- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Basic Configurations/
SLO Management/
Viewing the SLO Interruption Records
- Log in to COC.
- In the navigation pane on the left, choose Basic Configurations > SLO Management.
- In the SLO management list, locate the target metric, click Interrupt Record in the Operation column.
Figure 1 Viewing the SLO interruption records
- Click the search box. The search criteria list is displayed. Select search criteria, enter values, and press Enter to search for data. You can click the refresh icon next to the search box to refresh the data and configure the fields to be displayed in the list.
- Click Add Interrupt Record. The Add Interrupt Record drawer is displayed. Set the corresponding parameters and click OK.
Figure 2 Adding an interrupt record
- Click Correct in the Operation column. The Correct the Interruption Record page is displayed on the right. You can modify the unavailable duration of the interruption.
Figure 3 Modifying an interruption record
- Click Correct Record in the Operation column. The Correct Record dialog box is displayed on the right. You can view the modification history.
Figure 4 Viewing interrupt modification records
Parent topic: SLO Management
