- Billing
- Getting Started
User Guide
- Preparations
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
Best Practices
- Best Practices Summary
Using CodeArts to Manage an e-Mall Development Project
- Overview
- Resource Planning
- Process
Implementation Procedure
- Preparation
- Step 1: Managing Project Plans
- Step 2: Managing Project Configurations
- Step 3: Writing Code
- Step 4: Checking Code
- Step 5: Building an Application
- Step 6: Deploying an Application (CCE)
- Step 6: Deploying an Application (ECS)
- Step 7: Managing Project Tests
- Step 8: Configuring a Pipeline for Continuous Delivery
- Releasing Resources
General
- How Do I Collect or Archive Project Information Locally After a CodeArts Project Is Complete?
- Why Can't an IAM User View Any CodeArts Projects After Login?
- How Do I View All CodeArts Projects and Members Under My Account as Administrator?
- Will the Tasks Created by a Project Member Be Deleted After the Member Leaves the Project?
- Will a New User with the Same Name as a Deleted User Inherit Their Permissions and Tasks?
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
General
- Videos
Purchasing CodeArts
To perform this operation, you must have any of the following permissions:
- Tenant Administrator
- DevCloud Console FullAccess and BSS Administrator
- DevCloud Console FullAccess and BSS Finance
- DevCloud Console FullAccess and BSS Operator
- Custom policies that contain all permissions in DevCloud Console FullAccess as well as the bss:order:view, bss:order:pay, and bss:order:update permissions.
Purchasing a CodeArts Package
CodeArts uses yearly/monthly billing, and provides the free, basic, professional, and enterprise edition packages to meet the requirements of different user scales. For details about these packages, see Package Overview.
- Go to the Buy CodeArts page.
- Set the region, edition, number of users, required duration, and auto-renewal, agree to the agreement, and click Next.
- You are advised to select the nearest region based on your physical region where your services are located to reduce network latency. The purchased package takes effect only in the corresponding region and cannot be used across regions.
- The Free edition comes with a fixed number of users and duration. To use this edition, click Try Free. You do not need to make any payment.
- Confirm the order content. If you need to modify it, click Previous. If the content is correct, click Pay.
- Follow the prompts to complete the payment.
- Check the package purchase record back on the CodeArts console.
If the purchase fails, rectify the fault by referring to Billing FAQs.
Purchasing Resource Extension
CodeArts provides parallel job extension for multiple services. For details, see Resource Extension.
- Go to the Buy CodeArts Resource Extension page.
- Set the region, product, type, required duration, and auto-renewal, agree to the agreement, and click Next.
- The configuration items for the selected product and type are displayed. Select the configuration items you need.
- Select a region where you have purchased CodeArts Basic or higher edition, or you cannot purchase resource extensions.
- Check the resource extension purchase record back on the CodeArts console.
Purchasing a Value-Added Feature
CodeArts provides value-added features such as CodeCheck enhanced package. For details, see Value-added Features.
- Go to the CodeArts value-added feature purchase page.
- Set the region, product, quantity, required duration, and auto-renewal, agree to the agreement, and click Next.
- To purchase the CodeCheck enhanced package, select a region where you have purchased CodeArts Pro or Enterprise edition.
- Check the value-added feature purchase record back on the CodeArts console.
