Updated on 2025-09-23 GMT+08:00
Importing Users from an Agency
When your enterprise needs to manage and access resources in multiple accounts, you can create users using IAM Identity Center, and add these users as CodeArts project members.
Step
Step 1: Create an Agency
Create an agency in IAM Identity Center.
Step 2: Import Users from the Agency
Import users from the agency as project members. Ensure that you have the DevUC > project-role > userconfig permission. How Do I Check and Obtain Required Project Permissions?
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the target project name to go to the project.
  3. In the navigation pane, choose Settings > Members.
  4. Click the Member View tab, choose Add Members, and select From Agencies.
  5. In the displayed dialog box, select users, specify a role for each user, and click Save.
    Figure 1 Importing users from an agency
    The new members are displayed in the list.
Helpful Links
