- What's New
- Billing
- Getting Started
User Guide
- Buying a Cloud Phone Server
- Accessing the Cloud Phone
- Cloud Phone Management
- Cloud Phone Server Management
Using AOSP
- Overview
- Automatic Application Authorization
- Loading Pictures
- Rooting
- Startup Script
- Automatic Installation of Applications
- Hiding Virtual Keys
- Hiding the Status Bar
- Disabling the Notification System
- Disabling Screenshot Protection
- Simulating Location Information
- App Installation Whitelist
- App Installation Blacklist
- Forcibly Installing a 32-Bit Application
- Dynamically Changing the System Language
- Background Process Management
- Texture Compression
- Restarting a Cloud Phone
- Device Emulation
- Cloud Phone Audio and Video
- Configuring a Route
- Permission Management
- Adjusting Resource Quotas
- Monitoring
- CTS
- Appendix
Best Practices
- Best Practices of Connecting to General-Purpose Cloud Phones
Best Practices of Cloud Phone Application Sharing
- Overview of Application Sharing
Usage Guide to Application Sharing
- Purchasing a Cloud Phone Server That Supports Application Sharing
- Preparing the TAR Package of an Application
- Pushing the TAR Package of an Application to a Cloud Phone Server
- Using the appctrl Command to Manage Shared Applications
- Deleting an Application
- Presetting Configuration Files by Sharing Applications
- appctrl Commands
- Installing an Application on Cloud Phones in Batches
- Modifying the Cloud Phone GPS Location
- Using the Cloud Phone Camera
- Using STF to Manage Cloud Phones in Batches
- Allowing a Cloud Phone Server to Access a Public Network Outside the Chinese Mainland
- Delegating CPH to Operate OBS Buckets
- Changing the AOSP Version of a Cloud Phone
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
Cloud Phone Server APIs
Cloud Phone Servers
- Querying cloud phone servers
- Querying the Details of a Cloud Phone Server
- Querying Flavors of Cloud Phone Servers
- Restarting Cloud Phone Servers
- Changing the Cloud Phone Server for a Cloud Phone
- Pushing Shared Storage Files
- Querying Shared Storage Files
- Deleting Shared Storage Files
- Pushing Shared Applications
- Deleting a Shared Application
- Changing the Flavor of a Cloud Phone Server
- Modifying the Name of a Cloud Phone Server
- Bandwidth
Cloud Phones
- Querying Cloud Phones
- Querying Cloud Phone Details
- Obtaining the Cloud Phone Access Information
- Querying Cloud Phone Flavors
- Querying the Image of a Cloud Phone
- Resetting Cloud Phones
- Restarting Cloud Phones
- Stopping Cloud Phones
- Editing the Name of a Cloud Phone
- Updating Properties of Cloud Phones
- Exporting Data from Cloud Phones
- Restoring Data of Cloud Phones
- Diverting Cloud Phone Traffic
- Expanding the Data Disk of a Cloud Phone
- Tasks
- Keys
- Encoding Services
- ADB Commands
- Tags
- Images
Cloud Phone Servers
- Common Parameters
- Appendix
Consulting
- What Are the Advantages of Huawei Cloud Phone Compared with Other Similar Solutions?
- Does Cloud Phone Support iOS?
- Are There Cloud Phone Root Permissions?
- Does Each Cloud Phone Has an Independent Public IP Address?
- How Is CPH Billed?
- How Do I Obtain the Project ID?
- How Do I Install Applications on a Cloud Phone?
- How Long Does It Take to Activate a Server After I Purchase It?
- What Should I Do If I Can't Find My Cloud Phone Server on the CPH Console?
- How Long Will Resources Be Released After My Cloud Phone Server Expires?
- What Can I Do If the Private Key File Is Lost?
- How Can I Know Whether the SSH Service Has Been Installed on My Local Device?
- What Are Common ADB Commands?
- Does the Cloud Phone Support Cameras?
- Does the Cloud Phone Support Facial Recognition?
- What Are the Security Group Authorization Rules for Cloud Phones Using Custom Networks?
SSH Tunnel Faults
- What Can I Do If the SSH Tunnel Fails to Be Established When I Access the Cloud Phone over the Public Network?
- What Does Message "Authorized users only. All activities may be monitored and reported." Indicate?
- What Can I Do If Message "too open" Is Displayed When I Am Establishing the SSH Tunnel?
- What Can I Do If Message "Permission denied" Is Displayed When I Am Establishing the SSH Tunnel?
- What Can I Do If Message "no match mac found" Is Displayed When I Am Establishing the SSH Tunnel?
- What Can I Do If Message "no matching key exchange method found" Is Displayed When I Am Establishing the SSH Tunnel?
- How Do I Keep an SSH Session Uninterrupted?
- What Can I Do If I Failed to Establish an SSH Tunnel?
- What Can I Do If an Error Occurs When I Invoke the Cloud Phone Query API?
- ADB Connection Faults
Consulting
Show all
ADB (Recommended)
You can use ADB to access your cloud phones on the CPH console. This method is similar to the ADB (Internet) method. The access principles are the same.
The cloud phone must be in the Running state.
- On the Service List page, choose Compute > Cloud Phone Host.
The CPH console is displayed.
- In the navigation pane on the left, choose Instances.
- On the Instances page, locate the target cloud phone, and choose More > Access Through ADB in the Operation column.
The right pane is displayed.
- Enter the local path for storing the private key file of the server, for example, C:\Users\Administrator\Downloads\KeyPair-a49c.pem.
- Enter the platform-tools directory. To obtain the directory,
download the ADB tool and decompress the tool package to a specified directory, for example, C:\Users\Administrator\Downloads\platform-tools.
If you cannot access the ADB download address on the console, click the following link to download ADB:
https://dl.google.com/android/repository/platform-tools-latest-windows.zip
- Enter a local idle port number.
Run the netstat -an command to check whether the port is idle.
As shown in the following figure, port 6667 is occupied by another program, and port 1234 is idle.
- After you performed 5, 6, 7 in the lower part of the right panel, the command is automatically filled in the blank area. Perform operations as prompted to access the cloud phone.
For details about the parameters in the command for establishing an SSH tunnel, see ADB (Internet).
If you select Automatically-assigned IPv6 address when purchasing a cloud phone server, you can use the IPv6 address of the server to establish a tunnel to connect to the cloud phone. The command structure is the same as that for an IPv4 address. The following is an example:
ssh -L 1234:[fd00::aed:96]:5555 05e1aexxx@ xxx:xxx:xxx:xxx -i C:\Users\Administrator\Downloads\KeyPair-a49c.pem -o ServerAliveInterval=30 -Nf
For details about how to troubleshoot SSH tunnel establishment faults, visit the following links:
