Updated on 2025-08-08 GMT+08:00
Batch Starting ECSs
COC provides unified operations on ECSs. You can start ECSs one by one or in batches.
Precautions
  • You can perform this operation only when the instance is stopped.
  • If any service ticket (for example, restart service ticket) is being executed on the selected instance, the current operation cannot be performed. Wait until the existing service ticket is complete and try again.
Batch Starting ECSs
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resource O&M > Batch Resource Operations.
  3. On the displayed page, choose the Elastic Cloud Server (ECS) tab and click Start ECSs.
  4. Click Add and configure the parameters on the Select Instance dialog box.
    Table 1 Instance parameters
    Example Value
    Selection Method
    Select an instance selection method.
    • Manual Selection: Manually select an instance based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    • Select All: Automatically select all instances based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    Manual Selection
    Enterprise Project
    Select an enterprise project from the drop-down list. You can choose All.
    All
    View Type
    Select a view type.
    • CloudCMDB resources: Select an instance from the resource list.
    • CloudCMDB application groups: Select an instance from the application group list.
    CloudCMDB resources
    Resource Type
    The default value is used and cannot be changed.
    ECS
    Region
    Select a region from the drop-down list.
    CN-Hong Kong
    Target Instance
    Set filter criteria in the filter box and select the filtered instances manually or automatically.
  5. Set parameters for Batch Policy, Suspension Policy, and Timeout Interval.
    • Batch Policy: Select Automatic, Manual, or No Batch.
      • Automatic: The selected instances to be executed are automatically divided into multiple batches based on the preset rule.
      • Manual: You can manually create multiple batches and add instances to each batch as required.
      • No Batch: All instances will be executed in the same batch.
    • Suspension Policy:
      • You can set the execution success rate. When the number of failed hosts reaches the number failed ones that are calculated based on the execution success rate, the service ticket status becomes abnormal and the service ticket stops being executed.
      • The success rate ranges from 0 to 100 and supports accuracy up to one decimal place.
    • Timeout Interval: Value range: 1 to 1800, in seconds.
  6. Click OK to go to the Confirm Execution page. Click OK to start the execution.
  7. Perform the following operations to check whether a service ticket execution is complete.
    • For the service tickets that are being executed:
      • If you want to pause the next batch when the current batch is executed, click Pause in the upper right corner.
      • If you want to continue the paused batch, click Continue in the upper right corner.
      • If you want to stop the service ticket that is about to be executed or is abnormal, click Forcibly End.
    • For the service tickets that are executed:
      • If some or all instance tasks in the service tickets are executed abnormally:
        • Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Retry in the Operation column.
        • Select an abnormal batch and click Batch Retry above the instance to re-execute all abnormal tasks in the current batch.
        • Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Cancel in the Operation column.
        • Select an abnormal batch and click Batch Cancel above the instance to cancel all abnormal tasks in the current batch.
      • If all instance tasks in the service tickets are executed successfully no more operation is needed.
