Creating an Alarm Rule
You can configure alarm rules to customize the monitored objects and notification policies. You can learn your resource statuses at any time.
- Click
in the upper left corner and select the desired region and project.
- In the upper left corner of the page, click
to open the service list and choose Management & Deployment > Cloud Eye.
- In the left navigation pane on the left, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, click Create Alarm Rule and set required parameters, or modify an existing alarm rule.
- After the parameters are set, click Create.
After the alarm rule is created, the system automatically notifies you if an alarm is triggered for the VPC service.
