Redis Connection Parameters
| Parameter | Mandatory | Description |
| Data Connection Type | Yes | Redis is selected by default and cannot be changed. |
| Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
| Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
| Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
| Applicable Modules | Yes | Select the modules for which this connection is available. NOTE:
| Network Connectivity Configuration | ||
| Manual | Yes | Select the connection mode. If you do not need to access MRS clusters in other projects or enterprise projects, select Cluster Name Mode.
| MRS Cluster Name | Yes | The name of the MRS cluster. Select an MRS cluster that Hive belongs to. Only MRS clusters are supported. A Hadoop cluster can be selected only after it is managed by MRS. All the MRS clusters with the same project ID and enterprise project are displayed. NOTE:
If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
NOTE: If an agent is connected to multiple MRS clusters and one of the MRS clusters is deleted or abnormal, connections to the other MRS clusters will be affected. Therefore, you are advised to connect an agent to only one MRS cluster. |
| Server List | Yes | This parameter is displayed when Manual is set to Connection String Mode. One or more servers (server domain name/IP address:server port) separated by commas (,) Example: 192.168.0.1:27017 or 192.168.0.2:27017 |
| KMS encryption key | Yes | KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key. NOTE:
| Agent | Yes | The CDM cluster provides an agent for communications between DataArts Studio and Redis. When creating a Redis connection, select a CDM cluster. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster. |
| DataArts Migration Configuration | ||
| Redis Deployment Mode | Yes | Redis deployment mode. Available options include Single, Cluster, and Proxy. If you have selected Cluster Name Mode for Manual, you can only select Cluster for this parameter. |
| Redis Database Index | Yes | This parameter is mandatory when Redis Deployment Mode is Single. It is similar to the name of a relational database. For example, the value can be 0. |
| Config Path | Yes | This parameter is displayed when Authentication Method is set to KERBEROS. It indicates the OBS path for storing the cluster configuration file. The path must point to a ZIP package with a flat directory structure (no subdirectories) containing the following files:
| keytab File Path | Yes | This parameter is displayed when Authentication Method is set to KERBEROS. Select the OBS path where the keytab file is stored. |
| Principal Name | Yes | This parameter is displayed when Authentication Method is set to KERBEROS. Enter the Kerberos authentication username. |
| Data Source Authentication and Other Function Configuration | ||
| Authentication Method | Yes | This parameter is mandatory when Manual is set to Connection String Mode. Select the authentication type of the database. The options include SIMPLE and KERBEROS. |
| Password | Yes | This parameter is displayed when you select Cluster Name Mode for Manual or select Connection String Mode for Manual and SIMPLE for Authentication Method. Password for accessing the database. The password is required for creating a cluster. |
| Username | Yes | This parameter is displayed when you select KERBEROS for Authentication Method. It indicates the username for accessing the database. Enter the username you set when creating the cluster. |
