees and bandwidth fees (billed by bandwidth).
