- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Deploy Overview
- Purchasing and Authorizing CodeArts Deploy
- Accessing CodeArts Deploy Homepage
- Configuring the Host Cluster of CodeArts Deploy
Creating and Deploying an Application with a Blank Template
- Creating an Application with a Blank Template
Configuring Deployment Actions for an CodeArts Deploy Application
- Configuring Deployment Actions for Software Installation
Configuring Deployment Actions for Containers
- Deploying on Kubernetes
- Deploying an Application in Kubernetes (CCE Cluster) Using Manifest
- Deploying an Application in Kubernetes (CCE Cluster) Quickly
- Deploying an Application with a Custom Kubernetes Cluster
- Kubernetes Nginx-Ingress Grayscale Deployment (CCE Cluster)
- Deploying with Helm3
- Deploying an Application on ServiceStage 2.0
- Rolling Back ServiceStage Components
- Configure Deployment Actions for Starting or Stopping a Service
- Configuring Deployment Actions for File Operations
- Configuring Deployment Actions for Running Commands
- Configuring Other Deployment Actions
- Editing the Deployment Actions of the CodeArts Deploy Application
- Configuring Parameters of an Application
- Configuring an Environment
- Configuring Permissions for Different Roles
- Deploying an Application and Viewing the Result
- Configuring System Notifications
Creating and Deploying an Application Using a Preset Template
- Introduction to CodeArts Deploy Templates
- Creating and Deploying an Application Using ServiceStage
- Creating and Deploying an Application Using a Kubernetes Template
- Creating and Deploying an Application Using the Function Deployment Template
- Creating and Deploying an Application Using the Tomcat Template
- Creating and Deploying an Application Using the Spring Boot Deployment Template
- Creating and Deploying an Application Using the Docker Deployment Template (Linux)
- Creating and Deploying an Application Using the Django Template
- Creating and Deploying an Application Using the Node.js Template
- Creating and Deploying a Common Application by Running the Shell Script
- Creating and Deploying an Application Using the Go Application Deployment Template
- Creating and Deploying an Application Using the Vue Deployment Template
- Creating and Deploying an Application Using the Custom Template
- Querying Audit Logs (Optional)
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Managing Host Clusters
- Creating a Host Cluster
- Querying a Host Cluster List
- Deleting a Host Cluster
- Modifying a Host Cluster
- Creating a Host Cluster (Recommended)
- Querying a Host Cluster List (Recommended)
- Querying a Host Cluster (Recommended)
- Editing a Host Cluster
- Deleting a Host Cluster (Recommended)
- Querying Information About the Environment Associated with a Host Cluster
- Querying the Basic Environment Information List of an Application
Managing Hosts
- Creating a Host
- Querying a Host List
- Querying Host Details
- Modifying a Host
- Deleting a Host
- Creating a Host (Recommended)
- Querying a Host List (Recommended)
- Querying Host Details (Recommended)
- Editing Host Information in a Host Cluster
- Deleting a Host from a Host Cluster
- Cloning Hosts to the Target Host Cluster in Batches
- Deleting Hosts from a Host Cluster in Batches
Managing Applications
- Obtaining an Application List
- Creating an Application Using a Template
- Obtaining the Details of an Application
- Deleting an Application
- Querying the Historical Deployment Records of a Specified Application in a Project by the Start Time and End Time
- Obtaining an Application List (Recommended)
- Creating an Application (Recommended)
- Updating an Application
- Obtaining Application Details (Recommended)
- Deleting an Application (Recommended)
- Querying the Execution Parameters of a Deployment Record
- Cloning an Application
- Deleting Applications from a Project in Batches
- Checking Whether an Application with the Same Name Exists in a Project
- Disabling and Enabling an Application
- Managing Application Groups
- Managing Application Permissions
- Measuring Deployment Record
Managing Environments
- Creating an Environment for an Application
- Querying an Environment List of an Application
- Editing an Environment in an Application
- Deleting an Environment from an Application
- Querying Environment Details
- Importing a Host to an Environment
- Deleting a Host from an Environment
- Querying a Host List in an Environment
- Managing Host Cluster Permissions
- Managing Environment Permissions
- Application Examples
- Appendixes
Hosts
- What Are the Troubleshooting Methods for Host and Proxy Connectivity Verification Failures
- What Should I Do If Application Deployment Fails with "tomcat | Download War in url path" Displayed in Logs?
