Setting Notification Receiving Rules
CodeArts allows you to configure notification rules for each individual service and determine whether to receive notifications by email.
Setting Notification Rules
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region where you have enabled CodeArts.
- Click Go to Workspace.
If your account uses the old billing mode (see Old Billing Modes), click Access Service.
- On the top navigation bar, click
and choose This Account Settings. The Notifications page is displayed.
- Complete the configuration by referring to the table below.
Table 1 Setting rules for receiving notifications Operation
Setting do-not-disturb time period
- Toggle the Do-Not-Disturb switch.
- Click Edit Settings. In the displayed dialog box, set the start time and end time, and click OK.
The updated period is displayed.
Enabling/Disabling notifications
Click Enable or Disable.
Modifying the email address for receiving notifications
- Click Edit Settings next to the email address. The Security Settings page is displayed.
- Click Change, verify your identity, and change your email address as prompted.
The Notifications page is displayed, showing the new email address.
Helpful Links
For details about how to configure notifications for each service, see:
