MRS Hive Connection Parameters
| Parameter | Mandatory | Description |
| Data Connection Type | Yes | MRS Hive is selected by default and cannot be changed. |
| Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
| Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
| Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
| Applicable Modules | Yes | Select the modules for which this connection is available. NOTE:
| Network Connectivity Configuration | ||
| Connection Type | Yes | Connection type. Proxy connection is recommended.
NOTE: If the connection is used by components other than DataArts Migration and DataArts Factory, the connection mode cannot be set to MRS API connection. |
| Use Cluster Config | No | This parameter is displayed when DataArts Migration is selected for Applicable Modules. MRS Hive connections cannot use cluster configuration. You can use the cluster configuration to simplify parameter settings for the Hadoop connection. |
| Manual | Yes | This parameter is mandatory when you select Proxy connection for Connection Type. Select the connection mode. If you do not need to access MRS clusters in other projects or enterprise projects, select Cluster Name Mode.
| Manager IP | Yes | This parameter is mandatory when Connection String Mode is selected for Manual. Set this parameter to the floating IP address of MRS Manager. Only MRS clusters are supported. A Hadoop cluster can be connected only after it is managed by MRS. NOTE:
You can click Select next to the text box and select an MRS cluster in the same project and enterprise project. If you want to access an MRS cluster in another project or enterprise project, obtain and enter the floating IP address of MRS Manager and ensure that the connection's agent (CDM cluster) can communicate with the tenant-plane MRS cluster. To obtain the floating IP address of MRS Manager, log in to the active master node of the MRS cluster and run the ifconfig command. In the command output, the IP address of eth0:wsom is the floating IP address of MRS Manager. For details about how to log in to the master node of the MRS cluster, see Logging In to an ECS. Enter multiple IP addresses based on the scenario in sequence and separate them with commas (,), for example, 127.0.0.1 or 127.0.0.1,127.0.0.2,127.0.0.3.
| MRS Cluster Name | Yes | This parameter is mandatory when MRS API connection is selected for Connection Type or Cluster Name Mode is selected for Manual. The name of the MRS cluster. Select an MRS cluster that Hive belongs to. Only MRS clusters are supported. A Hadoop cluster can be selected only after it is managed by MRS. All the MRS clusters with the same project ID and enterprise project are displayed. NOTE:
If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
NOTE: If an agent is connected to multiple MRS clusters and one of the MRS clusters is deleted or abnormal, connections to the other MRS clusters will be affected. Therefore, you are advised to connect an agent to only one MRS cluster. |
| SQL Execution Mode | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules. JDBC and API are supported. When connecting to an MRS cluster via JDBC or API to submit SQL statements, if it involves a non-MRS cluster, a non-Hive 3.x scenario, or a scenario where Hive serves as the source, select JDBC. By default, API is only used for submitting the SQL statements used to insert data. To submit other SQL statements, select JDBC. |
| KMS encryption key | Yes | This parameter is mandatory when Connection Type is set to Proxy connection. KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key. NOTE:
| jobGateway IP | Yes | This parameter is mandatory when MRS tenant plane connection is selected for Connection Type or DataArts Migration is selected for Applicable Modules and API is selected for SQL Execution Mode. It indicates the JobGateway IP address, which can be obtained from the MRS JobGateway module.
| Agent | Yes | This parameter is mandatory when Connection Type is set to Proxy connection or MRS tenant plane connection. MRS is not a fully managed service and cannot be directly connected to DataArts Studio. A CDM cluster can provide an agent for DataArts Studio to communicate with non-fully-managed services. Therefore, you need to select a CDM cluster when creating an MRS data connection. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster. As a network proxy, the CDM cluster must be able to communicate with the MRS cluster. To ensure network connectivity, the CDM cluster must be in the same region and AZ and use the same VPC and subnet as the MRS cluster. The security group rule must also allow the CDM cluster to communicate with the MRS cluster. NOTE:
| Data Source Authentication and Other Function Configuration | ||
| Authentication Method | Yes | This parameter is mandatory when Connection String Mode is selected for Manual. It specifies the authentication method used for accessing the MRS cluster. The following options are available:
| Username | Yes | Human-machine user of the MRS cluster. This parameter is mandatory when Connection Type is set to Proxy connection. If a new MRS user is used for connection, you need to log in to Manager and change the initial password. To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user whose password never expires by referring to Creating a Kerberos Authentication User for an MRS Security Cluster. When creating an MRS data connection, set Username and Password to the new MRS username and password. NOTE:
| Password | Yes | The password for accessing the MRS cluster. This parameter is mandatory when Connection Type is set to Proxy connection. |
| Enable ldap | No | This parameter is available when Connection Type is set to Proxy connection. If LDAP authentication is enabled for an external LDAP server connected to MRS Hive, the LDAP username and password are required for authenticating the connection to MRS Hive. In this case, this option must be enabled. Otherwise, the connection will fail. |
| ldapUsername | Yes | This parameter is mandatory when Enable ldap is enabled. Enter the username configured when LDAP authentication was enabled for MRS Hive. |
| ldapPassword | Yes | This parameter is mandatory when Enable ldap is enabled. Enter the password configured when LDAP authentication was enabled for MRS Hive. |
| MRS Authentication Type | Yes | This parameter is mandatory when Connection Type is set to MRS tenant plane connection.