- Why Does a Task Fail on an Ubuntu Host After Being Successfully Run on a CentOS Host?
- What Should I Do If the No Host or Environment Whose Connectivity Has Been Verified?
- What Are Possible Causes of a Host verification failure?
- What Should I Do If a Draft Application Cannot Be Deployed?
- What Are Error Messages Displayed During Application Deployment?
- How Do I Find the Cause of an Application Deployment Error in Logs?
- What Should I Do If Error 403 Displayed During Application Deployment That Requires CCE Resources, Indicating Insufficient Permission?
- How Do I Roll Back a Deployed Version?
- What Should I Do If an Application Deployment Times Out?
- Does CodeArts Deploy Provide Batch and Incremental Deployment Policies?
- Do I Need to Upload a Software Package to CodeArts Artifact Before Deployment?
- Can I Deploy Web Pages Written in HTML or JS?
- How Do I Upload an Image for Container Deployment?
- Can I Use a Host to Deploy Multiple Projects?
- Do I Need to Install a Running Environment (Tomcat, Python, etc.) on the Target Host Before Deploying an Application?
- What Should I Do If Application Deployment Fails, with the Message "AnsibleUndefinedVariable: 'xxxx' is undefined" Displayed?
- What Should I Do If Application Deployment Succeeds But the Application Verification URL Cannot Be Accessed?
- What Should I Do If Application Deployment Fails Due to a DNS Resolution Error?
- What Should I Do If JDK Has Been Installed and Environment Variables Have Been Configured, But Application Deployment Fails with the Error Message "please configure JDK environment variables" Displayed?
- What Should I Do If the Log Indicates Insufficient Permissions?
- What Should I Do If the Path Is Invalid?
- What Should I Do If the System Displays a Message Indicating That No Hosts Are Found in the Environment?
- What Should I Do If an Error Is Reported When the Sudo Permission Is Used?
- What Should I Do If the File or File Path Does Not Exist?
- What Should I Do If I Have Insufficient Permissions?
- What Should I Do If the File Path Does Not Exist?
- What Should I Do If the Action "Create and Start Container" Fails on Ubuntu 22 OS When Using Template "Deploy a Docker Application for Linux"?
- What Should I Do If the Connection Times Out Occasionally During a Deployment on a Windows Host?
Custom Application Actions
Health Test via URLs
- Incorrect URL
- URL Does Not Exist
- Invalid URL
- Application Deployment Interruption
- Insufficient Permissions
- Parameters Contain Backslashes (\)
- No Host Exists in the Environment
- Environment Does Not Exist
- Failed to Deploy an Application on a Windows Host
- Error Occurs During Application Deployment with the sudo Privileges
- Deployment Blocked by Third-Party Antivirus Software
- Invalid Path
- A Network Error Occurs During Software Installation on CentOS
- A Network Error Occurs During Software Installation on Ubuntu OS
- Windows Path Not Allowed on a Linux Host
Selecting Deployment Sources
- Software Package Not Found in CodeArts Artifact
- No Software Package Available for a Build Task
- URL Domain Name Resolution Failure
- File Download Times Out
- Inconsistent SHA256 Values in a File
- Inconsistent MD5 Values in a File
- Error "More than 100 build files"
- "HTTP Error 403" Is Displayed When the CodeArts Artifact Software Package Is Downloaded
- Invalid Path
Stopping a Service
- Incorrect Port Number
- Action Stop Service Deployed Successfully, But the Service Is Still in Started State
- Invalid Path
Copying a File
- File to Be Copied Does Not Exist
- Invalid File Path
- File or File Path Does Not Exist
- Action Copy Files Deployed Successfully, But the Expected Result Is Not Achieved
- Log Contains "copy File Failed" When Copying Files Between Linux Environment
- Log Contains "Windows does not support copying files between hosts" When Copying Files Between Windows Environment
- Log Contains "Hosts using secret key credit do not support copying files between" When Copying Files Between Environment
