- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Parameter Management/
Parameter Center/
Modifying a Parameter
- Log in to COC.
- In the navigation pane, choose Resource O&M > Automatic O&M and click Parameter Center. Locate the target parameter record, and click Modify in the Operation column.
Figure 1 Parameter list
- On the displayed Modify Parameters page, Parameter Name, Enterprise Project, and Parameter Type cannot be changed.
Figure 2 Parameter details
- Modify the parameters as required and click Submit.
CAUTION:
If the notification time is a relative time, note the following:
- For unmodified notifications: If you click the modification button, the notification time will change immediately.
- For pre-deletion notifications: If you change the deletion time, the pre-deletion notification time will also change.
Parent topic: Parameter Center
