Updated on 2025-09-23 GMT+08:00
Importing IAM Users from Your Account
You can create multiple IAM users in your account, and then add them as project members in CodeArts.
Step
Step 1: Create IAM Users
Create IAM users in your account. Ensure that you have the Tenant Administrator role. If you already have IAM users, skip this step.
For details about how to grant the Tenant Administrator role to a user, see Creating a User Group and Assigning Permissions.
Step 2: Import IAM Users from Your Account
Add IAM users as project members. Ensure that you have the DevUC > project-role > userconfig permission. How Do I Check and Obtain Required Project Permissions?
Step 3: Manage Project Members
Change a member's role or remove a user as needed. Ensure that you have the DevUC > project-role > userconfig permission.
  1. Log in to the Log in the IAM console.
  2. Choose Users from the navigation pane, and click Create User in the upper right.
  3. Configure the user information. For details about the parameters, see Creating an IAM User.
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the target project name to go to the project.
  3. Choose Settings > Members from the navigation pane. The member management page is displayed.
  4. Click the Member View tab, click Add Members, and select From My Account.
  5. In the displayed dialog box, select the target IAM users, and click Next.
  6. Configure roles and member groups, and click Save.
    Figure 1 Adding users from your account
    Table 1 Setting a role
    Role
    The role of a user in the CodeArts project. The default role is Viewer.
    You can select a system role or a custom role.
    • System roles include project manager, product manager, test manager, system engineer, committer, developer, tester, participant, and viewer.
      For details about the system roles in CodeArts projects, see built-in project roles in CodeArts.
    • For details about how to create a custom role, see Managing Custom Project Roles.
    Member Groups
    The group to which the user belongs in CodeArts. For details about how to create a member group, see Step 3: Manage Project Members.
    This parameter is optional. Configure it as needed.
    The new members are displayed in the list.
  4. Perform the operations listed in the table below as needed.
    Figure 2 Managing project members
    Table 2 Managing project members
    Operation
    Changing member roles
    • Changing the role of a single member
      1. On the Member View tab, locate the target member and click in the Operation column.
      2. Select the desired role and click OK.
        The new role is displayed in the list.
    • Changing the roles of multiple members
      1. On the Member View tab, select the members you want to modify, and click Edit at the bottom of the page.
      2. In the displayed dialog box, confirm the operation and click OK.
      3. Select a role and click OK.
        The new role of the modified members is displayed.
    Removing members
    • Removing a single member
        The removed member is no longer displayed in the list.
    • Removing multiple members
      1. On the Member View tab, select the members you want to remove, and click Remove at the bottom of the page.
    This operation only removes the users from the project. To delete the users, see Deleting an IAM User.
    Exporting members
    On the Member View tab, click Export Members.
    Grouping members
    1. On the Member Groups tab, click Create Member Group.
    2. Configure the following information and click Save.
      • Member Group Name: Enter a maximum of 30 characters. Letters, digits, and underscores (_) are supported.
      • Description: Enter a maximum of 256 characters. Letters, digits, spaces, commas (,), periods (.), parentheses (()), and brackets ([]) are supported.
      The new member group is displayed in the list.
    3. Click in the Operation column.
    4. On the Members tab, click Add Member.
    5. Select project members and click Save.
    Viewing project members by role
    On the Role View tab, click a role name. The members with this role in the project are displayed.