NOTE: The token used for the IAM mode is valid for 24 hours. You need to periodically update the token by editing the data connection (save the settings without modification). The IAM mode is recommended only for test and verification. The keytab mode is recommended for scheduling tasks in the production environment. |
| Username | Yes | This parameter is mandatory when Connection Type is set to MRS tenant plane connection and MRS Authentication Type is set to keytab. If you select an MRS cluster that uses Kerberos authentication, you cannot enter admin for this parameter. The username is the human-machine user or machine-machine user of the MRS cluster. This parameter is mandatory if the MRS tenant plane is used for connection. To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user whose password never expires by referring to Creating a Kerberos Authentication User for an MRS Security Cluster. When creating an MRS data connection, set Username to the new MRS username. |
| Keytab File | Yes | This parameter is mandatory when Connection Type is set to MRS tenant plane connection and MRS Authentication Type is set to keytab. Click Select. In the displayed Driver File dialog box, select a .keytab file and click OK. If no Keytab file is available, obtain one and upload it first. To obtain a Keytab file, perform the following operations: Log in to the MRS console, click the name of a cluster on the Active Clusters page, and click Download Authentication Credential to download a Keytab file. Then decompress the downloaded package and upload the Keytab file to the system.. NOTE: You can upload a Keytab file only if you have at least one of the following permissions:
| Real-time Metadata Synchronization | Yes | When real-time metadata synchronization is enabled, the metadata of the connected MRS cluster is synchronized to the Data Map component in real time. You are advised to enable this function. NOTE:
| Metadata Collection Scope | No | Databases and data tables whose metadata will be synchronized in real time. If this parameter is not set, all metadata will be synchronized. The value can be in either of the following formats:
Examples:
| OBS storage support | No | This parameter is displayed when DataArts Migration is selected for Applicable Modules. The server must support OBS storage. When creating a Hive table, you can store the table in OBS. |
| Use Agency | No | This parameter is displayed when DataArts Migration is selected for Applicable Modules and OBS storage support is enabled. If you enable the agency function, you can create a data connection without having a permanent AK/SK and execute CDM jobs using the scheduling identity configured in DataArts Factory. |
| Public agency | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules, OBS storage support is enabled, and Use Agency is enabled. The agency is only used to check whether the connection agency function is normal. CDM jobs will be executed using the scheduling identity configured in DataArts Factory. |
| AK | N/A | This parameter is displayed when DataArts Migration is selected for Applicable Modules, OBS storage support is enabled, and Use Agency is disabled. AK and SK are used to log in to the OBS server. You need to create an access key for the current account and obtain an AK/SK pair. To obtain an access key, perform the following steps:
| SK | N/A | |
| Data Migration Configuration | ||
| HIVE Version | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules. Hive version Set it to the Hive version on the server. NOTE: Select HIVE_3_X for connections to Hive servers of version 3.x, and select HIVE_2_X for connections to Hive servers of version 2.x. If you select an unmatched connection version, the connection test may succeed, but the queried database table may be empty, or the job may fail. |
| Check Hive JDBC Connectivity | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules. Whether to check the Hive JDBC connectivity |
| Properties | No | This parameter is displayed when DataArts Migration is selected for Applicable Modules. This parameter is optional. You can click Add to add multiple client configuration properties. The following are some examples:
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. To create an MRS user, perform the following steps:
For clusters of MRS 3.x:
- Log in to MRS Manager as user admin.
- Choose System > Permission > Security Policy > Password Policy. Click Add Password Policy and add a policy under which the password never expires.
- Set Password Policy Name to neverexp.
- Set Password Validity Period (Days) to 0, indicating that the password never expires.
- Set Password Expiration Notification (Days) to 0.
- Retain the default values for other parameters.
- Choose . On the page displayed, click Create to add a dedicated human-machine user as the Kerberos authentication user and set the password policy to neverexp. Select the user group superGroup for the user, and assign all roles to the user.
- For clusters of MRS 3.1.0 or later, the user must at least have permissions of the Manager_viewer role to create data connections in Management Center. To perform database, table, and data operations on components, the user must also have user group permissions of the components.
