User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Creating Users and Assigning DLV Permissions
This section describes how to use IAM to implement fine-grained permissions control for your DLV resources. With IAM, you can:
- Create IAM users for employees based on the organizational structure of your enterprise. Each IAM user has their own security credentials, providing access to DLV resources.
- Grant only the permissions required for users to perform a specific task.
- Entrust a Huawei Cloud account or service to perform professional and efficient O&M on your DLV resources.
If your Huawei Cloud account does not need individual IAM users for permissions management, then you may skip over this chapter.
This section describes the procedure for granting permissions. Permission Assigning Process shows the procedure. You can use either of the following methods to grant DLV permissions to a user:
- Creating Users and Assigning Permissions of DLV Workspace Roles
- Creating Users and Assigning All DLV Permissions
- Before granting permissions to a user, learn about the DLV workspace roles and permissions that can be assigned to the user and select the roles and permissions based on the site requirements. For details about the roles and permissions supported by DLV, see Permissions Management.
- For the system policies of other services, see System Permissions.
- Create a user.
Log in to the IAM console and create a user.
- Adding Workspace Members and Roles
Log in to the DLV console as the user created in 1 and add the user as a member and role of the workspace to be authorized. Assume that only the visitor role of the DLV workspace is granted to the user.
- Log in and verify the permissions.
Log in to the DLV console by using the user created, and verify the granted permissions of the user as follows:
- Log in to the DLV console and switch to the authorized workspace. On the Screens page, click New Screen to create a screen. If the screen cannot be created, the visitor role has taken effect.
- In the service list area, select any service except DLV (assume that policies of other services are not granted to the user). If a message appears indicating that you have no permission to access the service, the visitor role has taken effect.
To grant an IAM user permission to create a workspace, you need to grant the IAM user the DLV FullAccess policy, so that the user can perform all permissions on DLV. You can grant DLV policies to a user group. In this way, after you add a user to the user group, the user will have the corresponding permissions.
- Create a user.
- Create a user group and assign permissions to it.
Create a user group on the IAM console, and assign the DLV FullAccess permission to the group.
- The DLV FullAccess permission is not granted to the existing users. To obtain this permission, log in to the IAM console and grant the permission to the existing users.
- Add a user to a user group.
On the IAM console, add the user created in 1 to the user group.
Log in to the DLV console by using the user created, and verify the granted permissions of the user.
- Log in to the DLV console and click
on the Workspace page to create a workspace. If a workspace can be created, the DLV FullAccess permission has taken effect.
- In the service list area, select any service except DLV. If a message appears indicating that you have no permission to access the service, the DLV FullAccess permission has already taken effect.