- Invalid Path
Deleting a File
- Cannot Delete Files on a Linux Host
- File Path Does Not Exist on a Windows Host
- Incorrect File Path on a Windows Host
- Invalid Path
Decompressing a File
- File to Be Decompressed Does Not Exist
- Backslashes (\) Are Used as Path Separators in the Native Command Compress-Archive
- Invalid Path
Modifying a Configuration File
- Invalid Path
Starting or Stopping Tomcat
- Invalid Tomcat Path
- Stopping Failed
- Startup Failed
- Environment Variables Are Not Configured
- Service Is Not Started Despite Successful Action Deployment
- Invalid Path
Starting/Stopping Go Service
- The Go Service Path Is Incorrect
- Startup Failed
- Deployment Is Successful, But the Service Is Not Started
- Invalid Path
Starting or Stopping Spring Boot
- Start/Stop Spring Boot
- Invalid Spring Boot Path
- Startup Failed
- Spring Boot Can Still Be Detected After Being Stopped (on Windows)
- Invalid Path
Starting or Stopping Nginx
- Nginx Gets Restarted Repeatedly
- Invalid Windows Host Path
- Deploying the Command for Stopping Nginx When Nginx Is Not Started
- Incorrect Format of the Nginx Configuration File
- Configuration File Backup Path Does Not Exist
- Starting or Stopping IIS
Starting or Stopping Node.js
- Node.js Fails to Be Started or Stopped on a Linux Host
- Node.js Fails to Be Started or Stopped on a Windows Host
- Invalid Path
Running Shell Commands
- A Message Indicating an Operation Failure Is Displayed During Action Run Shell Commands Deployment
- Service Is Not Started But the Log Shows That Shell Commands Are Successfully Executed
- Unidentified Shell Commands Are Used
- Shell Command References a File or Folder That Does Not Exist
- How Does a Shell Command Reference Parameters?
- Deployment of the Action Run Shell Commands Times Out
- Interactive Shell Commands Are Used
- Shell Command Deployment Times Out After the su Command Is Executed to Switch the User
- Invalid Path
- Other FAQs
Running Shell Scripts
- Running Shell Scripts Failed
- Deployment Is Successful But Does Not Achieve the Expected Result
- Invalid Path
Running PowerShell Commands
- Deployment of the Action Run PowerShell Commands Times Out
- Unidentified PowerShell Commands Are Used
- PowerShell Command References a File or Folder That Does Not Exist
- How Does a PowerShell Command Reference Parameters?
- Invalid Path
Running PowerShell Scripts
- Running PowerShell Scripts Failed
- Invalid Path
Running Docker Commands
- Docker Not Installed
- Docker Command Parameter Error
- No Deployment Permissions
- Image Does Not Exist
- login Command Execution Failed
- build Command Execution Failed
- tag Command Execution Failed
- push Command Execution Failed
- run Command Execution Failed
- start, restart, stop, or rm Command Execution Failed
- rmi Command Execution Failed
- pull Command Execution Failed
- rm Command Execution Failed
- Connection Timed Out
- Invalid Path
Pending Execution
- Invalid Path
- FAQs About ServiceStage
FAQs About Kubernetes Deployment Tasks
- Parameter Referenced by {{}} in the Manifest File Is Not Defined in the Application
- Target File Does Not Exist in CodeArts Artifact
- Path of the Manifest File in CodeArts Artifact Is Incorrect
- kubeconfig File Is Incorrectly Configured
- kubectl Command Fails to Be Deployed
- Failed to Deploy Applications on Kubernetes
- Log Contains "Too many files to unzip" When CodeArts Repo Is Selected as the Manifest File Source During Kubernetes Deployment
- Error Message "File is too large" Displayed During Manifest File Source Selection for Kubernetes Deployment
Ansible
- Invalid Entry File Path
- Entry File Not Found
- Copy Module Error
- JSON Parameter Parsing Error
- Service Module in Playbook Scripts Fails to Start or Stop Services
- Ansible Application Deployment Fails
- What Should I Do When the "Do not use the delegate_to, connection, hosts command in the Ansible PlayBook script for executing the local computer" message Is displayed When Running Ansible?
