Cassandra Link Parameters
- Cassandra is not supported in version 2.9.3.300 or later.
- Do not change the password or user when a job is running. If you do so, the password will not take effect immediately and the job will fail.
Parameter |
Description |
Example Value |
Name |
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for |
mongodb_link |
Service node |
An address of one node or addresses of multiple nodes. Separate addresses with semicolons (;). You are advised to configure multiple nodes at a time. |
192.168.0.1;192.168.0.2 |
Port |
Port number of the Cassandra node to be connected. |
9042 |
Username |
User name for connecting to Cassandra. |
cdm |
Password |
Password for connecting to Cassandra. |
Connection timeout duration |
(Optional) Displayed when you click Show Advanced Attributes. Connection timeout interval, in seconds. |
5 |
Read timeout duration |
(Optional) Displayed when you click Show Advanced Attributes. Read timeout interval, in seconds. If the value is less than or equal to 0, no timeout occurs. |
12 |
