- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Key Management Service
- Cloud Secret Management Service
- Key Pair Service
- Dedicated HSM
- Tag Management
- Auditing Logs
- Sharing
- Permission Control
Best Practices
- General
API Reference
- Before You Start
- Calling APIs
- API Overview
APIs
Key Management APIs
- Key Lifecycle Management
- DEK Management
- Small-Size Data Encryption and Decryption
- Signature and Verification
- Key Tag Management
- Key API Version Query
- Querying Key API Versions
- Key Import Management
- Querying Keys
- Key Grant Management
- Key Rotation Management
- Dedicated Keystore Management
- Signature Verification
- Key Pair Management APIs
- Secret Management APIs
Key Management APIs
- Historical APIs
- Application Examples
- Appendix
- SDK Reference
KMS Related
- What Is Key Management Service?
- What Is a Customer Master Key?
- What Is a Default Key?
- What Are the Differences Between a Custom Key and a Default Key?
- What Is a Data Encryption Key?
- Why Cannot I Delete a CMK Immediately?
- Which Cloud Services Can Use KMS for Encryption?
- How Do Huawei Cloud Services Use KMS to Encrypt Data?
- What Are the Benefits of Envelope Encryption?
- Is There a Limit on the Number of Custom Keys That I Can Create on KMS?
- Can I Export a CMK from KMS?
- Can I Decrypt My Data if I Permanently Delete My Custom Key?
- How Do I Use the Online Tool to Encrypt or Decrypt Small Volumes of Data?
- Can I Update CMKs Created by KMS-Generated Key Materials?
- When Should I Use a CMK Created with Imported Key Materials?
- What Should I Do When I Accidentally Delete Key Materials?
- How Are Default Keys Generated?
- What Should I Do If I Do Not Have the Permissions to Perform Operations on KMS?
- Why Can't I Wrap Asymmetric Keys by Using -id-aes256-wrap-pad in OpenSSL?
- Key Algorithms Supported by KMS
- What Should I Do If KMS Failed to Be Requested and Error Code 401 Is Displayed?
- What Is the Relationship Between the Ciphertext and Plaintext Returned by the encrypt-data API?
- How Does KMS Protect My Keys?
- How Do I Use an Asymmetric Key to Verify the Signature Result of a Public Key Pair?
- Does an Imported Key Support Rotation?
- Does KMS Support Offline Data Encryption and Decryption?
- How Do I Convert an Original EC Private Key into a Private Key in PKCS8 Format?
- CSMS Related
KPS Related
- How Do I Create a Key Pair?
- What Are a Private Key Pair and an Account Key Pair?
- How Do I Handle an Import Failure of a Key Pair Created Using PuTTYgen?
- What Should I Do When I Fail to Import a Key Pair Using Internet Explorer 9?
- How Do I Log In to a Linux ECS with a Private Key?
- How Do I Use a Private Key to Obtain the Password to Log In to a Windows ECS?
- How Do I Handle the Failure in Binding a Key Pair?
- How Do I Handle the Failure in Replacing a Key Pair?
- How Do I Handle the Failure in Resetting a Key Pair?
- How Do I Handle the Failure in Unbinding a Key Pair?
- Do I Need to Restart Servers After Replacing Its Key Pair?
- How Do I Enable the Password Login Mode for an ECS?
- How Do I Handle the Failure in Logging In to ECS After Unbinding the Key Pair?
- What Should I Do If My Private Key Is Lost?
- How Do I Convert the Format of a Private Key File?
- Can I Change the Key Pair of a Server?
- Can a Key Pair Be Shared by Multiple Users?
- How Do I Obtain the Public or Private Key File of a Key Pair?
- What Can I Do If an Error Is Reported When an Account Key Is Created or Upgraded for the First Time?
- Will the Account Key Pair Quota Be Occupied After a Private Key Pair Is Upgraded to an Account Key Pair?
- Why Is the Private Key Pair Invisible After It Is Upgraded to an Account Key Pair When Logging in as a Federated User?
Dedicated HSM Related
- What Is Dedicated HSM?
- How Does Dedicated HSM Ensure the Security for Key Generation?
- Do Equipment Room Personnel Has the Super Administrator Role to Steal Information by Using a Privileged UKey?
- What HSMs Are Used for Dedicated HSM?