- For clusters earlier than MRS 3.1.0, the user must have permissions of the Manager_administrator or System_administrator role to create data connections in Management Center.
- A user with only the Manager_tenant or Manager_auditor permission cannot create connections.
- Log in to Manager as the new user and change the initial password. Otherwise, the connection fails to be created.
- Synchronize IAM users.
- Log in to the MRS console.
- Choose Clusters > Active Clusters, select a running cluster, and click its name to go to its details page.
- In the Basic Information area of the Dashboard page, click Synchronize on the right side of IAM User Sync to synchronize IAM users.
- If the status is Synchronized, skip this step.
- When the policy of the user group to which the IAM user belongs changes from MRS ReadOnlyAccess to MRS CommonOperations, MRS FullAccess, or MRS Administrator, wait for 5 minutes until the new policy takes effect after the synchronization is complete because the SSSD (System Security Services Daemon) cache of cluster nodes needs time to be updated. Then, submit a job. Otherwise, the job may fail to be submitted.
- When the policy of the user group to which the IAM user belongs changes from MRS CommonOperations, MRS FullAccess, or MRS Administrator to MRS ReadOnlyAccess, wait for 5 minutes until the new policy takes effect after the synchronization is complete because the SSSD cache of cluster nodes needs time to be updated.
For clusters of MRS 2.x or earlier:
- On FusionInsight Manager, choose System Settings and click Configure Password Policy to modify the password policy.
- Choose . On the page displayed, add a dedicated human-machine user as the Kerberos authentication user. Select the user group superGroup for the user, and assign all roles to the user.
- For clusters of MRS 2.x or earlier, the user must have permissions of the Manager_administrator or System_administrator role to create data connections in Management Center.
- Log in to MRS Manager as the new user and change the initial password. Otherwise, the connection fails to be created.
Configuring Real-Time Metadata Synchronization for an MRS Cluster
The real-time metadata synchronization function needs to be manually enabled in the MRS cluster and bound to an agent with the DAYU User permissions for metadata synchronization authentication.
Enable real-time metadata synchronization.
- Choose Cluster > Services > Hive > Configuration > All Configurations, enter the parameter names in Table 2 in the search box, and set the parameters.
Table 2 Configuration parameters Parameter
Value
Purpose
Hive->MetaStore
hive.metastore.customized.configs
- Name: com.huawei.cloud.dataarts.endpoint
- Value: Endpoint of the Data Map component of DataArts Studio
An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. You can obtain the endpoints of the service from Regions and Endpoints.
(Mandatory) Enabling real-time metadata synchronization
- Name: hive.metastore.event.listeners
- Value: com.huawei.cloud.dii.catalog.agent.listener.MrsMetaStoreEventListener
Hive->HiveServer
hive.stats.autogather
true
(Optional) Enabling metadata statistics
hive.security.authorization.sqlstd.confwhitelist
Add ,hive.exec.pre.hooks to the end of the original value.
(Optional) Enabling the last access time
hive.server.customized.configs
- Name: hive.exec.pre.hooks
- Value: org.apache.hadoop.hive.ql.security.authorization.plugin.DisallowTransformHook,org.apache.hadoop.hive.ql.hooks.UpdateInputAccessTimeHook$PreExec
Figure 2 Configuring the hive.metastore.customized.configs parameters
- After configuring all parameters in Table 2, click Save in the upper left corner and OK in the displayed dialog box. Figure 3 Saving the configuration
- After saving the configuration, switch to the Instances tab page, select the instance that has expired, click More, and select Instance Rolling Restart to make the configuration take effect. Figure 4 Performing a rolling instance restart
Authorize and bind an agency.
- Log in to the IAM console.
- Choose Agencies. In the agency list, locate the preset MRS_ECS_DEFAULT_AGENCY agency and click Authorize.
If the preset MRS_ECS_DEFAULT_AGENCY agency is not found, you can buy an MRS cluster and select the MRS_ECS_DEFAULT_AGENCY agency in advanced settings. When the MRS cluster creation starts, the MRS_ECS_DEFAULT_AGENCY agency is automatically generated.
Figure 5 Authorizing an agency
- On the authorization page, enter DAYU in the search box and select DAYU User. Figure 6 Selecting the permission
- After selecting the permission, click Next to set the authorization scope. In this example, retain the default settings and click OK to complete the authorization.
- On the MRS management console, choose Clusters > Active Clusters. Click the name of the target cluster to go to the cluster details page.
- On the Dashboard page, locate the O&M Management area and check that the cluster has been bound to the MRS_ECS_DEFAULT_AGENCY agency. If the cluster is not bound to the MRS_ECS_DEFAULT_AGENCY agency, you need to manually select the MRS_ECS_DEFAULT_AGENCY agency. Figure 7 Binding an agency