- Invalid Path
Creating an IIS Site
- Physical Path of an Application Does Not Exist
- IIS Not Installed on the Host
- Invalid Path
- How Do I Check the IIS Function on the Local Host?
- Installing IIS
Installing JDK
- A JDK of the Same Version Already Exists on the Target Host
- Java Not Installed on the Target Host
- JDK Decompression Failed
- Cannot Install OpenJDK 8 on Ubuntu 14 or Earlier Versions
- The Deployment Result Is "Openjdk does not support arm"
- Software Version Detected on Windows Host Does Not Match the Installed Version
- Invalid Path
Installing Tomcat
- Deployment Failed
- Invalid Path
Installing Nginx
- No sudo Permissions
- No Permission to Access the Path
- Invalid Path
Installing Go
- Invalid Installation Path
- Invalid Path
Installing PHP
- Error Returned When Installing PHP as a Common User
- Some Dependency Packages Do Not Exist in the CentOS Yum Repository
- Download Fails Due to Network Disconnection from the CentOS Yum Source
- Download Fails Because Some Software Dependency Packages Are Missing for apt-get in Ubuntu
- Invalid Path
Installing Node.js
- Cannot Decompress Node Packages
- Installation Path Fails to Be Created
- Invalid Path
Installing Python
- Invalid Path
Installing/Uninstalling Docker
- Error Returned During the Deployment of the Action for Installing or Uninstalling Docker as a Common User
- Error Returned Even Though the Action for Installing or Uninstalling Docker Is Successfully Deployed
- Invalid Path
- Grayscale Release with Istio
Hosts
- Videos
CodeArts Deploy provides popular templates for deployment process (system templates) and allows you to save custom deployment processes as custom templates, enabling you to quickly create applications. This section describes how to create an application using a template.
You can add a system template to favorites. After the template is added to favorites, the template is moved to the top of the system template list. If you favorite multiple templates, the templates are displayed on the top from newest to oldest based on the time when they are favorited.
Creating an Application Using a System Template - Procedure
- Go to the CodeArts homepage and click the target project name to access the project.
- Choose CICD > Deploy.
- Click Create Application. On the Basic Information page that is displayed, modify the basic information such as Name, Description, Execution Resource Pool as required. For details, see Editing Basic Information.
- After editing the basic application information, click Next and go to the Select Template page.
- Select a recommended template based on the service type. Click OK. The Deployment Actions page is displayed. The left pane is the action orchestration area, and the right pane is the action details area.
- (Optional) Configure application information.
- Click
above or below an added action. All actions that can be added are displayed in the right pane. You can add an action before or after the current action.
- You can drag, add, and delete actions in the action orchestration area.
- You can save the current application as a custom template by clicking Save as Custom Template. Then the template will be displayed under Templates > Custom Templates.
- After adding an action, configure the action information. For details, see Configuring Deployment Actions for an CodeArts Deploy Application.
- After the action information is configured, switch to the Basic Information tab page and click Edit to edit the basic information as required. For details, see Editing Basic Information.
Only specific users at the Mexico site can edit Execution Host.
- Switch to the Parameters tab page, and create custom parameters as required. For details, see Editing Parameters.
- Switch to the Environment Management tab page, and create and manage environments as required. For details, see Configuring an Environment.
- Switch to the Permissions tab page and configure role permissions as required. For details, see Configuring Permissions for Different Roles.
- Switch to the Notifications page to notify users of application events they favorited through emails. For details, see Configuring System Notifications.
- Click
- After configuring all information, click Save.
Generating an application using a system template: Choose Templates > System Templates, and click in the Operation column of the target template.
