Help Center/ CodeArts Deploy/ User Guide/ Configuring Application Deployment Actions/ Configuring Container-based Deployment Actions/ Gray Releasing an Application in Kubernetes (CCE Cluster) with Nginx-Ingress
Updated on 2026-09-11 GMT+08:00
This section describes the procedure for grayscale deployment in a CCE Kubernetes cluster using the Nginx-Ingress component.
  • A CCE cluster is available. You may be charged during the process. For details, see CCE Billing.
  • The NGINX Ingress controller is installed in the CCE cluster.
Configuring Deployment Actions
  1. Create an application by referring to Creating an Application.
  2. On the Deployment Actions page, add this deployment action based on the service scenario.
  3. Configure the action using the parameters described in the table below.
    Table 1 Parameters
    Action Name
    Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
    Tenant
    • Current: The software package is deployed in a CCE cluster of the current tenant for release.
      Select Current. The current tenant must have the CCE cluster operation permission. If not, enable IAM authorization to select an authorized user from the User drop-down list for deployment.
    • Other: The software package is deployed and released in a CCE cluster of another tenant in IAM authorization mode.
      After selecting Other, select an authorized tenant.
    You are advised to configure the AK/SK of a member account that has the CCE cluster operation permission. You are not advised to configure the AK/SK of a tenant account.
    IAM authorization
    If you do not have the permission to call CCE APIs, enable this option to obtain the temporary AK/SK of an authorized user.
    Region
    Select the region to be deployed.
    Cluster Name
    Select the Kubernetes cluster applied for on CCE.
    Namespace
    Select the namespace of the Kubernetes cluster on CCE.
    Workload
    Select the target workload to be deployed.
    Service
    Select the name of the Service bound to the target workload.
    Ingress
    Select the name of the route bound to the target Service.
    Container
    Select the name of the CCE container to be deployed.
    Select the image for deployment.
    Image Tag
    Select the tag of the image for deployment.
    Enable grayscale configuration
    Grayscale release policy:
    The values of Header and Cookie can contain a maximum of 500 characters.
    • Header
      Header-Key: You can enter the key of a custom header.
      Header-Value: You can enter a custom header value. The value can be a character string or a regular expression. The regular expression format is ^....$.
      Gray Traffic Weight (%): You can customize the traffic weight of each service version.
    • Cookie
      Cookie: Enter custom cookie content.
