Updated on 2026-02-11 GMT+08:00
Building an Image and Pushing It to SWR
CodeArts Build provides a large number of default build actions and templates. If necessary dependency packages and tools are missing, you can create a custom image from a Dockerfile and push the image to SWR. For details about how to use the pushed image, see Using an SWR Public Image.
CodeArts Build uses CentOS 7 and Ubuntu 18 as the base images, which are provided with multiple common environment tools. You can configure custom environments as required. To download the Dockerfile, following these steps:
  1. In the upper right corner of the CodeArts Build homepage, click More and select Custom Build Environments from the drop-down list.
  2. On the Custom Build Environments page, click a base image to download the Dockerfile template.
  3. Edit the downloaded Dockerfile.
    You can add other dependencies and tools required by the project to customize the Dockerfile. The following figure shows an example of adding JDK and Maven tools.
    RUN yum install -y java-1.8.0-openjdk.x86_64
    RUN yum install -y maven
    RUN echo 'hello world!'
    RUN yum clean all
Tutorial Video
Learn to create a custom Maven image and push it to SWR.
Preparations
  • You have created an organization in SWR. For details about organization restrictions, see notes and constraints of SWR.
  • If you want to push the created image to SWR of other Huawei Cloud users, perform the following operations.
    1. Access the CodeArts Build homepage from the project page.
    2. In the navigation pane, choose Settings > General > Service Endpoints.
    3. Select IAM user from the Create Endpoint drop-down list box. In the displayed dialog box, enter the following information and click Confirm.
      • Service Endpoint Name: Assign a custom name to the endpoint. Enter a maximum of 256 characters, including letters, digits, hyphens (-), underscores (_), periods (.), and spaces.
      • Access key ID (AK) and secret access key (SK) are used like passwords to authenticate users who make API requests.
        On the CodeArts Build homepage, click Console, hover the cursor on the username in the upper right corner, and choose My Credentials from the drop-down list. In the navigation pane on the left, choose Access Keys to create a user key.
  • If you want to push the created image to other image repositories, perform the following operations.
    3. Select Docker repository from the Create Endpoint drop-down list box. In the displayed dialog box, enter the following information and click Confirm.
      • Repository Address: Enter the address of the target image repository.
      • Username: Enter the username for logging in to the repository.
      • Password: Enter the password used for logging in to the repository.
Build on GUI
Add Build Image and Push to SWR after Build with Maven, when configuring build actions.
Retain the default values for the Build with Maven action. If the current parameter settings do not meet your requirements, modify the parameter settings by referring to Building with Maven. For details about the parameters for the Build Image and Push to SWR action, see Table 1.
Table 1 Parameters for creating an image and pushing it to SWR
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select the Docker version, or use the default one.
Currently, CodeArts Build supports Docker 18.03 and Docker 20.10.
Image Repository
Select the target image repository. You can push the image to Huawei Cloud SWR and other image repositories.
Authorized User
Specify the user to which the target image repository belongs. You can push the image to the current user or other user's image repository.
Ensure that you have permissions to edit or manage all images in the organization. For details, see User Permissions.
IAM Account
Expand the drop-down list and select the service endpoint created in Preparations for the specific IAM account. Then, use the service endpoint to push the files to the user's SWR.
This parameter is mandatory when Authorized User is set to Other.
Push Region
Select the target region of your push. The built image will be pushed to the SWR repository in this region.
Docker Repository Endpoint
Select the Docker repository service endpoint created in Preparations and push the image to the corresponding repository through the service endpoint.
Organization
Select the organization created in Preparations from the drop-down list box. The image will be placed in this organization after being pushed to SWR.
Image Name
Enter the name of the created image.
The value must start with a digit or letter and can contain 1 to 255 characters, including only lowercase letters, digits, underscores (_), and hyphens (-).
Image Tag
Specify the image tag, which can be customized. You can use Image name:Tag to uniquely specify an image.
The value can contain 1 to 128 characters, including only letters, digits, periods (.), underscores (_), and hyphens (-). It cannot start with periods or hyphens.
Working Directory
Work directory of docker build. The context path parameter in the docker build command is the relative path of the root directory of the repository.
When Docker builds an image, the docker build command packs all content under the context path and sends it to the container engine to help build the image.
Dockerfile Path
Path of the Dockerfile. Set this parameter to a path relative to the working directory. For example, if the working directory is the root directory and the Dockerfile is in the root directory, set this parameter to ./Dockerfile.
Add Build Metadata to Image
Specify whether to add the build information to the image. After the image is created, run the docker inspect command to view the image metadata.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - build_image:
        inputs:
          regions: ["x-x-x", "x-x-xxx"]
          organization: codeci_test
          image_name: demo
          image_tag: ${GIT_COMMIT}
          dockerfile_path: dockerfile/Dockerfile
          build_args:
            - name: aaa
              value: iuhascihsd
          # set_meta_data: true
          ignore_fail: true
Table 2 Parameters in the sample code for creating an image and pushing it to SWR
Type
regions
List
Optional.
Select the region of SWR where the image is to be uploaded to. By default, the image is uploaded to SWR in the region where the current task is located. If multiple regions are configured, the built image will be pushed to SWR in each region in sequence after the image is created.
organization
String
Enter the name of the organization to which the image belongs after being pushed to SWR. The organization name is the name of the organization created in Preparations.
image_name
String
Optional.
The default value is demo.
image_tag
String
Optional.
The default value is v1.1.
context_path
String
Optional.
The default value is ..
dockerfile_path
String
Optional.
The default value is ./Dockerfile.
build_args
String
Optional. Set the build-arg parameter if it is required in the docker command.
set_meta_data
Bool
Optional.
  • true: Add the build information to the image.
  • false: Do not add the build information to the image.
The default value is false.
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