- What APIs Does Dedicated HSM Support?
- How Do I Enable Public Access to a Dedicated HSM Instance?
- Pricing
General
- What Functions Does DEW Provide?
- What Cryptography Algorithms Does DEW Use?
- In Which Regions Are DEW Services Available?
- What Is a Quota?
- What Is the Resource Allocation Mechanism of DEW?
- What Are Regions and AZs?
- Can DEW Be Shared Across Accounts?
- How Do I Access the Functions of DEW?
- Why Do DEW Pemissions Fail to Take Effect Immediately?
KMS Related
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- User Guide (Paris and Amsterdam Regions)
User Guide
- Auditing Logs
KMS Related
- How Do Cloud Services Use KMS to Encrypt Data?
- What Types of Keys Can I Import?
- Credential Related
KMS Related
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Scheduling the Deletion of a CMK
- Canceling the Scheduled Deletion of a CMK
- Querying the List of CMKs
- Querying the Information About a CMK
- Creating a Random Number
- Creating a DEK
- Creating a Plaintext-Free DEK
- Encrypting a DEK
- Decrypting a DEK
- Querying the Number of Instances
- Querying the Quota of a User
- Changing the Alias of a CMK
- Changing the Description of a CMK
- Encrypting Data
- Decrypting Data
- Obtaining CMK Import Parameters
- Importing CMK Material
- Deleting CMK Material
- Querying CMK Instances
- Querying CMK Tags
- Querying Project Tags
- Adding or Deleting CMK Tags in Batches
- Adding a CMK Tag
- Deleting a CMK Tag
- Appendix
- Change History
API Reference (Paris and Amsterdam Regions)
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Querying Grants on a CMK
- Querying Grants That Can Be Retired
- Encrypting Data
- Decrypting Data
- Enabling Rotation for a CMK
- Changing the Rotation Interval for a CMK
- Disabling Rotation for a CMK
- Querying the Rotation Status of a CMK
- Appendix
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Encrypting Data
- Decrypting Data
- Appendix
- Change History
On this page
Help Center/
Data Encryption Workshop/
User Guide/
Key Pair Service/
Using Key Pairs/
Binding Key Pairs in Batches
When ECS is in the Running state, you can bind key pairs in batches on the console.
This section describes how to bind key pairs in batches on the KMS console.
Application Scenario
- If multiple ECSs to be bound have the same password, you can enter the password and select the key pair with just a few clicks.
- If the passwords of the ECSs to be bound are different, you can enter their passwords and select the same key pair for binding.
- The ECS must be in the Running state.
- The ECS has not been bound to a key pair.
- On the management console, key pairs cannot be bound to ECSs that run Windows.
- Key pairs cannot be bound to public images running CoreOS, OpenEuler, FreeBSD (Other), Kylin V10 64-bit, or UnionTech OS Server 20 Euler 64-bit.
- You can bind key pairs to a maximum of 10 ECSs at a time.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner and choose Security & Compliance > Data Encryption Workshop.
- In the navigation pane on the left, click Key Pair Service.
- Click ECS List to view ECSs.
- Select the servers to be bound in batches and click Bind above the search box.
- If the passwords of the ECSs to be bound are the same, you can select a key pair by one click and enter the password to bind the key pair. For details, see Figure 1.
- If the passwords of the ECSs to be bound are different, you can bind them separately.For details, see Figure 2.
If you select Unified bind, only the same key pair can be used for binding.
- The default port number is 22 and can be modified.
Before using user-defined port, ensure that:
- The key pair can be connected to the ECS using the port. For details about how to modify the security group configuration of an ECS, see Configuring Security Group Rules.
- Modify the default port of the ECS and ensure that the port is enabled. For details, see Enhancing Security for SSH Logins to Linux ECSs.
- You can choose whether to disable the password login mode as necessary. By default, the password login mode is disabled.
- If you do not disable the password login mode, you can use the password or the key pair to log in to the ECS.
- If the password login mode is disabled, you can use only the key pair to log in to the ECS. If you need to use the password login mode later, you can enable the password login mode again. For details, see How Do I Enable the Password Login Mode for an ECS?.
- Select I have read and agree to the Key Pair Service Disclaimer.
- Click OK. The key pairs are bound in batches. The binding takes about 3 to 5 minutes.
Parent topic: Using Key Pairs
